4.2.0.25 Recording failed with "Emby Premiere required to use Emby DVR."
dvr premiere
  • Please log in to reply
22 replies to this topic
#1 ProperlyFormattedDataFile OFFLINE
    Advanced Member
  • Members
  • 72 posts
  • Local time: 10:32 AM
Posted 09 July 2019 - 08:57 PM
This seems similar to the thread about invalid license keys, but in my case the key seems to show as valid.  Today a regular recording failed to record, and the only clue I get from the logs is this:
2019-07-09 19:00:00.021 Info LiveTV: Recording timer fired for Jeopardy!.
2019-07-09 19:00:00.039 Warn LiveTV: Emby Premiere required to use Emby DVR.
I have a valid premiere license, and on the server on the Emby Premiere tab I have:
<green checkmark> You have a Monthly Emby Premiere plan and your device usage is well within your limit.
#2 Luke OFFLINE
Luke
    System Architect
  • Administrators
  • 149030 posts
Posted 09 July 2019 - 10:32 PM
Hi, does the emby premiere key page show your key in it?
#3 ProperlyFormattedDataFile OFFLINE
    Advanced Member
  • Members
  • 72 posts
Posted 09 July 2019 - 11:32 PM
Yes, it does.
#4 sfatula OFFLINE
sfatula
    Advanced Member
  • Members
  • 588 posts
  • Local time: 09:32 AM
  • LocationCalera, OK
Posted 10 July 2019 - 03:14 AM
I've had this same issue when a license validate check failed. The claim was it takes a long time of failures (>1cday) before emby will deny access to premiere features, but for me, it was virtually immediate.
#5 Luke OFFLINE
Luke
    System Architect
  • Administrators
  • 149030 posts
Posted 11 July 2019 - 02:43 AM
Please try 4.2.0.27+, and if you run into this again, please attach the emby server log. thanks.
#6 ProperlyFormattedDataFile OFFLINE
    Advanced Member
  • Members
  • 72 posts
Posted 15 July 2019 - 03:26 PM
Thanks, it's happened once so far on 4.2.0.27.  I've attached the log.  The error is on the same 7PM Jeopardy recording.
#7 Luke OFFLINE
Luke
    System Architect
  • Administrators
  • 149030 posts
Posted 15 July 2019 - 03:46 PM
Can you attach the previous log, before the log file rotation? thanks.
#8 ProperlyFormattedDataFile OFFLINE
    Advanced Member
  • Members
  • 72 posts
Posted 15 July 2019 - 07:36 PM
It happened today again on 4.2.0.30 at 7:00PM.  I've attached my /var/lib/emby/logs directory as a zip.
#9 sfatula OFFLINE
sfatula
    Advanced Member
  • Members
  • 588 posts
Posted 15 July 2019 - 08:18 PM
So, had 4 shows set to record at 7PM today. It's 7:16PM, and, 1 is recording. Where's the other 3? I have 6 tuners.
#10 sfatula OFFLINE
sfatula
    Advanced Member
  • Members
  • 588 posts
Posted 15 July 2019 - 08:21 PM
Yep, so, had trouble with 4.2.0.30 noted elsewhere, stopped emby, went back to .28, started emby, and, it says premiere required. So, it would not record one of the 3 shows. Needs fixed.
Edited by sfatula, 15 July 2019 - 08:40 PM.
#11 Luke OFFLINE
Luke
    System Architect
  • Administrators
  • 149030 posts
Posted 15 July 2019 - 10:18 PM
Why do you feel that they didn't happen? 6
#12 sfatula OFFLINE
sfatula
    Advanced Member
  • Members
  • 588 posts
Posted 15 July 2019 - 10:24 PM
Cause they didn't, no files in the directories, nothing on latest, nothing showing active recording except for the one, and, tuner showed only 1 being used. I see you merged my post, mine is on 4.2.0.30.
Finally, looked in hdhomerun system log, only 1 channel tuned. 23:59 is my 7pm. Note after restarting, it tunes to the scheduled channels.
This is the second time this has happened to me, curiously both times same day as a Beta update.
HDHR log:
20190715-23:59:00 Tuner: tuner0 tuning 10.1 KTENNBC (8vsb:545MHz-3)
20190715-23:59:01 Tuner: tuner0 streaming http to 192.168.3.18:36615
20190716-00:19:15 Tuner: tuner0 http stream ended (remote closed)
20190716-00:19:31 Tuner: tuner0 tuning 12.1 KXIICBS (8vsb:207MHz-1)
20190716-00:19:31 Tuner: tuner1 tuning 10.3 KTENABC (8vsb:545MHz-5)
20190716-00:19:31 Tuner: tuner1 streaming http to 192.168.3.18:46823
20190716-00:19:31 Tuner: tuner0 streaming http to 192.168.3.18:43403
20190716-00:22:17 Tuner: tuner2 tuning 10.1 KTENNBC (8vsb:545MHz-3)
20190716-00:22:18 Tuner: tuner2 streaming http to 192.168.3.18:40243
20190716-01:03:00 Tuner: tuner0 http stream ended (remote closed)
20190716-02:03:00 Tuner: tuner2 http stream ended (remote closed)
20190716-02:04:02 Tuner: tuner1 http stream ended (remote closed)
20190716-02:59:00 Tuner: tuner0 tuning 10.1 KTENNBC (8vsb:545MHz-3)
20190716-02:59:01 Tuner: tuner0 streaming http to 192.168.3.18:42389
20190716-03:37:00 Tuner: tuner0 http stream ended (remote closed)
Edited by sfatula, 16 July 2019 - 02:53 AM.
