LehighBri 19 Posted July 10, 2014 Share Posted July 10, 2014 I am using MB3 version 3.0.5289.18702 on Windows 7 64-bit and ServerWMC v1150 on Gotham 13.1. I have a couple issues related to watched status not being synced. When I watch a show in XBMC, on my one client, I see the episode is marked as watched, but then when I open another client (both are rpi's), it is showing the episode as not watched. Additionally, in MB3, I am not seeing the watched status sync (I think MB3 calls it "Played"). Thoughts on this? Isn't the watched status supposed to be in sync across everything (all XBMC clients, MB3, etc)? And if so, is it a "real-time" sync or is there some delay? This is a big use case for me as I have several clients and would like to make sure the WMC recordings status is always in sync. Link to comment Share on other sites More sharing options...
Luke 37009 Posted July 10, 2014 Share Posted July 10, 2014 It's on the roadmap. Link to comment Share on other sites More sharing options...
krustyreturns 191 Posted July 10, 2014 Share Posted July 10, 2014 You really should post the xbmc problem on the xbmc forum, as mbs and xbmc deal with the 'watched' status differently. I will check out the xbmc problem though. Link to comment Share on other sites More sharing options...
LehighBri 19 Posted July 10, 2014 Author Share Posted July 10, 2014 You really should post the xbmc problem on the xbmc forum, as mbs and xbmc deal with the 'watched' status differently. I will check out the xbmc problem though. Link to comment Share on other sites More sharing options...
LehighBri 19 Posted July 10, 2014 Author Share Posted July 10, 2014 (edited) Sure, I'll post the Xbmc issue in the xbmc forums. But glad to hear the MB3 syncing portion is on the roadmap. Edit: cross posted in the xbmc forums here: http://forum.xbmc.org/showthread.php?tid=199631 Edited July 10, 2014 by LehighBri Link to comment Share on other sites More sharing options...
