riverboat2001 18 Posted November 12, 2019 Share Posted November 12, 2019 Not sure how exactly to explain this.I use a third party web app, where i import my M3U link and then go into the app and sort/organise my links into UK/Sports/Movies/Kidsetc. In perfect Player on an Android box these would all show up under separate headings. I've imported my M3U url into Emby, but i now have a channel list with over 250 channels. That's a lot to scroll through. Would it be possible to create Live TV UK - Live TV Sports - Live Movies -Live KidsThe app I use would allow me to create multiple M3U's so I could create an M3U containing just Sports then one for Kids. So, basically when I start the Emby app under "My Media" all the different TV line-ups would have their own box"Is this clear? and can/how could I do it. Link to comment Share on other sites More sharing options...
Luke 37064 Posted November 12, 2019 Share Posted November 12, 2019 Hi, ultimately that's not how we plan to do it, but we will be improving our sorting, filtering and categorization features to better accommodate this. Thanks. Link to comment Share on other sites More sharing options...
riverboat2001 18 Posted November 13, 2019 Author Share Posted November 13, 2019 What is the currently suggested way of managing and sorting hundreds of channels?Would it be to manually go through them and renumber them all so they show up in the order which best suits me, or could I tag them and sort via tags? Family love some of the channels, but wading through hundreds of channels to get where they won't to be isn't floating their boat. Link to comment Share on other sites More sharing options...
ebr 14913 Posted November 13, 2019 Share Posted November 13, 2019 Hi. Do you actually need to access all those channels? Why not wean your m3u list down to just the ones you want? We will make this easier in the future but limiting the input is a good first step to simplifying it for you. Link to comment Share on other sites More sharing options...
riverboat2001 18 Posted November 14, 2019 Author Share Posted November 14, 2019 Okay. Using epg for IPTV I have got the list down to about 100.Epg for IPTV allows you to create a custom M3U file, basically you input your url. then you can edit out all the channels you don't want. it then creates a custom m3u file and a matching xml file. This has worked flawlessly using cheap android boxes running perfect player etc (with all my unwanted channels gone) However I've used the same m3u and xml in emby, but this emby imports all 1000+ channels.Any idea how I can get around this?https://www.iptv-epg.com Link to comment Share on other sites More sharing options...
Luke 37064 Posted November 14, 2019 Share Posted November 14, 2019 Make sure to refresh the guide in emby after making the changes. Link to comment Share on other sites More sharing options...
riverboat2001 18 Posted November 14, 2019 Author Share Posted November 14, 2019 Definitely done that. Also restarted server. Link to comment Share on other sites More sharing options...
Luke 37064 Posted November 14, 2019 Share Posted November 14, 2019 Have you checked the contents of the url? Link to comment Share on other sites More sharing options...
riverboat2001 18 Posted November 14, 2019 Author Share Posted November 14, 2019 No, i haven't. I understand what you mean, but don't know how to do it. Link to comment Share on other sites More sharing options...
Luke 37064 Posted November 14, 2019 Share Posted November 14, 2019 You just put the m3u url in a browser, look at the contents and verify the channels you don't want are no longer present. 1 Link to comment Share on other sites More sharing options...
ernstgot 17 Posted November 14, 2019 Share Posted November 14, 2019 (edited) I am also interested in this as a possibility, I have several different M3U files, one for live tv, and a couple for on demand sources. Would be nice to be able to add "Live TV" "Movies on Demand" "TV on Demand" to the My Media section or to have the ability to add the "On Demand" as a tab to "Live TV" section. Edited November 14, 2019 by ernstgot 1 Link to comment Share on other sites More sharing options...
riverboat2001 18 Posted November 14, 2019 Author Share Posted November 14, 2019 I've opened the file and it's a bit confusing. I should have 103 channels. There seem to be a lot of doubles and trebles of channels and I can't understand why. Could you have a look at the file and tell me where I'm going wrong please.In the channel lineup in Emby I have lots of blank channels. But my epg and m3u should only have 103 channels Channel list.zip Link to comment Share on other sites More sharing options...
Luke 37064 Posted November 14, 2019 Share Posted November 14, 2019 It sounds like you removed the channels from your guide data source, but they still exist in your tuner source (m3u). Link to comment Share on other sites More sharing options...
riverboat2001 18 Posted November 14, 2019 Author Share Posted November 14, 2019 I'll get on to epg for iptv to double check that there is no issue thier end. Is there anyway for me to open that file and check.Many Thanks for your help in this. Is work underway to help us organise/sort these m3u files in a more user friendly way? Link to comment Share on other sites More sharing options...
riverboat2001 18 Posted November 14, 2019 Author Share Posted November 14, 2019 This is the sort of thing I'm seeing. Link to comment Share on other sites More sharing options...
Luke 37064 Posted November 14, 2019 Share Posted November 14, 2019 Is work underway to help us organise/sort these m3u files in a more user friendly way? Yes it is. 1 Link to comment Share on other sites More sharing options...
riverboat2001 18 Posted November 14, 2019 Author Share Posted November 14, 2019 In the meantime I'll just have to rename the sort order to put all the blank and doubles at the bottom of the pile? Link to comment Share on other sites More sharing options...
Luke 37064 Posted November 15, 2019 Share Posted November 15, 2019 That could potentially work for now. 1 Link to comment Share on other sites More sharing options...
riverboat2001 18 Posted November 15, 2019 Author Share Posted November 15, 2019 (edited) I deleted the m3u and xml, however despite refreshing and even restarting the server, the channel listings remain in the guide. The channels themselves don't play.Is there a folder/file somewhere that I need to delete to force an update?I remade the m3u and xml with only two channels in it.When I go into mapping they are the only ones that show up. But despite again restarting server, refreshing the guide all the other channels still appear in the epg guide but don't play. Edited November 15, 2019 by riverboat2001 Link to comment Share on other sites More sharing options...
Luke 37064 Posted November 15, 2019 Share Posted November 15, 2019 Try refreshing the guide again. Link to comment Share on other sites More sharing options...
riverboat2001 18 Posted November 15, 2019 Author Share Posted November 15, 2019 Refreshed the guide a million times with no change. Restarted the server and the PC. But the epg and the now non working channels don't change. (they say no streams were provided for playback.) which would be correct. Even if I completely remove the m3u and xml file they stay in the TV listings. Refresh and restarting the server again doesn't remove them. Would it be possible to browse to where the files are stored and delete them manually? Sent from my G8441 using Tapatalk Link to comment Share on other sites More sharing options...
