SEGACD32XMODEL1 0 Posted November 29, 2019 Share Posted November 29, 2019 I am having trouble accessing my Emby server from outside my network. I have opened ports on router and Windows firewall. Is it my computer not being up to specs? The computer specs: AMD Vision CPU Toshiba Satellite All Realtek Drivers Please and Thank you! Link to comment Share on other sites More sharing options...
Luke 37049 Posted November 29, 2019 Share Posted November 29, 2019 Hi there, what exactly are you trying to do, and what happens when you try to do that? Link to comment Share on other sites More sharing options...
SEGACD32XMODEL1 0 Posted November 29, 2019 Author Share Posted November 29, 2019 I am trying to access my server away from home, but the connection times out Link to comment Share on other sites More sharing options...
Luke 37049 Posted November 29, 2019 Share Posted November 29, 2019 Do you get an error message? What does it say? Link to comment Share on other sites More sharing options...
SEGACD32XMODEL1 0 Posted November 29, 2019 Author Share Posted November 29, 2019 Timed Out Message from chrome and canyouseeme.org Link to comment Share on other sites More sharing options...
Luke 37049 Posted November 29, 2019 Share Posted November 29, 2019 Ok, I would suggest checking out our Connection Troubleshooter: https://github.com/MediaBrowser/Wiki/wiki/Connectivity Please try the steps listed there and let us know which ones succeed and which ones do not. Thanks ! Link to comment Share on other sites More sharing options...
SEGACD32XMODEL1 0 Posted November 29, 2019 Author Share Posted November 29, 2019 I tested externally and with canyouseeme.org which comes with a timed out message Link to comment Share on other sites More sharing options...
Luke 37049 Posted November 29, 2019 Share Posted November 29, 2019 I tested externally and with canyouseeme.org which comes with a timed out message Yes and our document above goes through a number of things for you to check. Thanks. Link to comment Share on other sites More sharing options...
SEGACD32XMODEL1 0 Posted November 29, 2019 Author Share Posted November 29, 2019 I checked everything Link to comment Share on other sites More sharing options...
Luke 37049 Posted November 29, 2019 Share Posted November 29, 2019 What exactly did you check? Link to comment Share on other sites More sharing options...
SEGACD32XMODEL1 0 Posted November 29, 2019 Author Share Posted November 29, 2019 Test Your External Address The easiest way to test your external address, is to open it in a web browser while away from home, or inside your home using a smart phone or tablet with the wifi connection turned off. Important: Testing your external address inside your home might not work, and this is OK. Some internet routers disable loopback capabilities (going out and coming back in), therefore you might not be able to test this from inside your home network. It's important that you test away from home, or with your smart phone or tablet's wifi connection turned off. If the external address works in a browser, then you're good to go, and can proceed with connecting from Emby apps. Setup Port Forwarding If you're still unable to connect after testing the above, then you may need to setup port forwarding with your router to allow external connectivity to your Emby Server. To do this, you'll need to open the web interface for your router, and forward TCP Port 8096 on your router to port 8096 on the Emby Server machine. The process of doing this will be slightly different for each router model. Here is a good step by step guide on how to do this: http://www.wikihow.com/Set-Up-Port-Forwarding-on-a-Router This Youtube video also explains it pretty well: https://www.youtube.com/watch?v=Kp-R-eHiQco Verify Public Port To test that your public port is accessible over the internet, try testing it from canyouseeme.org If this test does not succeed, then it's an indication that your router is blocking the traffic and may need additional configuration. Link to comment Share on other sites More sharing options...
Luke 37049 Posted November 29, 2019 Share Posted November 29, 2019 And what did you find when looking at those things? Link to comment Share on other sites More sharing options...
SEGACD32XMODEL1 0 Posted November 29, 2019 Author Share Posted November 29, 2019 Every was setup right and timed out message was still there Link to comment Share on other sites More sharing options...
Luke 37049 Posted November 29, 2019 Share Posted November 29, 2019 Ok I'm trying to help you, but with each question I ask you're responding with only a couple words and not a whole lot of detail. Link to comment Share on other sites More sharing options...
SEGACD32XMODEL1 0 Posted November 30, 2019 Author Share Posted November 30, 2019 @@cayars @@Happy2Play Here is the problem: I set up everything correctly, but I cannot connect outside my network. Please Help! Link to comment Share on other sites More sharing options...
Happy2Play 8275 Posted November 30, 2019 Share Posted November 30, 2019 Are you using a vpn? Link to comment Share on other sites More sharing options...
SEGACD32XMODEL1 0 Posted November 30, 2019 Author Share Posted November 30, 2019 VPN turning off does not matter Link to comment Share on other sites More sharing options...
Happy2Play 8275 Posted November 30, 2019 Share Posted November 30, 2019 Do you have more then one router (possible double nat)? Could you be on a CGNAT from your ISP? Link to comment Share on other sites More sharing options...
Guest asrequested Posted November 30, 2019 Share Posted November 30, 2019 VPN turning off does not matter When you turned it off, did you restart the server? You need to do that so the IP gets corrected. And depending on how you implement the VPN, you may need to restart the machine. You keep saying everything is setup correctly, but obviously something isn't. You need to provide details of your configuration. If it worked before, but doesn't now, then something has changed. Has your IP changed? Maybe your router re-assigned the IP to another device. Rebooting the machine and checking the IPs is what you would need to do. Link to comment Share on other sites More sharing options...
SEGACD32XMODEL1 0 Posted November 30, 2019 Author Share Posted November 30, 2019 My Antivirus blocked the port and now I fixed that. He should put that tip on the wiki. Link to comment Share on other sites More sharing options...
Happy2Play 8275 Posted November 30, 2019 Share Posted November 30, 2019 My Antivirus blocked the port and now I fixed that. He should put that tip on the wiki. But it already does. If you're using third party firewall software, you'll need to follow it's instructions to open the port. Note: If you're using third party antivirus software such as Norton Internet Security, it will most likely have it's own firewall that will need to be configured. 1 Link to comment Share on other sites More sharing options...
