Web player not seeing Chromecast
web player chromecast cast
Best Answer Luke , 19 October 2019 - 09:47 PM
I use Opera mainly.
The requirement is in Chromium and will apply to any Chromium based browser such as Chrome or Opera.
So based on what you are doing, you should not expect to be able to access chromecast.
Go to the full post
  • Please log in to reply
15 replies to this topic
#1 speedingcheetah OFFLINE
speedingcheetah
    Advanced Member
  • Members
  • 491 posts
  • Local time: 12:08 AM
Posted 19 October 2019 - 04:23 PM
i just updated from stable version(4.2.1.0) to beta 4.3.0.15.
I notice that I can no longer use the web page player to stream to my Chromecast Ultra, and sorta...my Nvidia Shield(Chromecast built in).
It just says "Play ON" now.
It will show other instances of Emby like if i log in on other computer in FireFox, or on my phone via the Android app
If i open up and loginto the Emby on the Shield (or phone), it does then show up as a device and with that user name...
But I have no such app on the plain Chromecast...and the web app does not see it.
Phone can see and cast to it fine.
Is there a way to force a rescan/refresh of casting devices the server can detect.
I have tried restarting the server,
Edited by speedingcheetah, 19 October 2019 - 04:23 PM.
#2 Luke OFFLINE
Luke
    System Architect
  • Administrators
  • 142356 posts
  • Local time: 01:08 AM
Posted 19 October 2019 - 04:35 PM
Make sure you're using the web app either on localhost, or with https as Chromecast requires running in a secure context.
#3 speedingcheetah OFFLINE
speedingcheetah
    Advanced Member
  • Members
  • 491 posts
Posted 19 October 2019 - 04:54 PM
i have always accessed the sever via local ip addres in the url. it is using http. not https.  never been an issue before, did something change in the new version?
https does not work...i get
This site can’t provide a secure connection
192.168.0.20 sent an invalid response.
ERR_SSL_PROTOCOL_ERROR
#4 speedingcheetah OFFLINE
speedingcheetah
    Advanced Member
  • Members
  • 491 posts
Posted 19 October 2019 - 04:57 PM
O. https uses differnt port number. 8920
i change url...but i insead get
ERR_CONNECTION_RESET
In Fire fox i get
Secure Connection Failed
An error occurred during a connection to 192.168.0.20:8920. PR_END_OF_FILE_ERROR
Edited by speedingcheetah, 19 October 2019 - 04:58 PM.
#5 Luke OFFLINE
Luke
    System Architect
  • Administrators
  • 142356 posts
Posted 19 October 2019 - 09:44 PM
By local do you mean localhost, or Lan IP address? The Chrome browser started requiring a secure context for Chromecast several months ago, so probably 2-3 versions of Chrome ago.
A secure context is either localhost, or using https.
#6 Luke OFFLINE
Luke
    System Architect
  • Administrators
  • 142356 posts
Posted 19 October 2019 - 09:45 PM
In Fire fox i get
Have you setup SSL? Using SSL on the local network might not be worth the complication. What you can instead do is use our mobile android or iOS app. You'll be able to use chromecast from those without having to worry about this.
#7 speedingcheetah OFFLINE
speedingcheetah
    Advanced Member
  • Members
  • 491 posts
i use the ip address.
bookmark:
  http://192.168.0.20:...tml#!/home.html
I use Opera mainly.
Edited by speedingcheetah, 19 October 2019 - 09:46 PM.
#8 Luke OFFLINE
Luke
    System Architect
  • Administrators
  • 142356 posts
Posted 19 October 2019 - 09:47 PM   Best Answer
I use Opera mainly.
  • speedingcheetah likes this
#9 speedingcheetah OFFLINE
speedingcheetah
    Advanced Member
  • Members
  • 491 posts
Posted 19 October 2019 - 09:49 PM
I have not setup anything under Network, it is at default from isntall.
I try to enable secure connection mode, but it asks for
To enable secure connections, you will need to supply a trusted SSL certificate, such as Lets Encrypt. Please either supply a certificate, or disable secure connections.
I dont really know how to do all of that......i have messed with this kinda thing with my Ubiquiti Unifi server software to get rid of the annoying, "Not secure" page before I load the  local login page...that is https and works fine, just have to click the I know, let me load site, button. never got it to work..or u have to pay for something...
I have never been able to figure out lets encrypt etc...I dont really need to worry about https when i load the sever from my home network....
Edited by speedingcheetah, 19 October 2019 - 09:50 PM.
#10 Luke OFFLINE
Luke
    System Architect
  • Administrators
  • 142356 posts
Posted 19 October 2019 - 09:51 PM
Right, you need an SSL certificate in order to use SSL.
#11 Luke OFFLINE
Luke
    System Architect
  • Administrators
  • 142356 posts
Then either use localhost in the web app, or use the android or iOS app.
#12 speedingcheetah OFFLINE
speedingcheetah
    Advanced Member
  • Members
  • 491 posts
Posted 19 October 2019 - 09:55 PM
I guess Opera updated and this is why I now cant stream to the Chromecast...i only discovered this feature in web app last weak...only used it a few times.
I can try other browsers...FF dont see it, Edge dont......IE doesnt...so it does not appear to be a  Chrome thing.
#13 speedingcheetah OFFLINE
speedingcheetah
    Advanced Member
  • Members
  • 491 posts
Posted 19 October 2019 - 09:56 PM
what u mean? ....the ip is the accessing the local internal server port.. (In home LAN address)
doest "localhost" only work on the machine that is running the server?
Edited by speedingcheetah, 19 October 2019 - 09:56 PM.
#14 Luke OFFLINE
Luke
    System Architect
  • Administrators
  • 142356 posts
Posted 19 October 2019 - 09:57 PM
Correct.
#15 Luke OFFLINE
Luke
    System Architect
  • Administrators
  • 142356 posts
Posted 19 October 2019 - 09:58 PM
I'm just telling you your options. This is not an Emby requirement. You probably got an Opera update and they updated their internal Chromium build and now the restriction applies to Opera as well.
#16 speedingcheetah OFFLINE
speedingcheetah
    Advanced Member
  • Members
  • 491 posts
Posted 19 October 2019 - 10:01 PM
guess so...o well...was just wondering why it wasn't showing up, while other streaming devices were...thanks for the info.
Also tagged with one or more of these keywords: web player, chromecast, cast
0 user(s) are reading this topic
0 members, 0 guests, 0 anonymous users
