diaz1510 150 Posted February 8, 2020 Share Posted February 8, 2020 (edited) While on my mobile device, I can access my emby server and watch media just fine when I'm on my home wifi network, but as soon as I am on mobile data, I can't sign in. I try to sign in with my emby connect account but it just brings me back to the screen that shows my server to select and when I select it, it gives me a connection failure error and tells me to ensure it is running and to try again. I wanted to attach logs, but the folder that is supposed to keep the logs does not exist. Using ES File Explorer I can navigate to Android/data/com.mb.android/files but under the "files" folder there is nothing...maybe it is in another location? I've even tried to manually connect to my server using the remote WAN IP address, but same connection failure error. Is there a setting on the server side I am forgetting? oh and i've tried to uninstall and reinstall the app multiple times as well...same issues each time Emby Android v3.0.97 Emby Server v4.3.1.0 Edited February 8, 2020 by diaz1510 Link to comment Share on other sites More sharing options...
Luke 36889 Posted February 8, 2020 Share Posted February 8, 2020 Hi there, I would suggest checking out our Connection Troubleshooter: https://support.emby.media/support/solutions/articles/44001849007-connectivity Please try the steps listed there and let us know which ones succeed and which ones do not. Thanks ! Link to comment Share on other sites More sharing options...
diaz1510 150 Posted February 8, 2020 Author Share Posted February 8, 2020 Doh! Looks like my port forwarding was pointing to the incorrect local IP server address...changed it and VIOLA! it works....thanks! Link to comment Share on other sites More sharing options...
Luke 36889 Posted February 8, 2020 Share Posted February 8, 2020 Thanks for the feedback. Link to comment Share on other sites More sharing options...
nikita94 0 Posted May 1, 2020 Share Posted May 1, 2020 Doh! Looks like my port forwarding was pointing to the incorrect local IP server address...changed it and VIOLA! it works....thanks! ciao riusciresti ad aiutare anche me gentilmente ? stesso problema tuo Link to comment Share on other sites More sharing options...
Luke 36889 Posted May 2, 2020 Share Posted May 2, 2020 ciao riusciresti ad aiutare anche me gentilmente ? stesso problema tuo Hi there, did you take a look at our connection troubleshooter above? Thanks. Link to comment Share on other sites More sharing options...
