Problems with delete
  • Please log in to reply
25 replies to this topic
#1 rykr OFFLINE
rykr
    Advanced Member
  • Members
  • 143 posts
  • Local time: 11:52 AM
Posted 22 September 2019 - 10:28 AM
This may be a problem with the web app but I see the same thing from the android app.
When I go to delete something from the recordings view I very often see an immediate dialog that says "this is taking longer than is expected".   Don't really understand why that comes up IMMEDIATELY.   But the delete usually does take longer than is expected.  it's a simple delete but it often takes quite a few seconds.
And the web app almost never correctly updates.  if I refresh the page you can see the thing is gone but I shouldn't have to refresh the page to see that.   I've actually sometimes gone and used Plex (they are looking at the same dvr folder) to delete recordings since it does it instantly and refreshes the web app.
Just one of those few remaining niggles that keeps Emby from being really good.
#2 ebr OFFLINE
ebr
    Chief Bottle Washer
  • Administrators
  • 51903 posts
  • Local time: 12:52 PM
Posted 22 September 2019 - 10:54 AM
You must be talking about Android TV.  If it takes more than 1/2 second for the server to respond, then you get that dialog so you know it is working on it.  The dialog disappears and the screen updates, correct?
#3 rykr OFFLINE
rykr
    Advanced Member
  • Members
  • 143 posts
Posted 22 September 2019 - 04:59 PM
I think there are lots of problems with delete.   Here is a screen capture I took just now deleting an NFL game.  As you can see I choose delete and NOTHING visually happens.  This is the web app in Chrome.   After some time I do a refresh and the game is indeed gone.  I just took another video on my phone showing some weird behavior with the timecode on playback. I'll start a new thread for that.
Edited by rykr, 22 September 2019 - 04:59 PM.
#4 Happy2Play OFFLINE
Happy2Play
    Trial and Error
  • Moderators
  • 19127 posts
  • Local time: 09:52 AM
  • LocationWashington State
Posted 22 September 2019 - 05:11 PM
Depending on the screen you are deleting from yes there is/can be a refresh issues that requires a manual refresh.  But the item is deleted ever though the page has not refreshed.
Edited by Happy2Play, 22 September 2019 - 05:12 PM.
#5 rykr OFFLINE
rykr
    Advanced Member
  • Members
  • 143 posts
Posted 22 September 2019 - 05:12 PM
But you would agree that's a bug which is why I'm reporting it.
#6 Happy2Play OFFLINE
Happy2Play
    Trial and Error
  • Moderators
  • 19127 posts
Posted 22 September 2019 - 05:20 PM
To me from a browser perspective you will run into these issues across the board.  Almost every action would.could require a total refresh, so should it be forced or happen naturally with other user actions.  To me there is never a clear answer and everyone expects something different.  But only Luke can truly answer if it is by design or a bug.
#7 Luke OFFLINE
Luke
    System Architect
  • Administrators
  • 156731 posts
Posted 22 September 2019 - 05:29 PM
What screen did you delete from?
#8 Happy2Play OFFLINE
Happy2Play
    Trial and Error
  • Moderators
  • 19127 posts
Posted 22 September 2019 - 05:32 PM
Would appear to be the Seasons episode list shown in the video.
Edited by Happy2Play, 22 September 2019 - 05:33 PM.
#9 Luke OFFLINE
Luke
    System Architect
  • Administrators
  • 156731 posts
Posted 22 September 2019 - 05:33 PM
It's just not refreshing after the delete. The can be easily resolved. Thanks.
#10 rykr OFFLINE
rykr
    Advanced Member
  • Members
  • 143 posts
Posted 22 September 2019 - 05:34 PM
It *could* be by design but I highly doubt it.  Not trying to start anything but Plex does it right.  The file is deleted and the screen updated quickly and automatically.
  please note that there are other areas where delete does this type of thing. I just took a video of a delete taking a long time on my shield.
#11 rykr OFFLINE
rykr
    Advanced Member
  • Members
  • 143 posts
Posted 22 September 2019 - 05:37 PM
I apologize in advance.  I want Emby to be better than Plex so I intend to post *alot* about the issues I see.  Again, I apologize in advance. :)
  • maegibbons likes this
#12 vaise OFFLINE
vaise
    Advanced Member
  • Members
  • 1213 posts
  • Local time: 02:52 AM
Posted 22 September 2019 - 08:08 PM
I get this on every delete from my recorded TV on ShieldTV.
Its no biggie, gets there in the end....
#13 Luke OFFLINE
Luke
    System Architect
  • Administrators
  • 156731 posts
Posted 22 September 2019 - 08:39 PM
Thanks for the feedback.
#14 ebr OFFLINE
ebr
    Chief Bottle Washer
  • Administrators
  • 51903 posts
Posted 23 September 2019 - 10:43 AM
You get what on every delete from your Shield?
#15 vaise OFFLINE
vaise
    Advanced Member
  • Members
  • 1213 posts
Posted 23 September 2019 - 07:08 PM
Exactly what the op posted - "this is taking longer than is expected"
#16 Luke OFFLINE
Luke
    System Architect
  • Administrators
  • 156731 posts
Posted 24 September 2019 - 01:02 AM
Please attach the emby server log from when this happened. Thanks.
#17 vaise OFFLINE
vaise
    Advanced Member
  • Members
  • 1213 posts
Posted 24 September 2019 - 02:56 AM
It does not bother me - I am talking a few seconds here - but starnge the message comes up so quickly.
