RobbyBobby 9 Posted August 22, 2019 Share Posted August 22, 2019 As per Topic Title. I’m running Emby 4.2.1.0 on Mac, using Emby Guide Data. I have tried a manual refresh. Many thanks. Link to post Share on other sites
Luke 25799 Posted August 22, 2019 Share Posted August 22, 2019 Hi, what guide data source are you using? Link to post Share on other sites
RobbyBobby 9 Posted August 22, 2019 Author Share Posted August 22, 2019 Freeview - Cable (South) Link to post Share on other sites
RobbyBobby 9 Posted August 22, 2019 Author Share Posted August 22, 2019 Hi Luke i’ve been doing some research and although True Movies has been on channel 62, it now appears to be on channel 50. So... I think I’ve disturbed you unnecessarily. Not sure why it’s listed twice like that on the HD Homerun Quatro channel Lineup. Thank you very much for the prompt response. Link to post Share on other sites
Luke 25799 Posted August 23, 2019 Share Posted August 23, 2019 Thanks for the feedback. Link to post Share on other sites
RobbyBobby 9 Posted August 23, 2019 Author Share Posted August 23, 2019 In case anyone else has a problem with the two "True" channels in the UK vanishing, i.e. True Entertainment and True Movies, my understanding is that Sony is reorganising its free to air channels, and these have both been moved off Freeview national coverage and onto what is described as a local multiplex. If your transmitter doesn't support these channels locally, which I guess is based on catchment area(?), then you are now out of luck. Link to post Share on other sites
Luke 25799 Posted August 24, 2019 Share Posted August 24, 2019 Interesting, thanks for the info. Link to post Share on other sites
