salty 0 Posted July 9, 2020 Share Posted July 9, 2020 (edited) Edit: I have found a way to get what I want. Thanks anyway Greetings! Hope you are all doing well in these tough times. I am trying to use the Emby WEB API to lookup metadata on items in my library and came across ExternalIdInfos by browsing through the swagger page but when I call the endpoint as such: curl -X GET "https://emby.domain.tld/emby/Items/8/ExternalIdInfos?api_key=<snip>" -H "accept: application/json" I get the following output: [{"Name":"IMDb","Key":"Imdb","UrlFormatString":"https://www.imdb.com/title/{0}"},{"Name":"TheMovieDb","Key":"Tmdb","UrlFormatString":"https://www.themoviedb.org/movie/{0}"},{"Name":"TheMovieDb Collection","Key":"TmdbCollection","UrlFormatString":"https://www.themoviedb.org/collection/{0}"}]% Which seems to suggest that the variables aren't getting sent out properly. Would love some help using this since it would help out with my current project and I assume that I'm not doing it wrong but if that is the case you may want to update the way swagger tells you to do it. Hope you lads can help me out, thanks in advance Edited July 9, 2020 by salty Solved Link to comment Share on other sites More sharing options...
Luke 37008 Posted July 10, 2020 Share Posted July 10, 2020 What was the solution? Link to comment Share on other sites More sharing options...
salty 0 Posted July 10, 2020 Author Share Posted July 10, 2020 I got the information I wanted from the emby/Items endpoint. Link to comment Share on other sites More sharing options...
Luke 37008 Posted July 10, 2020 Share Posted July 10, 2020 Thanks for the feedback. Link to comment Share on other sites More sharing options...
