Richard Branches 231 Posted May 8, 2021 Share Posted May 8, 2021 (edited) Multichannel FLAC won't play when connected to mobile data and it shows the below error message, though they play fine when using WiFi. I ignore if other multichannel audio formats present the same problem. The "Internet quality" option is set to "Auto", I didn't check if they play selecting other audio qualities. I'm using the latest Emby mobile stable 3.1.94. I'm using the latest beta server 4.6.0.43. A transcoding log is also created by the server. ffmpeg-transcode-1b0b895e-ef0e-4344-a3d6-5a29535d877d_1.txt Edited May 8, 2021 by Richard Branches Link to comment Share on other sites More sharing options...
Richard Branches 231 Posted May 8, 2021 Author Share Posted May 8, 2021 (edited) Please delete this comment. Edited June 5, 2021 by Richard Branches Link to comment Share on other sites More sharing options...
Richard Branches 231 Posted May 8, 2021 Author Share Posted May 8, 2021 (edited) On Android Mobile everything plays directly or transcoded (depending on the upload limitation set in the server) except multichannel FLAC with the error message I shared above. The "Internet quality" in the app is set to "Auto". Edited June 5, 2021 by Richard Branches Link to comment Share on other sites More sharing options...
Luke 36999 Posted May 10, 2021 Share Posted May 10, 2021 Hi, let's look at an example: Thanks. Link to comment Share on other sites More sharing options...
Richard Branches 231 Posted May 10, 2021 Author Share Posted May 10, 2021 (edited) I already attached a log file and also sent a log from the app... Edited May 10, 2021 by Richard Branches Link to comment Share on other sites More sharing options...
Luke 36999 Posted May 10, 2021 Share Posted May 10, 2021 The android mobile app doesn't have a send log function. Link to comment Share on other sites More sharing options...
Richard Branches 231 Posted May 10, 2021 Author Share Posted May 10, 2021 1 minute ago, Luke said: The android mobile app doesn't have a send log function. I attached a log from the server. I forgot to extract the android mobile one, hold on please... Link to comment Share on other sites More sharing options...
Richard Branches 231 Posted May 10, 2021 Author Share Posted May 10, 2021 See which one works for you. 56713a0f-84df-4374-8616-dd9cec3ec8f2.log 74d8be09-3185-45c1-9754-0d13eebfcdf2.log Link to comment Share on other sites More sharing options...
Richard Branches 231 Posted May 14, 2021 Author Share Posted May 14, 2021 (edited) Question: Why don't you publish the android mobile beta apps in the "Emby for Android Release Notes (BETA)" or in the "Emby for Android Beta Release Note History" inside the Android topic of the testing area section similar as you do with the Android TV app? Edited May 14, 2021 by Richard Branches 1 Link to comment Share on other sites More sharing options...
Carlo 4330 Posted May 14, 2021 Share Posted May 14, 2021 It would surely make it easier to find. Link to comment Share on other sites More sharing options...
Luke 36999 Posted May 20, 2021 Share Posted May 20, 2021 Are you still having an issue with this? Link to comment Share on other sites More sharing options...
Richard Branches 231 Posted May 20, 2021 Author Share Posted May 20, 2021 Yes, but I haven't said anything because I was waiting to be notified or I find out myself when you post the release notes, on beta 3.1.96 the issue is still present. Link to comment Share on other sites More sharing options...
Luke 36999 Posted May 20, 2021 Share Posted May 20, 2021 Can you provide a sample track for testing? thanks. Link to comment Share on other sites More sharing options...
Richard Branches 231 Posted May 20, 2021 Author Share Posted May 20, 2021 Sure. 1459382395_TheOffspring-ComeOutandPlay(KeepEmSeparated).flac Link to comment Share on other sites More sharing options...
Richard Branches 231 Posted May 20, 2021 Author Share Posted May 20, 2021 (edited) On 5/8/2021 at 2:55 PM, Richard Branches said: On Android Mobile everything plays directly or transcoded (depending on the upload limitation set in the server) except multichannel FLAC with the error message I shared above. The "Internet quality" in the app is set to "Auto". @Luke don't forget to pay attention to this. Thanks. Edited June 5, 2021 by Richard Branches Link to comment Share on other sites More sharing options...
Richard Branches 231 Posted May 21, 2021 Author Share Posted May 21, 2021 (edited) Please delete this comment. Edited June 11, 2021 by Richard Branches Link to comment Share on other sites More sharing options...
Richard Branches 231 Posted May 21, 2021 Author Share Posted May 21, 2021 (edited) Please delete this comment. Edited June 5, 2021 by Richard Branches Link to comment Share on other sites More sharing options...
Luke 36999 Posted May 25, 2021 Share Posted May 25, 2021 Are you still running into this? Link to comment Share on other sites More sharing options...
Richard Branches 231 Posted May 25, 2021 Author Share Posted May 25, 2021 (edited) Please delete this comment. Edited June 11, 2021 by Richard Branches Link to comment Share on other sites More sharing options...
Richard Branches 231 Posted May 26, 2021 Author Share Posted May 26, 2021 (edited) Please delete this comment. Edited June 16, 2021 by Richard Branches Link to comment Share on other sites More sharing options...
Luke 36999 Posted June 4, 2021 Share Posted June 4, 2021 On 5/20/2021 at 1:08 PM, Richard Branches said: Sure. Your browser does not support the HTML5 audio tag Can you also provide the android app log? it might be a device specific problem. Thanks. Link to comment Share on other sites More sharing options...
Richard Branches 231 Posted June 4, 2021 Author Share Posted June 4, 2021 15 minutes ago, Luke said: Can you also provide the android app log? 0195cc17-90bf-42eb-81ae-843931c6e0e8.log Link to comment Share on other sites More sharing options...
Luke 36999 Posted June 7, 2021 Share Posted June 7, 2021 On 5/20/2021 at 1:08 PM, Richard Branches said: Sure. Your browser does not support the HTML5 audio tag It appears this is not the right sample causing crashing as it's working just fine for us. Can you please attach the correct one? thanks. Link to comment Share on other sites More sharing options...