2019-09-24 16:48:08.383 Info HttpServer: HTTP Response 200 to 192.168.1.31. Time: 3ms. http://192.168.1.200...nfo?format=json
2019-09-24 16:48:08.397 Info HttpServer: HTTP GET http://192.168.1.200...516&format=json. UserAgent: Dalvik/2.1.0 (Linux; U; Android 9; SHIELD Android TV Build/PPR1.180610.011)
2019-09-24 16:48:08.399 Info HttpServer: HTTP Response 200 to 192.168.1.31. Time: 2ms. http://192.168.1.200...516&format=json
2019-09-24 16:48:12.194 Info HttpServer: HTTP DELETE http://192.168.1.200...by/Items/519852. UserAgent: Dalvik/2.1.0 (Linux; U; Android 9; SHIELD Android TV Build/PPR1.180610.011)
2019-09-24 16:48:12.196 Info App: Removing item from database, Type: Episode, Name: 2019 - Pressure Building, Path: /mnt/user/EmbyRecordings/The Block (2003)/Season 15/The Block S15E30 2019 - Pressure Building.ts, Id: 519852
2019-09-24 16:48:12.196 Info App: Deleting path /config/metadata/library/c6/c69d394e43506cde41c692b9ee96b694
2019-09-24 16:48:12.198 Info App: Deleting path /mnt/user/EmbyRecordings/The Block (2003)/Season 15/The Block S15E30 2019 - Pressure Building.ts
2019-09-24 16:48:22.060 Info App: Deleting path /mnt/user/EmbyRecordings/The Block (2003)/Season 15/The Block S15E30 2019 - Pressure Building.nfo
2019-09-24 16:48:22.061 Info App: Deleting path /mnt/user/EmbyRecordings/The Block (2003)/Season 15/The Block S15E30 2019 - Pressure Building-320-10.bif
2019-09-24 16:48:22.118 Info HttpServer: HTTP Response 204 to 192.168.1.31. Time: 9924ms. http://192.168.1.200...by/Items/519852
2019-09-24 16:48:22.190 Info HttpServer: HTTP GET http://192.168.1.200...852?format=json. UserAgent: Dalvik/2.1.0 (Linux; U; Android 9; SHIELD Android TV Build/PPR1.180610.011)
2019-09-24 16:48:22.192 Error HttpServer: Error processing request
*** Error Report ***
Version: 4.3.0.9
Command line: /system/EmbyServer.dll -programdata /config -ffdetect /bin/ffdetect -ffmpeg /bin/ffmpeg -ffprobe /bin/ffprobe -restartexitcode 3
Operating system: Unix 4.19.55.0
64-Bit OS: True
64-Bit Process: True
User Interactive: True
Runtime: file:///system/System.Private.CoreLib.dll
Processor count: 16
Program data path: /config
Application directory: /system
System.NullReferenceException: System.NullReferenceException: Object reference not set to an instance of an object.
   at Emby.Server.Implementations.Dto.DtoService.AttachPeople(BaseItemDto dto, BaseItem item, DtoOptions options)
   at Emby.Server.Implementations.Dto.DtoService.GetBaseItemDtoInternal(BaseItem item, DtoOptions options, User user)
   at Emby.Server.Implementations.Dto.DtoService.GetBaseItemDto(BaseItem item, DtoOptions options, User user)
   at MediaBrowser.Api.UserLibrary.UserLibraryService.Get(GetItem request)
   at Emby.Server.Implementations.Services.ServiceController.GetTaskResult(Task task)
   at Emby.Server.Implementations.Services.ServiceHandler.ProcessRequestAsync(HttpListenerHost appHost, IRequest httpReq, IResponse httpRes, RestPath restPath, String responseContentType, CancellationToken cancellationToken)
   at Emby.Server.Implementations.HttpServer.HttpListenerHost.RequestHandler(IRequest httpReq, ReadOnlyMemory`1 urlString, ReadOnlyMemory`1 host, ReadOnlyMemory`1 localPath, CancellationToken cancellationToken)
Source: Emby.Server.Implementations
TargetSite: Void AttachPeople(MediaBrowser.Model.Dto.BaseItemDto, MediaBrowser.Controller.Entities.BaseItem, MediaBrowser.Controller.Dto.DtoOptions)
2019-09-24 16:48:22.192 Info HttpServer: HTTP Response 500 to 192.168.1.31. Time: 2ms. http://192.168.1.200...852?format=json
#18 ebr OFFLINE
ebr
    Chief Bottle Washer
  • Administrators
  • 51903 posts
Posted 24 September 2019 - 09:57 AM
Okay, so the app is giving you visual feedback that something is happening.
That dialog disappears and the item deletes and disappears from the interface, correct?
Why are you guys thinking that is a problem...?
#19 rykr OFFLINE
rykr
    Advanced Member
  • Members
  • 143 posts
Posted 24 September 2019 - 10:17 AM
1.  The delete should be very quick if not nearly instant . It is not.  It very often takes 4-5 seconds
2.  The delete very rarely updates the screen.  Normally I have to exit the area and come back in before I see visual evidence that the item is gone
3.  A dialog that shows _immediately_ upon selecting delete that something is taking longer than expected is simply bad user experience.   If the delete takes longer than 2 seconds I would say then the dialog is warranted.  It shows instantly.
It is most definitely a bug. You may not want to fix it but it is a bug.  This is not about what we can live with.  It's about making Emby a truly quality product.
#20 ebr OFFLINE
ebr
    Chief Bottle Washer
  • Administrators
  • 51903 posts
Posted 24 September 2019 - 10:24 AM
I cannot reproduce that in the Android TV app.  The screen is always updated for me.
Can you explain an exact scenario where this happens to you in the Android TV app?
Thanks.
0 user(s) are reading this topic
0 members, 0 guests, 0 anonymous users
