No audio on specific file
  • Please log in to reply
12 replies to this topic
#1 darkassassin07 OFFLINE
darkassassin07
    Advanced Member
  • Members
  • 876 posts
  • Local time: 10:08 AM
Posted 22 November 2019 - 12:07 AM
When trying to play my copy of Jeff Dunham: Spark of Insanity on my xbox via theater for xbox V1.1.273.70 the video plays just fine but there is no audio.
The file plays fine including audio on Emby for android, the web app on chrome (both mobile and desktop), and Externally via VLC.
It also fails to convert through emby simply displaying 'Failed' in the conversion queue with no other errors.
attached is a zip with my log files:
- I shutdown the server, then cleared the logs folder
- Started the server
- Connected with my xbox and attempted to play the media
- stopped that playback
- Connected with chrome on the server machine and played the media
- then I stoppped that and tried to convert the media using the settings 'original media folder, next to original files' 'TV' and 'Original quality'
from there I zip'd everything in the logs folder.
heres the media info as displayed by emby:
Video
Title: 480p H264
Codec: H264
Codec tag: avc1
AVC: Yes
Profile: High
Level: 30
Resolution: 720x400
Aspect ratio: 16:9
Anamorphic: No
Interlaced: No
Framerate: 29.97
Bitrate: 847 kbps
Bit depth: 8 bit
Pixel format: yuv420p
Ref frames: 1
NAL: 4
Audio
Title: Und AAC stereo (Default)
Language: und
Codec: AAC
Codec tag: mp4a
Profile: LC
Layout: stereo
Channels: 2 ch
Bitrate: 103 kbps
Sample rate: 48,000 Hz
Default: Yes
Container: mp4
Path: F:\Media\Movies\Jeff Dunham Spark Of Insanity (2007)\Jeff Dunham Spark Of Insanity (2007).mp4
On request I can pm a link to download the media file from me.
  • Attached File  test.zip   52.48KB   0 downloads
#2 Luke OFFLINE
Luke
    System Architect
  • Administrators
  • 156918 posts
  • Local time: 01:08 PM
Posted 22 November 2019 - 12:10 AM
is there a conversion log?
#3 darkassassin07 OFFLINE
darkassassin07
    Advanced Member
  • Members
  • 876 posts
Posted 22 November 2019 - 12:13 AM
No, attached is everything that showed up in the Emby-Server/programdata/logs folder
/edit pm'd you guys a dl link
Edited by darkassassin07, 22 November 2019 - 12:39 AM.
#4 Luke OFFLINE
Luke
    System Architect
  • Administrators
  • 156918 posts
Posted 22 November 2019 - 12:32 AM
@FrostByte can you try this file? Thanks!
#5 FrostByte ONLINE
FrostByte
    Advanced Member
  • ForumMod
  • 5062 posts
  • LocationThe UP
Posted 22 November 2019 - 12:47 AM
yep, I'll grab it in the morning after coffee
  • darkassassin07 likes this
#6 FrostByte ONLINE
FrostByte
    Advanced Member
  • ForumMod
  • 5062 posts
  • LocationThe UP
Posted 22 November 2019 - 09:47 AM
Same thing here.  Video plays, but no audio.  However, when I remuxed it into an mkv container I got sound.
mediainfo for original
https://pastebin.com/7tneKhFs
and remuxed using mkvtoolnix
https://pastebin.com/5YSm5b3j
Edited by FrostByte, 22 November 2019 - 09:51 AM.
#7 Guest_asrequested_* OFFLINE
Guest_asrequested_*
  • Guests
Posted 22 November 2019 - 11:19 AM
The audio bitrate changed
  • FrostByte likes this
#8 FrostByte ONLINE
FrostByte
    Advanced Member
  • ForumMod
  • 5062 posts
  • LocationThe UP
Posted 22 November 2019 - 11:41 AM
Ahh, good catch.  The bitrate of the new one is the same as the nominal bitrate of the original, but it doesn't report it as variable anymore.  Should be the exact same audio file though because it was just a remux.
#9 Guest_asrequested_* OFFLINE
Guest_asrequested_*
  • Guests
Posted 22 November 2019 - 11:45 AM
Probably a header error.
#10 FrostByte ONLINE
FrostByte
    Advanced Member
  • ForumMod
  • 5062 posts
  • LocationThe UP
Posted 22 November 2019 - 11:53 AM
Could be, I'll see if I can find an mp4 remuxer
--or just try ffmpeg I guess
Edited by FrostByte, 22 November 2019 - 11:55 AM.
#11 FrostByte ONLINE
FrostByte
    Advanced Member
  • ForumMod
  • 5062 posts
  • LocationThe UP
Posted 22 November 2019 - 12:13 PM
Another test
command used:
ffmpeg -i Jeff_Dunham_spark_of_insanity.mp4 -acodec copy -vcodec copy newvideo.mp4
https://pastebin.com/rEmbirmU
So, should just be another container swap, but using mp4 like the original this time.  The newvideo.mp4 says it's constant bitrate also just like when I remuxed it to mkv
The newvideo played just fine on my XB1X.  So that might suggest that it was a bad header in the original like @Doofus mentioned (audio is actually constant and not variable bitrate)
#12 darkassassin07 OFFLINE
darkassassin07
    Advanced Member
  • Members
  • 876 posts
Posted 22 November 2019 - 04:45 PM
So I should just use ffmpeg myself and repack this one for now?
How come embys convert feature fails?
#13 Guest_asrequested_* OFFLINE
Guest_asrequested_*
  • Guests
Posted 22 November 2019 - 05:02 PM
Just run it through mkvtoolnix. Matroska is better than crappy mp4, anyway.
0 user(s) are reading this topic
0 members, 0 guests, 0 anonymous users
