My key failed after it was reinstalled with emby
  • Please log in to reply
5 replies to this topic
#1 orangekid OFFLINE
orangekid
    Newbie
  • Members
  • 5 posts
Posted 22 May 2020 - 02:59 PM
I'm using the synology Suite
Because my hard disk is broken, I have reinstalled the DSM system of synology after replacing the hard disk
And then I reinstalled emby
After that, I input the key I bought before, and prompt me that the key is valid
But the top right corner of the server still prompts me to get the emby premiere
I can use hardware decoding function, but I can't change the server's skin and use IPTV function
How can I solve this problem
#2 Luke OFFLINE
Luke
    System Architect
  • Administrators
  • 156694 posts
  • Local time: 02:28 PM
Posted 22 May 2020 - 04:27 PM
Hi, please see if this helps:
https://support.emby...alid-or-missing
Thanks.
#3 orangekid OFFLINE
orangekid
    Newbie
  • Members
  • 5 posts
Posted 22 May 2020 - 11:17 PM
Thanks.
Hi Luke
I rechecked my key according to the link you provided
Now my server is working normally
And my emby is normal when I visit the website
But now there are new problems. I use my android app to access emby
Mobile app reminds me that I don't have emby Premiere
How to solve this problem
#4 ebr ONLINE
ebr
    Chief Bottle Washer
  • Administrators
  • 51885 posts
Posted 23 May 2020 - 10:27 AM
Hi.  Something is probably blocking the mobile app from our site to validate.  What was the solution to the problem on the server?
  • orangekid likes this
#5 orangekid OFFLINE
orangekid
    Newbie
  • Members
  • 5 posts
Posted 23 May 2020 - 02:06 PM
I deleted the key and saved it, then restarted Synology
After that I used the Server configure backup plugin to restore the previous settings
Then I enter the key and save it, my server will display normal
I didn’t change the phone or change the settings, so I am confused now that the phone cannot be activated
And I know that my key is permanent, and my client has not reached the upper limit of 25 units
#6 orangekid OFFLINE
orangekid
    Newbie
  • Members
  • 5 posts
Posted 23 May 2020 - 02:50 PM
In the latest situation, although I don’t know the reason, I went back home and connected the phone and the server to the same network, and my phone APP could be activated again.
0 user(s) are reading this topic
0 members, 0 guests, 0 anonymous users
