Issue with max simultaneous video streams
  • Please log in to reply
33 replies to this topic
#21 shocker OFFLINE
shocker
    Advanced Member
  • Members
  • 518 posts
  • Local time: 03:04 PM
Posted 24 March 2020 - 12:36 PM
@shocker have you replicated the issue without going thru the reverse proxy?
If not, let's both test that too since I can't think of much else we can do.
No, not I don’t think this is the case as the feedback from server is received. I believe that sometimes the the sessions are not updated or written to db in realtime.
But I think @Luke should know better how the mechanism works behind :)
I’ll do some testings in the upcoming days to check if it’s still present with the latest server releases
#22 Luke OFFLINE
Luke
    System Architect
  • Administrators
  • 156872 posts
  • Local time: 08:04 AM
Posted 25 March 2020 - 01:32 PM
Great, thanks.
#23 ray-finkle OFFLINE
ray-finkle
    Advanced Member
  • Members
  • 34 posts
  • Local time: 07:04 AM
Posted 27 March 2020 - 01:06 PM
Definitely still an issue in the latest release for me.
#24 Luke OFFLINE
Luke
    System Architect
  • Administrators
  • 156872 posts
Posted 27 March 2020 - 02:11 PM
What are the steps to reproduce?
#25 ray-finkle OFFLINE
ray-finkle
    Advanced Member
  • Members
  • 34 posts
Posted 27 March 2020 - 02:16 PM
Set a user to 1 stream maximum, using that account start watching a TV show, when auto playing to the next episode the error will quickly pop and disappear, failing to continue with the next episode.
It doesn't happen 100% of the time but often enough to be very annoying. So far has happened on android TV, fire TV, emby theater, web, so I assume it's global and server related.
#26 ray-finkle OFFLINE
ray-finkle
    Advanced Member
  • Members
  • 34 posts
Posted 30 March 2020 - 12:13 AM
A possibly more reliable method seems to be using the playback correction option, at least on android TV so far. Again, with a user set to 1 stream limit.
#27 shocker OFFLINE
shocker
    Advanced Member
  • Members
  • 518 posts
Posted 30 March 2020 - 04:10 AM
Tested with 4.5.0.2 yesterday and the issue is not reproduced that often I only been able to reproduce twice on web by clicking and changing the tv episode more than 80 times.
I have observed that the error appeared when the load is higher on the server and the sqlite3 is stressed on updating things for example I had a sys load average of 3.5 at 5 min by that time and the Emby response time between 0.8s to 1.4s. HDD IO was around 140MB/s out of 2000MB/s due to transcoding etc. I was thinking about if it will not be a good idea to keep the transcoding folder outside Emby, even that I have 550k IOPS I think delays are triggered on sqlite. I can add an extra hdd with slower performance something about 1500MB/s with 250k IOPS just for Emby meta and db.
I think sometimes when you are at the end of a tv episode and you press start next, something somewhere is not changed fast enough on the server side and that's why this error is triggered.
@ray-finkle are you experiencing this when your sys load is increased or all the time?
@Luke let me know if I can help with something else.
#28 ray-finkle OFFLINE
ray-finkle
    Advanced Member
  • Members
  • 34 posts
Posted 30 March 2020 - 01:04 PM
I haven't noticed anything related to system load in my setup though I can try to look into it. I transcode to memory but I also run many containers from the same appdata storage drive which is nvme.
This still seems like a bug to me that a time delay could likely fix as a simple form of fuzzy logic.
#29 shocker OFFLINE
shocker
    Advanced Member
  • Members
  • 518 posts
Posted 30 March 2020 - 01:11 PM
Agree :) I think it can be quickly fixed with my above proposal to retry again before showing the limit screen
#30 ray-finkle OFFLINE
ray-finkle
    Advanced Member
  • Members
  • 34 posts
Posted 31 March 2020 - 05:42 PM
Just confirmed that the behavior is exactly the same within the LAN and that the playback correction function replicates the problem very reliably.
#31 ray-finkle OFFLINE
ray-finkle
    Advanced Member
  • Members
  • 34 posts
Posted 02 April 2020 - 10:42 AM
Additional note:
The upcoming episode that is being force ended gets marked as played, thereby skipping episodes when resuming playback.
#32 ray-finkle OFFLINE
ray-finkle
    Advanced Member
  • Members
  • 34 posts
Posted 17 April 2020 - 06:37 PM
@Luke was anyone within Emby able to reproduce this issue?
I can provide a log with debugging enabled but I'd rather not post it publicly to the forum.
#33 Luke OFFLINE
Luke
    System Architect
  • Administrators
  • 156872 posts
Posted 06 May 2020 - 11:42 PM
Not yet. Can you please PM one to me? Thanks !
#34 ray-finkle OFFLINE
ray-finkle
    Advanced Member
  • Members
  • 34 posts
Posted 27 May 2020 - 11:04 AM
@Luke sure I will send it over now.
0 user(s) are reading this topic
0 members, 0 guests, 0 anonymous users
