Mohd11 1 Posted June 23, 2021 Share Posted June 23, 2021 I subscribed to a library and everything is fine, but sometimes I face a problem with the translation, which is late or advanced. Why can't I adjust its speed? 1 Link to comment Share on other sites More sharing options...
Luke 37010 Posted June 23, 2021 Share Posted June 23, 2021 Hi there, can you please go over an example? What do you mean by problem with the translation? Link to comment Share on other sites More sharing options...
Abobader 2941 Posted June 24, 2021 Share Posted June 24, 2021 Topic title change. In his other post, he indicated that the sync speed for the subtitle do not match the media file, so he looking for either for LG or Emby to be able to change the subtitle timing. Link to comment Share on other sites More sharing options...
Solution Luke 37010 Posted June 24, 2021 Solution Share Posted June 24, 2021 OK, the next update to our LG app will have the subtitle offset feature. 2 Link to comment Share on other sites More sharing options...
Unreachable 0 Posted June 25, 2021 Share Posted June 25, 2021 On 6/24/2021 at 9:02 AM, Luke said: OK, the next update to our LG app will have the subtitle offset feature. Hi, How long does it take for the new update to arrive? If LG tv and LG projector(for example LG HF80LS) applications are different versions, we expect the update to come to LG projectors as well. In addition, subtitle offset can be adjusted in 1 second intervals in Android TV applications. Can't you make this value at least 100ms? Thanks, Link to comment Share on other sites More sharing options...
Luke 37010 Posted June 25, 2021 Share Posted June 25, 2021 Hopefully it will be soon. Thanks. Link to comment Share on other sites More sharing options...
Mohd11 1 Posted June 25, 2021 Author Share Posted June 25, 2021 On 24/06/2021 at 09:02, Luke said: OK, the next update to our LG app will have the subtitle offset feature. When will the update be released? Link to comment Share on other sites More sharing options...
Luke 37010 Posted June 25, 2021 Share Posted June 25, 2021 Hopefully soon. Thanks. Link to comment Share on other sites More sharing options...
Unreachable 0 Posted August 24, 2021 Share Posted August 24, 2021 On 6/25/2021 at 6:28 PM, Luke said: Hopefully it will be soon. Thanks. Has it been updated ? Link to comment Share on other sites More sharing options...
Luke 37010 Posted December 16, 2021 Share Posted December 16, 2021 Emby for LG TV's 1.0.31 has been released. Stay tuned to the blog for the release announcement. Link to comment Share on other sites More sharing options...
Mohd11 1 Posted December 30, 2021 Author Share Posted December 30, 2021 On 16/12/2021 at 11:48, Luke said: Emby for LG TV's 1.0.31 has been released. Stay tuned to the blog for the release announcement. Hi The application is still very slow, And I talked to you about subtitle offest And you told me that it will be added in the next update and it has not been added Link to comment Share on other sites More sharing options...
Luke 37010 Posted December 31, 2021 Share Posted December 31, 2021 5 hours ago, Mohd11 said: Hi The application is still very slow, And I talked to you about subtitle offest And you told me that it will be added in the next update and it has not been added @Mohd11, the latest update has the subtitle offset feature, but whether it is active or not depends on how the subtitles are being played. Can we please look at an example? Thanks. Link to comment Share on other sites More sharing options...
Luke 37010 Posted February 14 Share Posted February 14 Hi, for those running a projector please try searching the LG store. According to LG we're in the store for projectors running WebOS 4+. Thanks. Link to comment Share on other sites More sharing options...
