Camera Upload issues with beta and Galaxy S6 Active
android camera upload video
  • Please log in to reply
18 replies to this topic
#1 Hoochee OFFLINE
Hoochee
    Advanced Member
  • Members
  • 77 posts
  • Local time: 09:33 PM
Posted 04 January 2020 - 03:32 AM
Running the beta from https://emby.media/c...oid-mobile-3088
Release notes are that video upload is supported but they aren't uploading. Also, as with the iOS camera upload (separate thread for that) I must do a little dancing around the camera upload settings checking/unchecking boxes for server and wifi only uploading to get it to upload new photos (first upload worked well on its own).
I have emby set to save to device specific directory.
#2 Luke OFFLINE
Luke
    System Architect
  • Administrators
  • 153190 posts
  • Local time: 10:33 PM
Posted 05 January 2020 - 03:08 PM
Hi there, were these recorded using the android camera app?
#3 Hoochee OFFLINE
Hoochee
    Advanced Member
  • Members
  • 77 posts
Posted 05 January 2020 - 09:02 PM
@Luke, Yes.
#4 nikc0069 OFFLINE
nikc0069
    Advanced Member
  • Members
  • 46 posts
  • Local time: 02:33 AM
Posted 13 January 2020 - 07:36 PM
Yea mine sometimes upload and sometimes dont until I jump into the camera upload menu, which then triggers the upload and the notification though this is on a Mate 20 Pro.
#5 Hoochee OFFLINE
Hoochee
    Advanced Member
  • Members
  • 77 posts
Posted 14 January 2020 - 04:27 AM
@nikc0069, you're videos are uploading?
Mine are not, just photos and to trigger the upload of new ones I must go into Camera Upload as you describe. I originally stated I needed to check/uncheck Wifi Only but have now found it will trigger just by entering the Camera Upload screen.
#6 nikc0069 OFFLINE
nikc0069
    Advanced Member
  • Members
  • 46 posts
Posted 14 January 2020 - 04:52 AM
My videos are indeed uploading. But most of the time I need to go into the camera upload settings.
#7 nikc0069 OFFLINE
nikc0069
    Advanced Member
  • Members
  • 46 posts
Posted 15 January 2020 - 06:24 PM
@Luke it looks like I'm not the only one this happens to. Are there any logs we can get you that would help?
#8 nikc0069 OFFLINE
nikc0069
    Advanced Member
  • Members
  • 46 posts
Posted 19 January 2020 - 08:55 AM
@Luke had any time to look into thie at all?
#9 Luke OFFLINE
Luke
    System Architect
  • Administrators
  • 153190 posts
Posted 20 January 2020 - 03:13 PM
Please download the latest version from the testing topic, then open up the camera upload settings screen to force the process to start, then provide an app log:
https://emby.media/c...ndroid-problem/
Thanks.
#10 nikc0069 OFFLINE
nikc0069
    Advanced Member
  • Members
  • 46 posts
Posted 20 January 2020 - 03:53 PM
Looking promising. Don't seem to have a logs folder but camera upload seems to have triggered this time. I'll wait an hour and test again.
#11 Luke OFFLINE
Luke
    System Architect
  • Administrators
  • 153190 posts
Posted 20 January 2020 - 03:57 PM
You may need to download again as I may not have had logging enabled in the one you got. Thanks.
#12 nikc0069 OFFLINE
nikc0069
    Advanced Member
  • Members
  • 46 posts
Posted 20 January 2020 - 03:59 PM
Just now downloaded 0.90 is that the one?
#13 nikc0069 OFFLINE
nikc0069
    Advanced Member
  • Members
  • 46 posts
Posted 20 January 2020 - 05:43 PM
No dice. Still need to visit the camera upload settings for anything past the first upload.
#14 nikc0069 OFFLINE
nikc0069
    Advanced Member
  • Members
  • 46 posts
Posted 21 January 2020 - 06:43 PM
Testing with powergenie disabled. First two uploads worked great. Third has not triggered yet. Will see if it's uploaded by morning.
#15 nikc0069 OFFLINE
nikc0069
    Advanced Member
  • Members
  • 46 posts
Posted 22 January 2020 - 04:17 AM
@Luke happy to report it took a while but photo uploaded. So looks like Powergenie on huawei kills the app. So you may need to contact them to ask them to whitelist the app.
#16 Luke OFFLINE
Luke
    System Architect
  • Administrators
  • 153190 posts
Posted 22 January 2020 - 09:47 AM
Thanks for the feedback.
#17 Hoochee OFFLINE
Hoochee
    Advanced Member
  • Members
  • 77 posts
Posted 23 January 2020 - 11:02 AM
@Luke, same as with nickc0069 - the upload takes a while (hours) but it eventually triggers on its own without having to enter Camera Upload; however, if I do then the upload is triggered immediately. But my videos are still not uploading. Thoughts?
#18 Luke OFFLINE
Luke
    System Architect
  • Administrators
  • 153190 posts
Posted 24 January 2020 - 05:08 PM
I'm not sure yet. Sounds like something is not allowing the periodic background process to run. It could possibly be some Samsung-specific battery saving feature.
#19 nikc0069 OFFLINE
nikc0069
    Advanced Member
  • Members
  • 46 posts
Posted 24 January 2020 - 05:11 PM
Oddly, removing Powergenie sorted mine out. But doing the same thing on my wife's mate 20 pro doesn't seem to have fixed things. Only real difference is hers is on android 9 and I am on android 10. Don't know if that's a clue?
Edited by nikc0069, 25 January 2020 - 08:29 AM.
Also tagged with one or more of these keywords: android, camera upload, video
0 user(s) are reading this topic
0 members, 0 guests, 0 anonymous users
