Manual collections deleted
Best Answer Luke , 24 July 2019 - 02:11 PM
Shot in the dark but please let me know if 4.2.0.36 helps, and if not, please attach a new server log from a library scan. thanks.
Go to the full post
  • Please log in to reply
53 replies to this topic
#1 jordy OFFLINE
jordy
    Advanced Member
  • Members
  • 1324 posts
  • Local time: 07:50 PM
  • LocationAdelaide, Australia
Posted 18 July 2019 - 02:52 AM
@Luke, I'm just fine with what I had before, limitations or not, so I'll follow up on your suggestion.Thanks
HOWEVER, over the past two days I have twice created a NEW Collection and twice it has been deleted by Emby. Def not me and no-one else knows how or has any file system access to do this.
When I create the Collection it appears in this folder; <C:\Users\Paul\AppData\Roaming\Emby-Server\programdata\data\collections> However, i'm thinking that the AutoBoxSets plugin is deleting it on it's scheduled refresh.
Can you check it out and fix it please before I lose a third one with manual edits.
Thanks
Edited by jordy, 18 July 2019 - 02:56 AM.
#2 Luke OFFLINE
Luke
    System Architect
  • Administrators
  • 146507 posts
  • Local time: 04:20 AM
Posted 18 July 2019 - 02:59 AM
Thanks
Server log? thanks.
#3 jordy OFFLINE
jordy
    Advanced Member
  • Members
  • 1324 posts
Posted 18 July 2019 - 04:05 AM
Here is today's log. There are a couple of hundred references to the "Kids Movies" collection. Early in the day I added some 60 odd movies to this collection, afterwards, a Library Scan is initiated, this is followed by ALL of the Collections being removed and deleted from the database.
2019-07-18 14:48:51.396 Info TaskManager: Executing Scan media library
at
2019-07-18 14:48:52.924 - My "Kids Movies" Collection is removed and deleted from the Database...
thanks
Edited by jordy, 18 July 2019 - 04:06 AM.
#4 jordy OFFLINE
jordy
    Advanced Member
  • Members
  • 1324 posts
Posted 18 July 2019 - 04:34 AM
One more thing, Because I was adding so many movies to this collection, when adding the content of existing Collections eg Madagascar Collection, I was multi-selecting all of the included movies and then "adding them to Kids Movies as a group, the "Items saved" notification appeared but the movies were not added. I could only add them individually. Is this a bug or intended ?
You may be able to see this in action earlier in the log somewhere around 09:00.
thanks
#5 Luke OFFLINE
Luke
    System Architect
  • Administrators
  • 146507 posts
Posted 18 July 2019 - 12:12 PM
I see no problems using multi select to add to collections. @Happy2Play do you?
#6 Centory OFFLINE
Centory
    Member
  • Members
  • 24 posts
  • Local time: 10:20 AM
Posted 18 July 2019 - 02:32 PM
Same here, this is terrible, i only! want to add my movies manualy to a collection, nothing more, not automatic, now i have zero collections...
Switched to stable, collections are back...
Edited by Centory, 18 July 2019 - 03:27 PM.
#7 Happy2Play OFFLINE
Happy2Play
    Trial and Error
  • Moderators
  • 17164 posts
  • Local time: 01:20 AM
  • LocationWashington State
Posted 18 July 2019 - 04:11 PM
No I had no issue with existing custom collections or creating a new custom collection.
But the log above clearly shows multiple Collections being removed from the database at 14:48 and Kids Movies again at 16:35 as the collection ids is changing.
 Line 6654: 2019-07-18 14:48:52.924 Info App: Removing item from database, Type: BoxSet, Name: Kids Movies, Path: C:\Users\xxxxl\AppData\Roaming\Emby-Server\programdata\data\collections\Kids Movies [boxset], Id: 1368989
 Line 8978: 2019-07-18 16:35:12.518 Info App: Removing item from database, Type: BoxSet, Name: Kids Movies, Path: C:\Users\xxxx\AppData\Roaming\Emby-Server\programdata\data\collections\Kids Movies [boxset], Id: 1369062
thanks
I had no issue multi-selecting all the content within a collection and adding it to another or adding the collection itself.
Edited by Happy2Play, 18 July 2019 - 04:12 PM.
#8 Luke OFFLINE
Luke
    System Architect
  • Administrators
  • 146507 posts
Posted 18 July 2019 - 04:53 PM
Hi, remember we're here for testing preview versions.  That's not really how we test. Please make sure to see how to report a problem. thanks.
#9 Happy2Play OFFLINE
Happy2Play
    Trial and Error
  • Moderators
  • 17164 posts
Posted 18 July 2019 - 05:14 PM
How about a server log.  Everything is manual unless you install a plugin.  If switching version they are back, then obviously there is a issue with your beta reading the \data\collection folder then.