#13 ProperlyFormattedDataFile OFFLINE
    Advanced Member
  • Members
  • 72 posts
Posted 15 July 2019 - 11:15 PM
So the 7:00PM recording failed as I mentioned.  The next two scheduled recordings happened, and I was able to watch the recording of one of them while it was in progress, but as soon as the recordings finished the files were deleted.  This feels like a separate bug that I ran into on an earlier build:
2019-07-15 22:00:00.002 Info MediaEncoder: ProcessRun 'Encoding c17180': Stopping ffmpeg process with q command for /usr/local/data/recordings/American Ninja Warrior (2009)/Season 11/American Ninja Warrior S11E07 Los Angeles City Finals.ts
2019-07-15 22:00:00.076 Info MediaEncoder: ProcessRun 'Encoding c17180' Process exited with code 0
2019-07-15 22:00:00.076 Info MediaEncoder: FFMpeg exited with code 0
2019-07-15 22:00:00.174 Info HttpServer: SocketException: http://127.0.0.1:809...36f06/stream.ts
2019-07-15 22:00:00.174 Info HttpServer: HTTP Response 200 to 127.0.0.1. Time: 7198541ms. http://127.0.0.1:809...36f06/stream.ts
2019-07-15 22:00:00.480 Info LiveTV: Recording stopped: /usr/local/data/recordings/American Ninja Warrior (2009)/Season 11/American Ninja Warrior S11E07 Los Angeles City Finals.ts
2019-07-15 22:00:00.481 Info MediaSourceManager: Live stream native_dcae7ee91da8349d9a3089106668280d_0cad33e7094290eb2e02437d2bfd39ed consumer count is now 0
2019-07-15 22:00:00.481 Info MediaSourceManager: Closing live stream 06044cf0e6f93cdae5f285c9ecfaaeb4_01413a525b3a9622ce6fdf19f7dde354_native_dcae7ee91da8349d9a3089106668280d_0cad33e7094290eb2e02437d2bfd39ed
2019-07-15 22:00:00.481 Info SharedHttpPipelineSource: Closing SharedHttpPipelineSource
2019-07-15 22:00:00.481 Info MediaSourceManager: Live stream 06044cf0e6f93cdae5f285c9ecfaaeb4_01413a525b3a9622ce6fdf19f7dde354_native_dcae7ee91da8349d9a3089106668280d_0cad33e7094290eb2e02437d2bfd39ed closed successfully
2019-07-15 22:00:00.481 Info LiveTV: Triggering refresh on /usr/local/data/recordings/American Ninja Warrior (2009)/Season 11/American Ninja Warrior S11E07 Los Angeles City Finals.ts
2019-07-15 22:00:00.483 Info LiveTV: Refreshing recording parent /usr/local/data/recordings/American Ninja Warrior (2009)/Season 11
2019-07-15 22:00:00.509 Info SharedHttpPipelineSource: SharedHttpPipelineSource is done streaming.
2019-07-15 22:00:00.509 Info SharedHttpPipelineSource: Deleting temp files /var/lib/emby/transcoding-temp/c3fcbf0a281b4ff0b3da46ec7cd36f06.ts
2019-07-15 22:00:00.595 Info App: Removing item from database, Type: Episode, Name: Los Angeles City Finals, Path: /usr/local/data/recordings/American Ninja Warrior (2009)/Season 11/American Ninja Warrior S11E07 Los Angeles City Finals.ts, Id: 110259
Edited by ProperlyFormattedDataFile, 15 July 2019 - 11:16 PM.
#14 Luke OFFLINE
Luke
    System Architect
  • Administrators
  • 149030 posts
Posted 16 July 2019 - 12:04 PM
Hi, please try 4.2.0.31. It should be all good now. Thanks.
#15 sfatula OFFLINE
sfatula
    Advanced Member
  • Members
  • 588 posts
Posted 16 July 2019 - 01:07 PM
I don't see any comment in the 4.2.0.31 release notes that says anything about recordings not starting, just an omission?
This version (.31) did start 3 recordings after I installed it.
Edited by sfatula, 16 July 2019 - 08:02 PM.
