Happy2Play 8242 Posted March 30, 2020 Share Posted March 30, 2020 Guess i found the file that i causing the problem: https://github.com/tidusjar/Ombi/blob/master/src/Ombi.Helpers/EmbyHelper.cs Pretty sure it is do to serverid as I know EmbyStats server uses old url item/item but has serverid and still works. From browser console connectionmanager.js?v=4.4.0.40:1 Uncaught Error: item or serverId cannot be null at ConnectionManager.getApiClient (connectionmanager.js?v=4.4.0.40:1) at startDataLoad (item.js?v=4.4.0.40:1) at Object.<anonymous> (item.js?v=4.4.0.40:1) at dispatchViewEvent (viewmanager.js?v=4.4.0.40:1) at viewmanager.js?v=4.4.0.40:1 at viewcontainer-lite.js?v=4.4.0.40:1 @@Luke Have they been contacted? Link to comment Share on other sites More sharing options...
hi2hello 34 Posted March 30, 2020 Share Posted March 30, 2020 I made a code change request. From what i understand the code needs to be changed as follows to generate a valid emby URL: https://github.com/didusee/Ombi/commit/10bb22639bc880f59b7bf6b472f33f517accaf3e Please correct if you feel like that is nonsense Link to comment Share on other sites More sharing options...
Happy2Play 8242 Posted March 30, 2020 Share Posted March 30, 2020 I made a code change request. From what i understand the code needs to be changed as follows to generate a valid emby URL: https://github.com/didusee/Ombi/commit/10bb22639bc880f59b7bf6b472f33f517accaf3e Please correct if you feel like that is nonsense Luke will have to comment more, but the url is fine if you add the serverid. http://localhost:8096/web/index.html#!/item/item.html?id={mediaId}&serverId={serverId} Link to comment Share on other sites More sharing options...
hi2hello 34 Posted March 30, 2020 Share Posted March 30, 2020 (edited) If i just add the Server ID to Ombi‘s generated URL with an "&serverID" such as follows: https://myserveraddress.com/web/index.html#!/item/item.html?id=467687&serverId=… emby is still just showing a black screen! So that does not seem to work. The URL is supposed to be: https://myserveraddress.com/web/index.html#!/item?id=467687&serverId=… PS: As I already stated you than could also drop the server ID to get a valid link to the media you are looking for. Edited March 30, 2020 by hi2hello Link to comment Share on other sites More sharing options...
Happy2Play 8242 Posted March 30, 2020 Share Posted March 30, 2020 If i just add the Server ID to Ombi‘s generated URL with an "&serverID" such as follows: https://myserveraddress.com/web/index.html#!/item/item.html?id=467687&serverId=… emby is still just showing a black screen! So that does not seem to work. The URL is supposed to be: https://myserveraddress.com/web/index.html#!/item?id=467687&serverId=… PS: As I already stated you than could also drop the server ID to get a valid link to the media you are looking for. Must be a local vs Remote thing, as all local original urls work for me with serverid addition. Link to comment Share on other sites More sharing options...
hi2hello 34 Posted March 30, 2020 Share Posted March 30, 2020 (edited) For me, both URLs such as proposed are not working, neither local nor remote.Running latest Emby (4.4.0.40) under unRaid in a Docker. 123.456.0.10:port/web/index.html#!/item/item.html?id=467687&serverId=serverId=… Result: black Screen https://myserveraddress.com/web/index.html#!/item/item.html?id=467687&serverId=serverId=… Result: black Screen 123.456.0.10:port/web/index.html#!/item?id=467687&serverId=… Result: correct media shown https://myserveraddress.com/web/index.html#!/item?id=467687&serverId=… Result: correct media shown 123.456.0.10:port/web/index.html#!/item?id=467687 Result: correct media shown https://myserveraddress.com/web/index.html#!/item?id=467687 Result: correct media shown Edited March 30, 2020 by hi2hello Link to comment Share on other sites More sharing options...
Pyro2577 0 Posted March 30, 2020 Share Posted March 30, 2020 If i just add the Server ID to Ombi‘s generated URL with an "&serverID" such as follows: https://myserveraddress.com/web/index.html#!/item/item.html?id=467687&serverId=… emby is still just showing a black screen! So that does not seem to work. The URL is supposed to be: https://myserveraddress.com/web/index.html#!/item?id=467687&serverId=… PS: As I already stated you than could also drop the server ID to get a valid link to the media you are looking for. Yeah using your link also works and also adding &serverId=xxxxxxxxxxxxxxxxxxxx to the end works also. I hope he fixes it either way. Link to comment Share on other sites More sharing options...
hi2hello 34 Posted March 31, 2020 Share Posted March 31, 2020 (edited) as my suggested code change does not seem to work for both emby and jellyfin users (which is, by the way, not really surprising) I posted test results with several URL options in github under issues and hope the maintainer will fix it … Once more, concerning to my tests, adding the ServerID to the URL does not make any difference at all https://github.com/tidusjar/Ombi/issues/3455 Edited March 31, 2020 by hi2hello Link to comment Share on other sites More sharing options...
hi2hello 34 Posted March 31, 2020 Share Posted March 31, 2020 Update: the bug is fixed by the maintainer and will be released with V4 of Ombi. @@Luke and the emby crew: It would be incredibly awesome if you could comment such changes made on your side in the future a bit more visible to those who contribute with plugins and API connected apps. Thanks in andvance! Cheers! Link to comment Share on other sites More sharing options...
