EduardoSantos 40 Posted September 26, 2019 Share Posted September 26, 2019 Dear sirs, I do not know if this is by design of if it is a bug. This has been there for several versions and updates. Facts are I fail to understand how this is supposed to work. When casting to Chromecast this is what is shown when I try to control Emby's volume: And it seems to be a mess. When one tries the first slider the second one moves, seemingly on a random manner.Also when phone is locked I can't control volume using buttons. Any info on this would be great. Link to comment Share on other sites More sharing options...
Luke 37050 Posted September 26, 2019 Share Posted September 26, 2019 What is the problem? Link to comment Share on other sites More sharing options...
EduardoSantos 40 Posted September 26, 2019 Author Share Posted September 26, 2019 Problems are: - there are two Emby volume sliders with inconsistent results; - hard volume buttons will not work when phone is locked Link to comment Share on other sites More sharing options...
EduardoSantos 40 Posted September 30, 2019 Author Share Posted September 30, 2019 I fear I was not clear enough. AFAIK Emby is the only Android app showing two volume sliders. The sliders seems to relate to GoogleHome app and the actual Emby app. But if volume is controled by the GoogleHome app, Emby slider will not move. Also when trying to control volume on Emby app, then the GoogleHome volume sometimes will not move. This leads to various scenarios when one slider changes the other. Link to comment Share on other sites More sharing options...
Luke 37050 Posted October 26, 2019 Share Posted October 26, 2019 Are you still running into this? Link to comment Share on other sites More sharing options...
EduardoSantos 40 Posted October 28, 2019 Author Share Posted October 28, 2019 As I changed my whole setup I did not came to this again. I will prepair a scenario and check it. Link to comment Share on other sites More sharing options...
Luke 37050 Posted November 5, 2019 Share Posted November 5, 2019 Great, thanks ! Link to comment Share on other sites More sharing options...
