Plugin settings not loading
  • Please log in to reply
65 replies to this topic
#1 bbdcmf OFFLINE
bbdcmf
    Newbie
  • Members
  • 7 posts
  • Local time: 02:59 AM
Posted 22 February 2020 - 12:56 AM
I'm not sure if it has something to do with my browser settings, but it happens when I use both of my browsers, and it does not happen on my Android, but whenever I try to access the settings on any of my plugins, it will not open anything. I can uninstall the plugins just fine but the settings will not open.
I attached my logs below:
#2 Luke OFFLINE
Luke
    System Architect
  • Administrators
  • 153204 posts
  • Local time: 04:59 AM
Posted 22 February 2020 - 01:06 AM
Hi, what plugins?
#3 bbdcmf OFFLINE
bbdcmf
    Newbie
  • Members
  • 7 posts
Posted 22 February 2020 - 01:07 AM
I was trying to access IPTV, but none of my plugins settings are opening. I have all of the stock plugins and added IPTV, statistics, and album covers. None of them open
#4 Luke OFFLINE
Luke
    System Architect
  • Administrators
  • 153204 posts
Posted 22 February 2020 - 01:30 AM
Ok thanks, we'll take a look.
#5 bbdcmf OFFLINE
bbdcmf
    Newbie
  • Members
  • 7 posts
Posted 22 February 2020 - 03:16 AM
Just to keep you updated, I downgraded to a stable version and everything worked properly. Thanks for all the replies
#6 gillmacca01 OFFLINE
gillmacca01
    Advanced Member
  • Members
  • 55 posts
  • Local time: 09:59 AM
Posted 22 February 2020 - 05:18 AM
I'm running 4.4.0.16, and can confirm I am seeing the same issue
#7 floflow OFFLINE
floflow
    Newbie
  • Members
  • 1 posts
  • Local time: 03:59 AM
Posted 22 February 2020 - 07:50 AM
same here
#8 PenkethBoy OFFLINE
PenkethBoy
    Advanced Member
  • Members
  • 3941 posts
  • LocationWarrington,UK
Posted 22 February 2020 - 08:44 AM
yep seeing the same with some plugins not all
#9 Dibbes OFFLINE
Dibbes
    Advanced Member
  • Members
  • 1184 posts
  • Local time: 10:59 AM
  • LocationMadrid, Spain
Posted 22 February 2020 - 10:03 AM
yup, same... clicking on the plugins doesn't do anything, except for the ones without any settings to configure. For these you get the standard popup. Also the plugins that have a menu item work when clicking on the menu, though nothing happens when you click the image in the plugin screen
#10 Happy2Play OFFLINE
Happy2Play
    Trial and Error
  • Moderators
  • 18439 posts
  • Local time: 01:59 AM
  • LocationWashington State
Posted 22 February 2020 - 12:07 PM
Not seeing anything really in the log but get this in the Console.
router.js?v=4.4.0.16:1 Uncaught TypeError: Dashboard.allowPluginPages is not a function
    at Object.showItem (router.js?v=4.4.0.16:1)
    at executeAction (shortcuts.js?v=4.4.0.16:1)
    at HTMLDivElement.onClick (shortcuts.js?v=4.4.0.16:1)
    at HTMLDivElement.onClick (emby-itemscontainer.js?v=4.4.0.16:1)
showItem @ router.js?v=4.4.0.16:1
executeAction @ shortcuts.js?v=4.4.0.16:1
onClick @ shortcuts.js?v=4.4.0.16:1
onClick @ emby-itemscontainer.js?v=4.4.0.16:1
#11 Happy2Play OFFLINE
Happy2Play
    Trial and Error
  • Moderators
  • 18439 posts
Posted 22 February 2020 - 06:20 PM
FYI if you open the console to see the configpageurl. you can copy and paste to open the config page
example
http://localhost:8096/web/index.html#!/configurationpage?name=Emby%20Backup
Edited by Happy2Play, 22 February 2020 - 06:25 PM.
#12 benaus OFFLINE
benaus
    Advanced Member
  • Members
  • 56 posts
  • Local time: 07:29 PM
  • LocationSouth Australia
Posted 22 February 2020 - 09:44 PM
I am seeing the same issue on my current Windows Server and a new Centos 8 server
Windows Server: Emby Server 4.4.0.16
New Centos 8 Server: Emby Server 4.4.0.16
Attaching Windows and Centos server logs
EDIT: Trying to open the Server Backup plugin but it seems to be affecting all the plugin selections
Edited by benaus, 22 February 2020 - 09:45 PM.
#13 Happy2Play OFFLINE
Happy2Play
    Trial and Error
  • Moderators
  • 18439 posts
Posted 22 February 2020 - 09:59 PM
Yes this is affecting all plugin access via Plugins.  If there is a Dashboard link you can still access. examples like Playback Reporting, Reports ect or via direct url.
You should be able to access the Server Configuration Backup via direct link if needed.
http://192.168.0.175:8096/web/index.html#!/configurationpage?name=Emby%20Backup
FYI you have a outdated PeopleBackup plugin installed "Info App: Loading PeopleBackup, Version=1.1.0.0".  Current version is 1.3.3.0
#14 benaus OFFLINE
benaus
    Advanced Member
  • Members
  • 56 posts
Posted 22 February 2020 - 10:33 PM
Interesting
Just checked the Plugin Catalogue and it doesn't appear to be installed there
Don't think I have ever had to installed
When I open the plugin it asks to install and it lists version 1.3.3.0
#15 rechigo OFFLINE
rechigo
    Advanced Member
  • Members
  • 567 posts
  • LocationCALIFORNIA
Posted 23 February 2020 - 12:14 AM
I was just about to make a thread about this. I have been experiencing this since .16
Sent from my SM-G973U using Tapatalk
Edited by rechigo, 23 February 2020 - 12:16 AM.
#16 AviatorBimmer OFFLINE
AviatorBimmer
    Advanced Member
  • Members
  • 148 posts
Posted 23 February 2020 - 02:49 AM
Same issue here. Was coming to ask about this in the forums and luckily found this thread.
Same issue on Emby Server for Windows 10 version 4.4.0.16-BETA
Sent from my iPhone using Tapatalk
#17 Spaceboy OFFLINE
Spaceboy
    Advanced Member
  • Members
  • 4575 posts
Posted 23 February 2020 - 05:50 AM
Same here. I can’t access any plugin settings
#18 CBers OFFLINE
CBers
    Advanced Member
  • Moderators
  • 15739 posts
  • LocationEngland
Posted 23 February 2020 - 06:25 AM
Same here.
Server Beta v4.4.0.16.
No error message in the server log.
Happens with Emby plugins and 3rd-party plugins.
#19 CBers OFFLINE
CBers
    Advanced Member
  • Moderators
  • 15739 posts
  • LocationEngland
Posted 23 February 2020 - 07:25 AM
Same here.
Clean server log attached.
  • Spaceboy likes this
#20 CBers OFFLINE
CBers
    Advanced Member
  • Moderators
  • 15739 posts
  • LocationEngland
Posted 23 February 2020 - 04:27 PM
@Luke / @ebr
In the Chrome console:
Can this be looed at as a matter of urgency please.
See OK in the previous (.15) beta, but not this one (16).
0 user(s) are reading this topic
0 members, 0 guests, 0 anonymous users
