osak00006 12 Posted April 14, 2020 Share Posted April 14, 2020 (edited) Hi Guys, It took me a while to figure this out for myself and there are tons of threads stating that it's not possible, so I wanted to post this very, very easy solution to display Movie Extras within Kodi, while also using Emby for Kodi as your backend. 1. Setup your Emby library in Kodi using Direct Play (this doesn't currently work with playback via Add-On) 2. Install the following Official Kodi Add On: https://kodi.wiki/view/Add-on:Extras 3. Add a subfolder to your movie directory called Extras... IE /path/to/movies/moviename/extras 4. Locate the movie within Kodi and then, using the Context Menu, click on Extras which will bring up a list of all your movie Extras - If you prefer to change the name of the directory that the addon looks for, IE from Extras to "Bonus Features" you can do that from within the Add On The Extras then display within the Movie Info screen of Kodi. I don't believe you can use NFO files to customize the content, but the video files themselves all show Edited April 24, 2020 by osak00006 1 Link to comment Share on other sites More sharing options...
Luke 32487 Posted April 14, 2020 Share Posted April 14, 2020 Hi, that's great info, thanks ! Link to comment Share on other sites More sharing options...
Red5ive 29 Posted April 14, 2020 Share Posted April 14, 2020 That is indeed great news and will look to test it our for myself, I already have all my extras in a extras folder within each films folder. I was nagging @@sualfred to try and add this to embuary as a dedicated strip but if this works that saves him a job ;-) Link to comment Share on other sites More sharing options...
Red5ive 29 Posted April 14, 2020 Share Posted April 14, 2020 Installed the add-on and get the context menu but am only taken to a screen with 'search with youtube', no list of the extras. Tried updating libraries. I'm using the emby for kodi and embuary skins. Link to comment Share on other sites More sharing options...
osak00006 12 Posted April 14, 2020 Author Share Posted April 14, 2020 That's what you'd see if it doesn't find them... 1. Example folder structure? 2. Did you confirm your folder name matches what add-on is expecting? 3. Are you using direct play or add-on for Emby for Kodi setting? Link to comment Share on other sites More sharing options...
Red5ive 29 Posted April 15, 2020 Share Posted April 15, 2020 Folder structure: E:\Movies\Back To The Future (1985)\extras Folder name in add-on was Extras, changed to lowercase extras but no change. Using add-on in E4K settings. Link to comment Share on other sites More sharing options...
osak00006 12 Posted April 15, 2020 Author Share Posted April 15, 2020 (edited) E4K? I'm asking about Direct Play or AddOn Edited April 15, 2020 by osak00006 Link to comment Share on other sites More sharing options...
Red5ive 29 Posted April 15, 2020 Share Posted April 15, 2020 Sorry, meant using add-on as the setting in Emby 4 Kodi. I could try changing it to direct play but dont want to break anything else. (Not really sure what the main differences between the two are. Link to comment Share on other sites More sharing options...
osak00006 12 Posted April 15, 2020 Author Share Posted April 15, 2020 I'll test in mine and report back. In meantime,try restarting Kodi Link to comment Share on other sites More sharing options...
instantsunrise 3 Posted April 16, 2020 Share Posted April 16, 2020 I’ve tested this addon in conjunction emby, and it only works when the Emby plugin is set to Native (Direct Paths) mode. If it’s set to Add-on mode, it doesn’t work. Which is unfortunate because being able to select between different versions of the same movie only works in the Add-on mode. 1 Link to comment Share on other sites More sharing options...
idhToronto 1 Posted April 24, 2020 Share Posted April 24, 2020 HI I would like to install this add-on however it doesn't show up in my list of video add-ons to install. Ian Link to comment Share on other sites More sharing options...
osak00006 12 Posted April 24, 2020 Author Share Posted April 24, 2020 (edited) HI I would like to install this add-on however it doesn't show up in my list of video add-ons to install. Ian Where are you looking? This is a Kodi Official Add-On. It is NOT an Emby Add-On. You should be able to install it from within Kodi by following the steps below: 1 Installing To install this add-on you must do so from the Add-on manager from within Kodi by going to The home screen Add-ons Download Context Menu Extras Install Edited April 24, 2020 by osak00006 Link to comment Share on other sites More sharing options...
idhToronto 1 Posted April 24, 2020 Share Posted April 24, 2020 I am following the exact instructions you have listed. I did a search for Extras in the add-ons and it is located under Add-ons/Context menus and is called Extras - takoi 1.3.0 - is this the correct one? Link to comment Share on other sites More sharing options...
osak00006 12 Posted April 24, 2020 Author Share Posted April 24, 2020 I am following the exact instructions you have listed. I did a search for Extras in the add-ons and it is located under Add-ons/Context menus and is called Extras - takoi 1.3.0 - is this the correct one? That sounds right, as you access it via the Context Menu Link to comment Share on other sites More sharing options...
idhToronto 1 Posted April 24, 2020 Share Posted April 24, 2020 Thanks. I have been able to install and I do have folders called "Extras" - When you refer to the "Context Menu" is that the "Info screen" - If so I do not see anywhere to select Extras? Thanks Ian Link to comment Share on other sites More sharing options...
osak00006 12 Posted April 24, 2020 Author Share Posted April 24, 2020 Thanks. I have been able to install and I do have folders called "Extras" - When you refer to the "Context Menu" is that the "Info screen" - If so I do not see anywhere to select Extras? Thanks Ian The keyboard letter "C" will access the Context Menu in Kodi. It is not the same as the Info Screen. Near the bottom of the list, assuming you are within movies and have a movie selected that has Extras, will be a menu item called "Extras" Link to comment Share on other sites More sharing options...
idhToronto 1 Posted April 24, 2020 Share Posted April 24, 2020 Thanks. That helped me to understand it. I have the same issue as the previous user where the playback is the Emby for Kodi Add-on and not Direct Path. I am not prepared to reset my databaase yet so will wait until another time. Thanks Link to comment Share on other sites More sharing options...
