selected Audiostream will not be played in direc play
nvidia shield
Best Answer ebr , 12 October 2019 - 11:10 AM
Ah, yeah, the single rear channel.  Not sure why the player is reporting only 6 channels.  Maybe there actually isn't an LFE channel.
In any case, the next beta release of the app should be more forgiving in this situation and, hopefully, will allow you to switch these tracks.
Thanks.
Go to the full post
  • Please log in to reply
7 replies to this topic
#1 K1ng_Lear OFFLINE
K1ng_Lear
    Advanced Member
  • Members
  • 163 posts
  • Local time: 04:56 AM
Posted 12 October 2019 - 09:18 AM
Hi there,
I sent a report from my nvidia shield and the user was Michael.
Following Issue:
My wife reported that emby plays the wrong audiostream, german instead the selected japanese, so I tried it on my iPad but there all works fine. So I tried it on my shield and encountered the same issue. Neither the preselection of the language nor changing during the playing stream had any effect, it played only the default stream in direct play.
I thought that this effect based on the direct play and this was true. As soon as I forced a transcode the correct audiostream was played. Oh, boath audio stream are the same codec.
thx for help
#2 ebr OFFLINE
ebr
    Chief Bottle Washer
  • Administrators
  • 50827 posts
  • Local time: 10:56 PM
Posted 12 October 2019 - 10:43 AM
Hi.  The problem is the channel count doesn't match.  Our info says 7 (6.1 - whatever that is...) but the player only sees 6 (which makes a lot more sense).
Can you try refreshing the item?
@softworkz what is a 6.1 channel layout and is it possible we are discovering/reporting this incorrectly (similar to how we are incorrectly reporting mono tracks)?
#3 K1ng_Lear OFFLINE
K1ng_Lear
    Advanced Member
  • Members
  • 163 posts
Posted 12 October 2019 - 10:55 AM
Hi there,
i can give you the following answers:
1.  I tried the suggested refresh with no effect.
2. 6.1 is correct. This format has an additional speaker in the rear between rear left and right.
3.  the german stream has the same format like the Japanese one and works correct. Unfortunately i hear the German sound when I want to hear the Japanese one instead, too.
hope I could help
#4 ebr OFFLINE
ebr
    Chief Bottle Washer
  • Administrators
  • 50827 posts
Posted 12 October 2019 - 11:10 AM   Best Answer
Thanks.
  • K1ng_Lear likes this
#5 softworkz OFFLINE
softworkz
    Advanced Member
  • Developers
  • 2595 posts
Posted 13 October 2019 - 01:52 PM
ffmpeg knows three 6.1 variants:
  • FL+FR+FC+LFE+BC+SL+SR => Back-Center, Side-Left, Side-Right
  • FL+FR+FC+LFE+BL+BR+BC => Back-Center, Back-Left, Back-Right
  • FL+FR+LFE+FLC+FRC+SL+SR => No Front-Center but Front-Right-Center, Front-Left-Center
For the discovery, I would need to check with a media sample.
#6 Doofus OFFLINE
Doofus
    Advanced Member
  • Members
  • 13712 posts
  • Local time: 07:56 PM
Posted 14 October 2019 - 01:39 AM
My 6.1 stuff is read correctly.
Audio
Format                                   : DTS ES XXCH
Format/Info                              : Digital Theater Systems
Commercial name                          : DTS-ES Discrete
Codec ID                                 : A_DTS
Duration                                 : 2 h 4 min
Bit rate mode                            : Constant
Bit rate                                 : 1 509 kb/s
Channel(s)                               : 6 channels
Channel(s)_Original                      : 7 channels
Channel layout                           : C L R Ls Rs Cb LFE
Sampling rate                            : 48.0 kHz
Frame rate                               : 93.750 FPS (512 SPF)
Bit depth                                : 24 bits
#7 K1ng_Lear OFFLINE
K1ng_Lear
    Advanced Member
  • Members
  • 163 posts
Posted 17 October 2019 - 11:08 AM
Hi there,
sorry for the late response but I was on a business trip and couldn’t test it. My issue is solved with the beta release 1.7.56
thx for helping.
Edited by K1ng_Lear, 17 October 2019 - 11:10 AM.
#8 Luke OFFLINE
Luke
    System Architect
  • Administrators
  • 153190 posts
Posted 17 October 2019 - 12:06 PM
Thanks for the feedback.
Also tagged with one or more of these keywords: nvidia shield
0 user(s) are reading this topic
0 members, 0 guests, 0 anonymous users