Luke 37007 Posted March 31, 2020 Share Posted March 31, 2020 Update: the bug is fixed by the maintainer and will be released with V4 of Ombi. @@Luke and the emby crew: It would be incredibly awesome if you could comment such changes made on your side in the future a bit more visible to those who contribute with plugins and API connected apps. Thanks in andvance! Cheers! Will do, for this one I just didn't realize it at the time. Thanks for the feedback. Link to comment Share on other sites More sharing options...
halkx 0 Posted May 25, 2020 Share Posted May 25, 2020 I am on Ombi v4 atm and cannot seem to find the location of the "view on emby" button that existed on v3...any help here? Link to comment Share on other sites More sharing options...
samuelqwe 313 Posted May 25, 2020 Share Posted May 25, 2020 I am on Ombi v4 atm and cannot seem to find the location of the "view on emby" button that existed on v3...any help here? On the detail page for whatever movie/show is available on Emby, there should be a green play button that serves as the view on Emby button. Link to comment Share on other sites More sharing options...
halkx 0 Posted May 25, 2020 Share Posted May 25, 2020 On v3 there was albeit the link was broken.... I thought t was fixed on v4 but on the details page the only green button displayed is the available one which does nothing.... maybe I should try another browser? I am on opera Link to comment Share on other sites More sharing options...
samuelqwe 313 Posted May 25, 2020 Share Posted May 25, 2020 (edited) On v3 there was albeit the link was broken.... I thought t was fixed on v4 but on the details page the only green button displayed is the available one which does nothing.... maybe I should try another browser? I am on opera The button should show right below the other social media icons. Perhaps another browser would work. EDIT: Here is the green play button I am referring to. Edited May 25, 2020 by samuelqwe Link to comment Share on other sites More sharing options...
halkx 0 Posted May 25, 2020 Share Posted May 25, 2020 Nope... doesn’t show on mine....maybe a settings issue? Or is it because I upgraded from v3? Maybe a clean install would fix this? Link to comment Share on other sites More sharing options...
halkx 0 Posted May 25, 2020 Share Posted May 25, 2020 Link to comment Share on other sites More sharing options...
samuelqwe 313 Posted May 25, 2020 Share Posted May 25, 2020 Nope... doesn’t show on mine....maybe a settings issue? Or is it because I upgraded from v3? Maybe a clean install would fix this? Before trying a clean install, I would check to see if you are on the latest version of Ombi, then verify that the Emby server settings are correct in Ombi. Link to comment Share on other sites More sharing options...
halkx 0 Posted May 25, 2020 Share Posted May 25, 2020 thanks for trying to help....I assume I am running the latest version from github.... What Emby server settings in particular should I check to see if they are correct? I have input the servers IP and port and pressed the discover server information button...then some fields populated automatically...I haven't entered anything in the externally facing hostname field because I don't have the server setup yet for outside access. Also the Base URL field is empty. Link to comment Share on other sites More sharing options...
samuelqwe 313 Posted May 25, 2020 Share Posted May 25, 2020 thanks for trying to help....I assume I am running the latest version from github.... What Emby server settings in particular should I check to see if they are correct? I have input the servers IP and port and pressed the discover server information button...then some fields populated automatically...I haven't entered anything in the externally facing hostname field because I don't have the server setup yet for outside access. Also the Base URL field is empty. If you’re able to discover the server, it should be good enough. Just curious, what version are running? I am on version 4.0.339.0, so if that’s different it may be why the button isn’t showing up. Link to comment Share on other sites More sharing options...
halkx 0 Posted May 25, 2020 Share Posted May 25, 2020 (edited) If you’re able to discover the server, it should be good enough. Just curious, what version are running? I am on version 4.0.339.0, so if that’s different it may be why the button isn’t showing up. same here... Have filed an issue on github...let's see how it goes... Edited May 25, 2020 by halkx Link to comment Share on other sites More sharing options...
samuelqwe 313 Posted May 25, 2020 Share Posted May 25, 2020 (edited) same here... Have filed an issue on github...let's see how it goes... That’s really strange. The only thing I can think of is if you didn’t check the Enable checkbox at the top of the Emby Media Server configuration page in Ombi, or if the API key is incorrectly entered. However, since you were able to test the server connection, everything should be good. Perhaps manually running the cacher could help, but hopefully GitHub can help resolve the issue. Edited May 25, 2020 by samuelqwe Link to comment Share on other sites More sharing options...