#10 Luke OFFLINE
Luke
    System Architect
  • Administrators
  • 146507 posts
Posted 19 July 2019 - 01:26 AM
Also as you have been on these 4.2.X betas, have you done any rollbacks to previous versions? That could be causing problems that we're not currently thinking of.
#11 jordy OFFLINE
jordy
    Advanced Member
  • Members
  • 1324 posts
Posted 19 July 2019 - 03:01 AM
if you're referring to me, No. Been permanently on Beta versions and haven't done Stable for years :)
And this is getting weirder by the day...
Yesterday, I added back my Kids Movies Collection and added 1 movie to it. It showed up correctly in the Collections Page. I edited the MetaData and changed the "Sort Title" to "01 Kids Movies" so that it would be shown at the top of the Collections list for easy access. - ALL Good.
Today, I checked the Collections Folder to see if Kids Movies had been removed again. It is still there. However, it no longer appears in the Collections Page in Emby Web UI. Nor does it appear in the "Add To Collections" list from the 3 dot menu. I was going to re-test the adding of multiple movies to a Collection using MultiSelect. But I cannot if I can't see it!
I'm just a little confused now.
Edited by jordy, 19 July 2019 - 03:02 AM.
#12 jordy OFFLINE
jordy
    Advanced Member
  • Members
  • 1324 posts
Posted 20 July 2019 - 06:06 AM
@Luke,
So again this morning I re-created my Kids Movies Collection adding some 80 individual movies. It appeared in all the screens I expected it to - the Movies page and the Collections Page of the Web UI.
This evening when I got home and wanted to play a movie for my grandkids, the collection had again disappeared from the Web UI on both pages.
I checked the Collections folder and the "Kids Movies [Boxset]" folder was still there.
Is there any chance you can fix this sometime soon?
I really don't understand why you "fixed" something  that was not broken.
#13 Luke OFFLINE
Luke
    System Architect
  • Administrators
  • 146507 posts
Posted 20 July 2019 - 12:00 PM
I have not been able to reproduce this but will keep an eye out for it. Thanks.
#14 ebr OFFLINE
ebr
    Chief Bottle Washer
  • Administrators
  • 49121 posts
Posted 20 July 2019 - 04:25 PM
What user are you using when looking for this?
Is there any chance that access permissions or parental control are actually just hiding it...?
#15 jordy OFFLINE
jordy
    Advanced Member
  • Members
  • 1324 posts
Posted 20 July 2019 - 10:34 PM
I am using the only admin account on the server - Access all areas. No filters applied
Edited by jordy, 20 July 2019 - 10:47 PM.
#16 Scott310 OFFLINE
Scott310
    Advanced Member
  • Members
  • 600 posts
  • Local time: 09:20 AM
Posted 22 July 2019 - 02:39 AM
Hey Guys,
I am on version 4.2.0.33 beta.
I went into my collections and saw that all of the auto generated collections were there but all of my custom box sets were gone.  I went ahead and recreated them only to find that with the next library scan they had all disappeared again. They were all also locked to prevent changes. I also went into the collections metadata folder and the .xml file was still there with all of the fanart and backdrops. Any ideas?
Thanks in advance for your help.  It was frustrating to spend a few hours recreating them only to have them disappear immediately with a library scan....
#17 jordy OFFLINE
jordy
    Advanced Member
  • Members
  • 1324 posts
Posted 22 July 2019 - 03:41 AM
@ebr, @Luke
So, are you guys doing something about this issue of disappearing Collections? or have you just moved on?
It's very clear from the Server log I posted that Emby is deleting Collections as part of some clean up/refresh process.
Again, I do not understand why you have changed/removed something that was not broken. You say that users are complaining that Collections within Collections is causing issues and they are not happy with how it works. I've not seen any complaints and I'm really not sure how else it can work. Some explanation would be nice so that we may all understand what you're trying to do or what others want that they didn't have.
#18 Luke OFFLINE
Luke
    System Architect
  • Administrators
  • 146507 posts
Posted 22 July 2019 - 11:47 AM
I haven't been able to reproduce but am keeping an eye out for it. Thanks.
#19 ebr OFFLINE
ebr
    Chief Bottle Washer
  • Administrators
  • 49121 posts
Posted 22 July 2019 - 11:49 AM
Hey Guys,
Hi.  Do you have the server log from that library scan?
#20 Scott310 OFFLINE
Scott310
    Advanced Member
  • Members
  • 600 posts
Posted 22 July 2019 - 01:55 PM
I think this might be the right one.  Let me know if you need anything else.
0 user(s) are reading this topic
0 members, 0 guests, 0 anonymous users
