Headfritz 7 Posted August 17, 2019 Share Posted August 17, 2019 I was Just wondering if the Costume intro path for cinema Mode has been disabled. I know from the past it was causing me trouble with trails playing before each movie, Which has been fixed, so I was wondering if it had been disabled until it can do fixed or is just broken, sort of to speak. I have the Intro pathed put in, but it dose not seem to be working. The trailers do play but not the custom intro. I believe all my setting are correct. If it has been disabled until it can be fixed, that's fine I was just checking in. Link to comment Share on other sites More sharing options...
Luke 36886 Posted August 17, 2019 Share Posted August 17, 2019 Hi, no it hasn't. The option is still there. Did you make sure to run a library scan after configuring it? Link to comment Share on other sites More sharing options...
Headfritz 7 Posted August 17, 2019 Author Share Posted August 17, 2019 Yes, ran it a couple of times. I have undone the link, then scanned the libraries, then restarted the server. Relinked then ran a library scan, them restated the server. still doesn't work. So when you hit plan a trailer will play, then the movie starts. What I would like to happen is, You hit play, a cartoon plays, then a trailer, (or vise versa) and then the movie. Right now that is not happening, just the trailer iplay and then the movie. Link to comment Share on other sites More sharing options...
Luke 36886 Posted August 17, 2019 Share Posted August 17, 2019 How did you configure cinema mode? Link to comment Share on other sites More sharing options...
Headfritz 7 Posted August 17, 2019 Author Share Posted August 17, 2019 Here you go. Link to comment Share on other sites More sharing options...
ebr 14862 Posted August 18, 2019 Share Posted August 18, 2019 Is that path you put in actually correct? To be so, you would have to have a 'volume1' directory off the root of the drive Emby is installed on. Did you maybe mean '//volume1...'? Link to comment Share on other sites More sharing options...
Headfritz 7 Posted August 18, 2019 Author Share Posted August 18, 2019 The path was done thought the select directory. So the single "/volume1..." was thought that section process. I did go back and change it to "//Volume1...." but it still did work. I've attached the log to see if that will help you. embyserver.txt Link to comment Share on other sites More sharing options...
ebr 14862 Posted August 20, 2019 Share Posted August 20, 2019 If you navigate to that folder in Windows Explorer, what shows in the path line? Never mind you are not on Windows. However, this does appear to be an OS access issue: System.UnauthorizedAccessException: Access to the path '/volume1/Cartoon Trailers/#recycle' is denied. ---> System.IO.IOException: Permission denied Link to comment Share on other sites More sharing options...
Headfritz 7 Posted August 20, 2019 Author Share Posted August 20, 2019 So, What dose this mean? Is it something on my end that I can fix? Also why would it deny permission and not deny it for the Movies folder let say? Link to comment Share on other sites More sharing options...
ebr 14862 Posted August 21, 2019 Share Posted August 21, 2019 Luke - is this possibly related to the new recycle bin feature on MacOS? Link to comment Share on other sites More sharing options...
Luke 36886 Posted August 23, 2019 Share Posted August 23, 2019 No, it's due to a permsisions problem trying to get the contents of the custom intros folder. Link to comment Share on other sites More sharing options...
ebr 14862 Posted August 23, 2019 Share Posted August 23, 2019 Okay, so '#recycle' is some sort of system folder inside there that the user may not be able to give proper permissions for? Link to comment Share on other sites More sharing options...
Headfritz 7 Posted August 23, 2019 Author Share Posted August 23, 2019 My folder is on a NAS and I've checked the permission against the movie folder and they are set correctly. I took the extra step and made a new folder and moved everything to the new folder and link the path to it. Didn't work. I'm using a Synology NAS if that helps any. I've doubled checked the permission and they seem ok, I can go back and check again, but they are set the same as my movie library folder. Could it be the naming of the folder that's the issue? Right now I believe I have it labeled as Cartoons Movies. Link to comment Share on other sites More sharing options...
Headfritz 7 Posted August 29, 2019 Author Share Posted August 29, 2019 Could the denial of access be due to my NAS see the request from cinema plug in and not from Emby server? Link to comment Share on other sites More sharing options...
Luke 36886 Posted November 4, 2019 Share Posted November 4, 2019 @@Headfritz, where do these #recycle folders get created? is it one in every single folder, or just one at the top of the mount? Link to comment Share on other sites More sharing options...
Headfritz 7 Posted November 5, 2019 Author Share Posted November 5, 2019 The #recycle fold was created by the NAS. There should only be one #recycle folders in the Mounted folder. All sub-folders should not have a #recycle folder in them. Link to comment Share on other sites More sharing options...
Happy2Play 8144 Posted November 5, 2019 Share Posted November 5, 2019 (edited) Looks like there will be the same issue with these system #recycle folders as we had with folders that begin with a period. It would appear there is a option to disable the recycle bin on the share or change the permissions, but permissions will cause Emby to read the files in the recycle bin also. Would appear the recycle folder is created on the share. https://www.synology.com/en-global/knowledgebase/DSM/help/DSM/AdminCenter/file_share_recycle Edited November 5, 2019 by Happy2Play Link to comment Share on other sites More sharing options...
Luke 36886 Posted November 27, 2019 Share Posted November 27, 2019 I'm not sure it will make a difference, but please let me know how Emby Server 4.3 compares. Thanks ! Link to comment Share on other sites More sharing options...
Headfritz 7 Posted November 28, 2019 Author Share Posted November 28, 2019 I've updated the server and still the same. Would it make any difference if I deleted the recycle folder? Link to comment Share on other sites More sharing options...
Luke 36886 Posted November 29, 2019 Share Posted November 29, 2019 That would be a workaround for now yes. Please let us know how that goes. Thanks. Link to comment Share on other sites More sharing options...
Headfritz 7 Posted November 30, 2019 Author Share Posted November 30, 2019 Hey Luke, I deleted the recycling folder and that did seem to work. Now cartoons will play after the trail. Link to comment Share on other sites More sharing options...
Luke 36886 Posted December 1, 2019 Share Posted December 1, 2019 Thanks for the feedback. Link to comment Share on other sites More sharing options...
