Casting from mobile to shield doesn't work well
  • Please log in to reply
34 replies to this topic
#1 Doofus OFFLINE
Doofus
    Advanced Member
  • Members
  • 13395 posts
  • Local time: 12:50 AM
Posted 25 November 2019 - 01:37 AM
Today I was at a house that has a Shield, so I tried casting to it. It connected just fine, showed the info page just fine, but anything I tried playing had problems. Some wouldn't play at all, others would freeze. The internet bandwidth was low, so I blamed that. Now that I'm home, I tried the same thing. I get the same results. Only a few movies that I tried, have played. Most won't. The movies have varying containers, varying audio and video codecs. I'm attaching the remux log for the last attempt. This just froze at the first frame.
#2 ebr OFFLINE
ebr
    Chief Bottle Washer
  • Administrators
  • 49022 posts
  • Local time: 03:50 AM
Posted 25 November 2019 - 10:28 AM
So you were casting to the Shield as a Chromecast device, as opposed to our Android TV app?
#3 Doofus OFFLINE
Doofus
    Advanced Member
  • Members
  • 13395 posts
Posted 25 November 2019 - 01:00 PM
Correct.
#4 Luke OFFLINE
Luke
    System Architect
  • Administrators
  • 146246 posts
Posted 25 November 2019 - 01:54 PM
Try lowering the Chromecast quality setting in the casting app.
#5 Doofus OFFLINE
Doofus
    Advanced Member
  • Members
  • 13395 posts
Posted 25 November 2019 - 02:03 PM
I just took a quick look at my logs for yesterday. Two of the movies that I remember playing correctly, were fully transcoded. All the others were remuxed. Which raises another question. Why would a generically encoded video (mp4, AAC, h264) need to be remuxed to play? Should that not be direct played?
#6 Luke OFFLINE
Luke
    System Architect
  • Administrators
  • 146246 posts
Posted 25 November 2019 - 09:25 PM
Did you explore your server dashboard to learn why it was transcoding?
#7 Doofus OFFLINE
Doofus
    Advanced Member
  • Members
  • 13395 posts
Posted 25 November 2019 - 10:34 PM
That's not the point. Very little will play at all. Nothing will direct play and most things are being remuxed and won't play.
#8 Doofus OFFLINE
Doofus
    Advanced Member
  • Members
  • 13395 posts
Posted 26 November 2019 - 12:01 AM
Testing this further, they will play from the beginning, but if you skip forward or use chapters, it freezes playing. No, it isn't that you need to wait for it to create a buffer, they completely freeze and the playback time continues as though it is playing. You have to press stop to exit out. Some will work ok, but a lot won't.
Does chromecast not support AAC?
aac-audiochannels=2&TranscodeReasons=AudioChannelsNotSupported
#9 Doofus OFFLINE
Doofus
    Advanced Member
  • Members
  • 13395 posts
Posted 26 November 2019 - 12:03 AM
And if it doesn't, why is the server transcoding the audio to AAC?
19:52:32.054 Stream mapping:
19:52:32.054   Stream #0:0 -> #0:0 (copy)
19:52:32.054   Stream #0:1 -> #0:1 (aac (native) -> aac (native))
#10 Doofus OFFLINE
Doofus
    Advanced Member
  • Members
  • 13395 posts
Posted 26 November 2019 - 12:12 AM
Oh I see, it's the channel count. It doesn't like 5.1 AAC. Ok, so the problem is the server remux. Chromcast doesn't seem to like seeking through it.
#11 Doofus OFFLINE
Doofus
    Advanced Member
  • Members
  • 13395 posts
Posted 27 November 2019 - 11:50 AM
So is this a Chromecast or emby issue? And while I'm here, how do you disable cinema mode for Chromecast? It's disabled in the app, but always plays with Chromecast.
#12 Luke OFFLINE
Luke
    System Architect
  • Administrators
  • 146246 posts
Posted 28 November 2019 - 11:27 AM
You're asking about the seeking?
#13 Doofus OFFLINE
Doofus
    Advanced Member
  • Members
  • 13395 posts
Posted 28 November 2019 - 01:09 PM
I'm asking about this issue in general. Have you reproduced it?
#14 Luke OFFLINE
Luke
    System Architect
  • Administrators
  • 146246 posts
Posted 08 December 2019 - 09:51 PM
Not yet. I would imagine it is content specific.
#15 Doofus OFFLINE
Doofus
    Advanced Member
  • Members
  • 13395 posts
Posted 12 December 2019 - 11:30 AM
I'll have to test more and see if I can determine a common denominator.
#16 Luke OFFLINE
Luke
    System Architect
  • Administrators
  • 146246 posts
Posted 31 December 2019 - 03:27 AM
Are you still running into this?
#17 Doofus OFFLINE
Doofus
    Advanced Member
  • Members
  • 13395 posts
Posted 06 January 2020 - 04:54 PM
Damn! I forgot to test it :D I'll try to remember tonight
#18 Doofus OFFLINE
Doofus
    Advanced Member
  • Members
  • 13395 posts
Posted 07 January 2020 - 03:15 AM
Yes, no change. The quick test I just did was to play a movie from the beginning, it played. Then choose a chapter while playing....it skipped to the chapter but doesn't play. It just freezes. Then tried playing directly by chapter, same as before, it freezes. Some movies won't even play from the beginning. Look in the log around 11:07pm, the movie is 3 Days to Kill.
Edited by Doofus, 10 January 2020 - 02:01 PM.
#19 Doofus OFFLINE
Doofus
    Advanced Member
  • Members
  • 13395 posts
Posted 08 January 2020 - 12:07 AM
Anything else you guys need? It should be very easy to reproduce.
#20 Doofus OFFLINE
Doofus
    Advanced Member
  • Members
  • 13395 posts
Posted 09 January 2020 - 05:05 PM
Anything?
0 user(s) are reading this topic
0 members, 0 guests, 0 anonymous users
