Android Mobile Home Screen Won't Load
  • Please log in to reply
20 replies to this topic
#1 Sammy OFFLINE
Sammy
    Advanced Member
  • Members
  • 3508 posts
  • Local time: 10:00 PM
Posted 22 January 2020 - 09:30 PM
This is what I am getting for my primary user. Server user loads fine.
What log do you need from the mobile app? As soon as the server app finishes downloading I'll post.
Android Mobile 3.0.92
Sent from my SM-G960U1 using Tapatalk
Edited by Sammy, 24 January 2020 - 01:01 PM.
#2 Luke OFFLINE
Luke
    System Architect
  • Administrators
  • 156602 posts
  • Local time: 01:00 AM
Posted 22 January 2020 - 10:04 PM
server log?
#3 Sammy OFFLINE
Sammy
    Advanced Member
  • Members
  • 3508 posts
Posted 22 January 2020 - 10:12 PM
server log?
I'll need to repeat this when I'm on the LAN because it's not letting me download the server log remotely
#4 Sammy OFFLINE
Sammy
    Advanced Member
  • Members
  • 3508 posts
Posted 23 January 2020 - 12:44 PM
I just repeated about 8:20PDT. Here's the log.
Edited by Sammy, 24 January 2020 - 11:41 AM.
#5 Luke OFFLINE
Luke
    System Architect
  • Administrators
  • 156602 posts
Posted 23 January 2020 - 02:31 PM
There's nothing obvious here. It might just be responding slowly. You could try uninstalling the CoverArt plugin.
#6 Sammy OFFLINE
Sammy
    Advanced Member
  • Members
  • 3508 posts
Posted 23 January 2020 - 03:28 PM
Try this. I had to scrub my WAN IP from the log. Can Emby just do this automatically?
Attached File  embyserver 20200123.txt   9.87MB   4 downloads
#7 Sammy OFFLINE
Sammy
    Advanced Member
  • Members
  • 3508 posts
Posted 24 January 2020 - 11:51 AM
Update:
I changed the display theme to Apple TV and it worked great. I then tried Dark (red accent) and it worked great. I changed it back to Dark and it again worked great. Somehow, somewhere the display them was the culprit. At any rate, it works and looks great now. Any thoughts as to why @ebr @Luke ?
My bad.. This is my Server User, not the one previously posted which still has issues. Why would one work and not the other? Why does this user work fine on AndroidTV and not the Mobile App?
Edited by Sammy, 24 January 2020 - 11:57 AM.
#8 Sammy OFFLINE
Sammy
    Advanced Member
  • Members
  • 3508 posts
Posted 24 January 2020 - 12:29 PM
IDK, After playing with the Home Screen settings switching things around then back to how they were it is working again..
Edited by Sammy, 24 January 2020 - 01:33 PM.
#9 Sammy OFFLINE
Sammy
    Advanced Member
  • Members
  • 3508 posts
Posted 24 January 2020 - 01:02 PM
I notice I've been updated to 3.0.93. Coincidence?
#10 Luke OFFLINE
Luke
    System Architect
  • Administrators
  • 156602 posts
Posted 24 January 2020 - 01:41 PM
Yes.
  • Sammy likes this
#11 Sammy OFFLINE
Sammy
    Advanced Member
  • Members
  • 3508 posts
Posted 24 January 2020 - 04:58 PM
IDK but it's doing it again. This is annoying!
#12 Sammy OFFLINE
Sammy
    Advanced Member
  • Members
  • 3508 posts
Posted 24 January 2020 - 07:37 PM
I have narrowed it down to the possibility of placing My Media in the first position but I want it in the first position!
#13 Luke OFFLINE
Luke
    System Architect
  • Administrators
  • 156602 posts
Posted 24 January 2020 - 10:29 PM
Everyone has that in the first position, by default at least.
#14 Sammy OFFLINE
Sammy
    Advanced Member
  • Members
  • 3508 posts
Posted 25 January 2020 - 01:09 AM
But that's what is triggering it to not load. As soon as I take it out it loads right away.
#15 Sammy OFFLINE
Sammy
    Advanced Member
  • Members
  • 3508 posts
Posted 25 January 2020 - 11:10 AM
I've started to notice this on other clients (AndroidTV) so I think it is server related for this particular user. I run the Stable Server but Beta Android Clients. Is this an issue?
Should I report this in the Server Section?
Should I roll back the clients to stable?
#16 WilhelmStroker OFFLINE
WilhelmStroker
    Advanced Member
  • Members
  • 366 posts
  • Local time: 06:00 AM
Posted 25 January 2020 - 08:42 PM
I'm running all my android clients (3) on beta with stable server and have not seen this issue.
#17 MaMoUs OFFLINE
MaMoUs
    Member
  • Members
  • 13 posts
Posted 10 February 2020 - 06:39 PM
I'm having the same issue on my Android Phone app.
Server is in beta
app is in beta. - also tried the app in stable same issue.
#18 Luke OFFLINE
Luke
    System Architect
  • Administrators
  • 156602 posts
Posted 10 February 2020 - 07:02 PM
Server is in beta
As a test, does the workaround that Sammy mentioned earlier also resolve it for you?
#19 MaMoUs OFFLINE
MaMoUs
    Member
  • Members
  • 13 posts
Posted 10 February 2020 - 10:17 PM
Okay after some testing and looking at this I noticed if you put "My Media" and "My Media (Small)" that causes the issue
Example:
I have My Media on (1) / My Media (Small) on (6) this causes the issue. as soon as i remove either one of them it works
#20 Sammy OFFLINE
Sammy
    Advanced Member
  • Members
  • 3508 posts
Posted 10 February 2020 - 10:52 PM
Example:
Exactly what I experience too.
0 user(s) are reading this topic
0 members, 0 guests, 0 anonymous users
