Matthew Shrives 0 Posted November 24, 2020 Share Posted November 24, 2020 Hi Team, Recommended edit on sign in for Android TV users The sign in option using using connect on Android TV is confusing for users as the highlighted buttons are the wrong way around. Basically the highlighted buttons show up on 2 options and the non highlighted button is the actual button to select, however this is very confusing to users... It should only have 1 highlighted option only, basically whatever is highlighted is the option you select and not the other way around. Link to comment Share on other sites More sharing options...
ebr 14910 Posted November 24, 2020 Share Posted November 24, 2020 Hi. What version of the app are you running? Link to comment Share on other sites More sharing options...