#16 ProperlyFormattedDataFile OFFLINE
    Advanced Member
  • Members
  • 72 posts
Posted 16 July 2019 - 10:05 PM
The Premiere issue hasn't happened again yet, but recordings are still disappearing at an alarming rate.  Of the two recording today, 1 of them disappeared after recording:
2019-07-16 20:18:48.836 Info LiveTV: Recording stopped: /usr/local/data/recordings/Pandora (2008)/Season 1/Pandora S01E01 Shelter From the Storm.ts
2019-07-16 20:18:48.836 Info MediaSourceManager: Live stream native_38e2ec422972cf18ae399822dbeeeca8_0cad33e7094290eb2e02437d2bfd39ed consumer count is now 0
2019-07-16 20:18:48.836 Info MediaSourceManager: Closing live stream 06044cf0e6f93cdae5f285c9ecfaaeb4_01413a525b3a9622ce6fdf19f7dde354_native_38e2ec422972cf18ae399822dbeeeca8_0cad33e7094290eb2e02437d2bfd39ed
2019-07-16 20:18:48.836 Info SharedHttpPipelineSource: Closing SharedHttpPipelineSource
2019-07-16 20:18:48.855 Info HttpServer: HTTP GET https://rhonhart.dyn...rogramId=101433. UserAgent: Mozilla/5.0 (Linux; Android 9; Pixel 3 Build/PQ3A.190801.002; wv) AppleWebKit/537.36 (KHTML, like Gecko) Version/4.0 Chrome/75.0.3770.143 Mobile Safari/537.36
2019-07-16 20:18:48.864 Info HttpServer: HTTP Response 200 to 174.203.16.63. Time: 9ms. https://rhonhart.dyn...rogramId=101433
2019-07-16 20:18:48.870 Info SharedHttpPipelineSource: SharedHttpPipelineSource is done streaming.
2019-07-16 20:18:48.870 Info SharedHttpPipelineSource: Deleting temp files /var/lib/emby/transcoding-temp/49f1d840a9784053b2c50e78c720eaf0.ts
2019-07-16 20:18:48.870 Info HttpServer: HTTP Response 200 to 127.0.0.1. Time: 70301ms. http://127.0.0.1:809...0eaf0/stream.ts
2019-07-16 20:18:48.870 Info MediaSourceManager: Live stream 06044cf0e6f93cdae5f285c9ecfaaeb4_01413a525b3a9622ce6fdf19f7dde354_native_38e2ec422972cf18ae399822dbeeeca8_0cad33e7094290eb2e02437d2bfd39ed closed successfully
2019-07-16 20:18:48.870 Info LiveTV: Triggering refresh on /usr/local/data/recordings/Pandora (2008)/Season 1/Pandora S01E01 Shelter From the Storm.ts
2019-07-16 20:18:48.871 Info LiveTV: Refreshing recording parent /usr/local/data/recordings/Pandora (2008)/Season 1
2019-07-16 20:18:48.886 Info HttpServer: HTTP GET https://rhonhart.dyn...39b3e851c638d36. UserAgent: Mozilla/5.0 (Linux; Android 9; Pixel 3 Build/PQ3A.190801.002; wv) AppleWebKit/537.36 (KHTML, like Gecko) Version/4.0 Chrome/75.0.3770.143 Mobile Safari/537.36
2019-07-16 20:18:48.890 Info HttpServer: HTTP Response 200 to 174.203.16.63. Time: 4ms. https://rhonhart.dyn...39b3e851c638d36
2019-07-16 20:18:48.956 Info HttpServer: HTTP GET https://rhonhart.dyn...39b3e851c638d36. UserAgent: Mozilla/5.0 (Linux; Android 9; Pixel 3 Build/PQ3A.190801.002; wv) AppleWebKit/537.36 (KHTML, like Gecko) Version/4.0 Chrome/75.0.3770.143 Mobile Safari/537.36
2019-07-16 20:18:48.963 Info HttpServer: HTTP Response 200 to 174.203.16.63. Time: 6ms. https://rhonhart.dyn...39b3e851c638d36
2019-07-16 20:18:48.978 Info App: Removing item from database, Type: Episode, Name: Shelter From the Storm, Path: /usr/local/data/recordings/Pandora (2008)/Season 1/Pandora S01E01 Shelter From the Storm.ts, Id: 111875
2019-07-16 20:18:48.978 Info App: Deleting path /var/lib/emby/metadata/library/a2/a29d2be745a8a8b339447d21feb08dd6
#17 Luke OFFLINE
Luke
    System Architect
  • Administrators
  • 149030 posts
Posted 16 July 2019 - 10:49 PM
There should have been a recording ffmpeg log. can you please attach that? Thanks.
#18 ProperlyFormattedDataFile OFFLINE
    Advanced Member
  • Members
  • 72 posts
Posted 16 July 2019 - 11:13 PM
Sure, attached what I believe is the right file
Edited by ProperlyFormattedDataFile, 16 July 2019 - 11:20 PM.
#19 Luke OFFLINE
Luke
    System Architect
  • Administrators
  • 149030 posts
Posted 16 July 2019 - 11:16 PM
You attached the emby server log (good), but there should have also been an ffmpeg recording log.t hanks.
#20 ProperlyFormattedDataFile OFFLINE
    Advanced Member
  • Members
  • 72 posts
Posted 16 July 2019 - 11:21 PM
Already edited above.  Forgot to actually upload the file after selecting it the first time I posted.
Also tagged with one or more of these keywords: dvr, premiere
0 user(s) are reading this topic
0 members, 0 guests, 0 anonymous users
