Emby Blog
  • entries
    580
  • comments
    5040
  • views
    3635985
Contributors to this blog
  • Luke 355
  • ebr 70
  • Carlo 31
  • sross44 26
  • 7illusions 15
  • ScottIsAFool 12
  • Abobader 11
  • radeon 8
  • xnappo 8
  • darwindeeds 7
  • Redshirt 6
  • Cheesegeezer 5
  • leedavies 3
  • Aphid 3
  • bigjohn 3
  • snazy2000 3
  • softworkz 3
  • techywarrior 3
  • Soultaker 2
  • chef 2
  • gcw07 2
  • marcelveldt 1
  • hurricanehrndz 1
16 Comments
Recommended Comments
TDriver
It's a shame that even after two years the German language is still not implemented.
  • Like 1
Luke
Hi, stay tuned for more coming.
spideytoto
Stay tuned for the french language too?
Coop4rilla1
I cannot connect to the server.  I believe i have messed something up. My server isn’t showing up and i don’t know the server to connect
Luke
HI, yes !
Luke
Hi, did you try clicking add server and entering your server information manually? Are you trying to connect to your own server or someone else's?
MadeByFrank
The tv surrounding episode screenshots for shows looks terrible. Is there a setting specifically for this or can you add one. It makes every theme look horrible.
Luke
That's the cover art plugin, so check in it's settings.
TulsaTV
This update partially broke the skill for me.
If I start with "Alexa, ask M... B home to play music", she says, "Sorry, I don't have an answer for that." But if I start with "Alexa, open M... B home", then follow up with "Play music", she does play music from my library.
Once Emby is opened, the full command "Alexa, ask M... B home to play music" does work.
But if I say "Next" or "Skip" once she is playing a song, she says "I encountered a glitch. Can you say that again?" When I repeat it, she says "No media found", seemingly implying that only the current song is on the queue. But another song does start after the current one finishes.
If I say "Stop", she says "I encountered a glitch. Can you say that again?" When I repeat it, she does stop.
So there is no way I can find to skip to the next song.
hatharry
Thank you for the feedback
Luke
HI, we are looking into it, thanks.
TulsaTV
Any updates on this problem?
Luke
HI, an update went out. Can you please try again? If there's still an issue then please open a topic in the community as this is the release announcement and not the best place to troubleshoot. Thanks !
TulsaTV
Yes, the skill is responding properly to the Next (Skip) and Stop commands now. Thanks!
  • Thanks 1
stephan1827
Would it be possible to add a profile pin for users? Similar to web interface?
Ideally this would use the FireTV native pin pad and not the d-pad
Luke
Hi, Emby for Fire TV will be getting this feature very soon. Thanks.
