Collections - again!
Collections AutoBoxSets
Best Answer Luke , 03 September 2019 - 02:19 AM
Did you copy a database file from another server installation, or something along those lines?
2019-09-03 15:34:06.365 Error BaseItem: Error refreshing owned items for C:\Users\Paul\AppData\Roaming\Emby-Server\programdata\data\collections
	*** Error Report ***
	Version: 4.3.0.6
	Command line: C:\Users\jordy\AppData\Roaming\Emby-Server\system\EmbyServer.dll -noautorunwebapp
	Operating system: Microsoft Windows NT 6.2.9200.0
	64-Bit OS: True
	64-Bit Process: True
	User Interactive: True
	Runtime: file:///C:/Users/jordy/AppData/Roaming/Emby-Server/system/System.Private.CoreLib.dll
	Processor count: 16
	Program data path: C:\Users\jordy\AppData\Roaming\Emby-Server\programdata
	Application directory: C:\Users\jordy\AppData\Roaming\Emby-Server\system
	System.IO.DirectoryNotFoundException: System.IO.DirectoryNotFoundException: Could not find a part of the path 'C:\Users\Paul\AppData\Roaming\Emby-Server\programdata\data\collections'.
Go to the full post
  • Please log in to reply
4 replies to this topic
#1 jordy OFFLINE
jordy
    Advanced Member
  • Members
  • 1430 posts
  • Local time: 03:35 AM
  • LocationAdelaide, Australia
Posted 03 September 2019 - 02:15 AM
Hey @Luke,
I have more issues with AutoBoxSets on Beta 4.3.0.6.
AutoBoxSets will not create a new Collection/Boxset. Example - I have just started adding the Fast & Furious movies. When running the plugin, it does not create a boxset/Collection for them, It creates successive "Collections" folders under the "AppData\Roaming\Emby-Server\programdata\root\default" folder. These Collections folders only contain an "Options.xml" file. These Collections folders are also appearing on the Homescreen
I cannot create a manual Collection either - Select Movie (single or multiple) - add to Collection - New - does not create a Collection. Selecting "Search the Internet for Artwork..." and pressing "Okay" results in a never ending spinner.
See attached images & server log
thanks
Edited by jordy, 03 September 2019 - 02:20 AM.
#2 Luke OFFLINE
Luke
    System Architect
  • Administrators
  • 157215 posts
  • Local time: 02:05 PM
Posted 03 September 2019 - 02:18 AM
Hi there, have you read the AutoBoxSets wiki article to learn what is required for it?
#3 Luke OFFLINE
Luke
    System Architect
  • Administrators
  • 157215 posts
Posted 03 September 2019 - 02:19 AM   Best Answer
	Version: 4.3.0.6
	64-Bit OS: True
	Processor count: 16
  • ebr likes this
#4 jordy OFFLINE
jordy
    Advanced Member
  • Members
  • 1430 posts
Posted 03 September 2019 - 02:25 AM
	Version: 4.3.0.6
	64-Bit OS: True
	Processor count: 16
Actually, yes I did. built a new pc and just copied the "Emby-Server" folder to the new one.. So I need to re-create the db?
EDIT: everything else works just fine.
Edited by jordy, 03 September 2019 - 02:28 AM.
#5 jordy OFFLINE
jordy
    Advanced Member
  • Members
  • 1430 posts
Posted 03 September 2019 - 03:51 AM
@Luke, re-created db and it's all good :D
Thanks. I'll know not to do that again ;)
Edited by jordy, 03 September 2019 - 03:52 AM.
Also tagged with one or more of these keywords: Collections, AutoBoxSets
0 user(s) are reading this topic
0 members, 0 guests, 0 anonymous users
