4.2.0.32 Manual recording stopped unexpectedly after 1 minute
livetv dvr
  • Please log in to reply
1 reply to this topic
#1 ProperlyFormattedDataFile OFFLINE
    Advanced Member
  • Members
  • 72 posts
  • Local time: 11:58 AM
Posted 21 July 2019 - 11:15 AM
Last night I tried recording an episode manually by clicking the record button in the UI on the Roku app to a 4.2.0.32 server on Linux with an HD Homerun.  I then exited emby I believe by pressing the home button on the Roku remote, though I'm not 100% sure.  When I came back to play the episode, it had only recorded for about a minute before stopping.  So far, this hasn't seemed to happen with regularly scheduled recordings on 4.2.0.32, but I haven't recorded much since upgrading to this version.
2019-07-20 21:21:39.231 Info LiveTV: Will record to /usr/local/data/recordings/Press Your Luck (1983)/Season 1/Press Your Luck S01E03 107.ts for 39.3461486233333 minutes.
2019-07-20 21:21:40.097 Info LiveTV: Triggering refresh on /usr/local/data/recordings/Press Your Luck (1983)/Season 1/Press Your Luck S01E03 107.ts
2019-07-20 21:21:40.100 Info LiveTV: Refreshing recording parent /usr/local/data/recordings
2019-07-20 21:21:40.100 Info LiveTV: Copying recording stream to file /usr/local/data/recordings/Press Your Luck (1983)/Season 1/Press Your Luck S01E03 107.ts
2019-07-20 21:22:40.070 Info LibraryMonitor: Press Your Luck (/usr/local/data/recordings/Press Your Luck (1983)) will be refreshed.
2019-07-20 21:22:40.070 Info LibraryMonitor: Season 1 (/usr/local/data/recordings/Press Your Luck (1983)/Season 1) will be refreshed.
2019-07-20 21:22:41.475 Info App: Transcoding kill timer stopped for JobId ca8a9864-5328-4265-ae68-5e13f3d503b6 PlaySessionId 897950026adf451ba9821f5ce08f5c73. Killing transcoding
2019-07-20 21:22:41.475 Info App: ProcessRun 'StreamTranscode ca8a98': Stopping ffmpeg process with q command for /var/lib/emby/transcoding-temp/cd375f3e0a8bfc932e920569127ebd420.ts
2019-07-20 21:22:41.670 Info HttpServer: SocketException: http://127.0.0.1:809...1ad58/stream.ts
2019-07-20 21:22:41.670 Info HttpServer: HTTP Response 200 to 127.0.0.1. Time: 1311987ms. http://127.0.0.1:809...1ad58/stream.ts
2019-07-20 21:22:41.728 Info App: ProcessRun 'StreamTranscode ca8a98' Process exited with code 0
2019-07-20 21:22:41.728 Info App: FFMpeg exited with code 0
2019-07-20 21:22:41.728 Info App: Deleting partial stream file(s) /var/lib/emby/transcoding-temp/cd375f3e0a8bfc932e920569127ebd42.m3u8
2019-07-20 21:22:41.729 Info MediaSourceManager: Live stream native_9098a73d5f0a41a094a99f31435d5a51_0cad33e7094290eb2e02437d2bfd39ed consumer count is now 1
2019-07-20 21:22:42.247 Info SessionManager: Session fdd45606b489811d169ebdd17c1c66c4 has gone idle while playing
2019-07-20 21:22:42.247 Info SessionManager: Playback stopped reported by app Roku SG 3.0.175 playing WABC-HD. Stopped at 1362000 ms
2019-07-20 21:22:42.248 Info MediaSourceManager: Live stream native_9098a73d5f0a41a094a99f31435d5a51_0cad33e7094290eb2e02437d2bfd39ed consumer count is now 0
2019-07-20 21:22:42.248 Info MediaSourceManager: Closing live stream 06044cf0e6f93cdae5f285c9ecfaaeb4_01413a525b3a9622ce6fdf19f7dde354_native_9098a73d5f0a41a094a99f31435d5a51_0cad33e7094290eb2e02437d2bfd39ed
2019-07-20 21:22:42.248 Info SharedHttpPipelineSource: Closing SharedHttpPipelineSource
2019-07-20 21:22:42.252 Info SharedHttpPipelineSource: SharedHttpPipelineSource is done streaming.
2019-07-20 21:22:42.252 Info SharedHttpPipelineSource: Deleting temp files /var/lib/emby/transcoding-temp/fa804516903b47aea984b0a173c1ad58.ts
2019-07-20 21:22:42.355 Info LiveTV: Recording stopped: /usr/local/data/recordings/Press Your Luck (1983)/Season 1/Press Your Luck S01E03 107.ts
2019-07-20 21:22:42.355 Info LiveTV: Triggering refresh on /usr/local/data/recordings/Press Your Luck (1983)/Season 1/Press Your Luck S01E03 107.ts
2019-07-20 21:22:42.357 Info LiveTV: Refreshing recording parent /usr/local/data/recordings/Press Your Luck (1983)/Season 1
2019-07-20 21:22:42.362 Info LiveTV: Running recording post processor /var/lib/emby/ccextract.sh "/usr/local/data/recordings/Press Your Luck (1983)/Season 1/Press Your Luck S01E03 107.ts"
Edited by ProperlyFormattedDataFile, 21 July 2019 - 11:21 AM.
#2 Luke OFFLINE
Luke
    System Architect
  • Administrators
  • 148727 posts
Posted 21 July 2019 - 06:06 PM
Hi, yes there's an issue here, thanks.
Also tagged with one or more of these keywords: livetv, dvr
0 user(s) are reading this topic
0 members, 0 guests, 0 anonymous users
