Recording Problems
Best Answer Luke , 01 July 2019 - 05:32 PM
We're looking into it, thanks.
Go to the full post
  • Please log in to reply
96 replies to this topic
#1 SHSPVR OFFLINE
SHSPVR
    Advanced Member
  • Members
  • 587 posts
  • Local time: 04:09 PM
  • LocationVinita, Oklahoma
Posted 30 June 2019 - 01:05 PM
4.2.0.23-beta what ever you all done with codes it killing both recording now my setup NextPVR as m3u tuner
Let say
The Brady Bunch S02E24 Tell It Like It Is, recording start at 10:59am end at 11:31am
Then
The Brady Bunch S03E01 Ghost Town U.S.A start 11:29am but end at 11:31am when should end at 12:01pm not 2 min later
Edited by SHSPVR, 30 June 2019 - 01:07 PM.
#2 maegibbons ONLINE
maegibbons
    Advanced Member
  • Members
  • 2279 posts
  • Local time: 10:09 PM
  • LocationLutterworth, England, UK
Posted 30 June 2019 - 01:34 PM
There does appear to be some recording weirdness going on at the moment but i have not tracked it down. Very short recordings or cancelled by watching live or another recording finishing.
Not got a handle on it at present. But it is happening.
Krs
Mark
  • cayars likes this
#3 SHSPVR OFFLINE
SHSPVR
    Advanced Member
  • Members
  • 587 posts
Posted 30 June 2019 - 01:38 PM
Krs
Mark
Thanks mark but I usually only watch my recording the next day
#4 JoeBob0131 OFFLINE
JoeBob0131
    Member
  • Members
  • 11 posts
  • Local time: 01:09 PM
Started happening in .21 for me. It has to do with when there are two connections to one tuner then one of the connections ends killing them both. I assume those two episodes are on the same channel. So when the first recording ends at 11:31 it kills both of them.
#5 SHSPVR OFFLINE
SHSPVR
    Advanced Member
  • Members
  • 587 posts
Posted 30 June 2019 - 01:54 PM
That maybe what going on but I have 4 tuners and 1 analog and yes both them work before but I just noticed it this seem happen with back to back recording.
My guest it has something to with (Support customizing referrer for m3u tuners)
Edited by SHSPVR, 30 June 2019 - 01:57 PM.
#6 JoeBob0131 OFFLINE
JoeBob0131
    Member
  • Members
  • 11 posts
Posted 30 June 2019 - 02:02 PM
Yes. From what I understand Emby is designed to use 1 tuner for the same channel regardless of how many you have. So if you have two recordings on channel 25 one ending at 11:31 and one starting at 11:29 you will have an overlap on that one tuner. That is why it happens on back to back recordings, I am guessing you have a minute pad on each side of the recording.
#7 mhaider60 OFFLINE
mhaider60
    Advanced Member
  • Members
  • 37 posts
Posted 30 June 2019 - 02:20 PM
I noticed the same behavior last night when back to back episodes of 48 Hours recorded. I have a 1 minute early start and 2 minute later ending set on my recordings. I'm on 4.2.0.22 beta though.
#8 SHSPVR OFFLINE
SHSPVR
    Advanced Member
  • Members
  • 587 posts
Posted 30 June 2019 - 02:21 PM
Like said it wasn't an issue before that how it was when I setup M3U tuner many moon ago
#9 JoeBob0131 OFFLINE
JoeBob0131
    Member
  • Members
  • 11 posts
Posted 30 June 2019 - 02:26 PM
I know? We are talking about it being a new issue right? That is all I am saying is that it is functioning different now...
#10 mhaider60 OFFLINE
mhaider60
    Advanced Member
  • Members
  • 37 posts
Posted 30 June 2019 - 03:07 PM
I updated to 4.2.0.23 beta then setup back to back recordings with 1 minute early start and 2 minute extra end, both on the same channel. When the 2 recordings were at the overlap point I checked and only 1 tuner was being used. When the first recording ended so did the second one which was 3 minutes long. I'll attach my server log.
Edited by mhaider60, 30 June 2019 - 03:08 PM.
  • JoeBob0131 likes this
#11 JoeBob0131 OFFLINE
JoeBob0131
    Member
  • Members
  • 11 posts
Posted 30 June 2019 - 03:22 PM
Thank you for doing that. I was about to update to .23 again to grab a log since I did not before going down to .18.
#12 Dan_Austin OFFLINE
Dan_Austin
    Advanced Member
  • Members
  • 43 posts
Posted 30 June 2019 - 05:09 PM
Just a guess, but I suspect that the recent fix to prevent orphaned LiveTV sessions has a hand in this...
#13 maegibbons ONLINE
maegibbons
    Advanced Member
  • Members
  • 2279 posts
Posted 30 June 2019 - 06:53 PM
Yes it id definately back to back that causes a problem.
Affects HDHR and iptv tuners.
Krs
Mark
#14 speedingcheetah OFFLINE
speedingcheetah
    Advanced Member
  • Members
  • 331 posts
Posted 30 June 2019 - 07:07 PM
I guess i should have posted this here.
https://emby.media/c...dings/?p=758510
Edited by speedingcheetah, 30 June 2019 - 07:08 PM.
#15 Luke OFFLINE
Luke
    System Architect
  • Administrators
  • 131280 posts
  • Local time: 05:09 PM
Posted 30 June 2019 - 07:51 PM
Yes I'm sure that's exactly it. For now, As long as you don't play the recording in progress it should be fine.
#16 mhaider60 OFFLINE
mhaider60
    Advanced Member
  • Members
  • 37 posts
Posted 30 June 2019 - 08:01 PM
Depending on what you are replying to, but I haven't been watching the recordings in progress when the back to back problem happens
Sent from my Moto G (5S) Plus using Tapatalk
  • speedingcheetah likes this
#17 speedingcheetah OFFLINE
speedingcheetah
    Advanced Member
  • Members
  • 331 posts
Posted 30 June 2019 - 08:33 PM
Playback how? In Emby, or via the local partial recorded file via a media player separate from Emby?
I do on occasion, open a recording file directly and watch part of it, close it, then reopen to get the more finished file...on really long shows while they are airing etc.
But at the time of these recordings, I was not using the tv tuner, or watching a recording file that was in progress.
I was, watching a already completed recorded file from eailer in the day, via MPV on PC, not via Emby client, while those 2 shows were recording, but that should have no effect on Emby recording processes.
#18 Luke OFFLINE
Luke
    System Architect
  • Administrators
  • 131280 posts
Posted 30 June 2019 - 08:35 PM
Yea i can see how back to back in the latest build could be a problem as well. thanks.
#19 speedingcheetah OFFLINE
speedingcheetah
    Advanced Member
  • Members
  • 331 posts
Posted 30 June 2019 - 08:37 PM
The issue was first noticed for me on build 4.2.0.21.
i have updated to .23.....same issue.
At least i have my HDHR DVR software I can fall back on, to set recordings on.
Edited by speedingcheetah, 30 June 2019 - 08:38 PM.
#20 JoeBob0131 OFFLINE
JoeBob0131
    Member
  • Members
  • 11 posts
Posted 30 June 2019 - 08:42 PM
Was noticed on .21 for me as well. I don't record things either, two clients were watching the same channel and noticed that both streams got ended when only one of the clients ended it.
0 user(s) are reading this topic
0 members, 0 guests, 0 anonymous users
