Armbian Strech (DietPi) / Rock64Pro 4.4.0.1 playback impossible
  • Please log in to reply
6 replies to this topic
#1 maeffjus OFFLINE
maeffjus
    Advanced Member
  • Members
  • 39 posts
  • Local time: 05:44 AM
Posted 07 December 2019 - 12:21 PM
Hi Guys,
just FYI: I have updated from the 4.3.0.24 beta to the 4.4.0.1 beta.
The problem is equal than it is with the non-beta version: Whatever video-playback I try to start, the server crashes immediately.
Only the re-install of the older beta helps.
Regads,
Maeffjus
#2 Luke OFFLINE
Luke
    System Architect
  • Administrators
  • 146635 posts
  • Local time: 11:44 PM
Posted 07 December 2019 - 10:21 PM
Hi, yes we're looking into this. Thanks.
#3 JaScoMa OFFLINE
JaScoMa
    Advanced Member
  • Members
  • 178 posts
  • LocationNE Ohio
Posted 08 December 2019 - 10:29 AM
Thank you for the post.  I was going to upgrade and try the new beta as the release notes state it fixes transcoding issues.
#4 JaScoMa OFFLINE
JaScoMa
    Advanced Member
  • Members
  • 178 posts
  • LocationNE Ohio
Posted 08 December 2019 - 11:58 AM
@maeffjus
I too have the same issues.  I have both MP4 encoded and MKV direct blu-ray rips.
If I tried to play any of these movies with an audio track not supported, it crashes Emby.  If I use an audio track supported, it plays without any issues.
E.g.
MKV - TrueHD 7.1 Crashes; DD 5.1 Plays fine.
MP4 - DTS 5.1 Passthru Crashes; AAC Plays fine.
Maybe try another audio track prior to starting the movie and see if this resolves your issue.
#5 Luke OFFLINE
Luke
    System Architect
  • Administrators
  • 146635 posts
Posted 08 December 2019 - 03:23 PM
Hi, please see here if you'd like to help test a patch:
https://emby.media/c...-fine/?p=817270
Thanks !
#6 Luke OFFLINE
Luke
    System Architect
  • Administrators
  • 146635 posts
Posted 13 December 2019 - 03:32 PM
At this point both the stable and beta channels have been updated to resolve the arm64 transcoding crashes. Thanks.
#7 maeffjus OFFLINE
maeffjus
    Advanced Member
  • Members
  • 39 posts
Posted 15 December 2019 - 02:32 PM
I can confirm that it works, but it took this time about 65s until the stream started in the app. (Web still working fine)
0 user(s) are reading this topic
0 members, 0 guests, 0 anonymous users
