4.2.0.20
Home screen => trailer => got "emby premiere required"
tested with chrome and firefox
Emby key is there and other feature that need it work. (ex. coverart)
Posted 26 June 2019 - 09:38 AM
i use ubuntu server if that can help.
I found that issue on Ubuntu several versions ago. With some plugins return the same issue.
Mi fix was:
1.- I uninstall the plugins.
2.- Save the key again in the settings.
3.- Reinstall the plugins.
Happenned to me twice after some server version updates, not all.
Posted 26 June 2019 - 09:43 AM
BTW. On Ubuntu I found that Is better download the .deb package to the server first, an then run the update from the terminal or the software installer. Using the software installer directly from the package when the browser prompt for action sometimes not work in the proper way. Of course with the server stopped.
Edited by HRSCR, 26 June 2019 - 09:44 AM.
Posted 26 June 2019 - 01:11 PM
Mi fix was:
That changed nothing in my case.
0 members, 0 guests, 0 anonymous users
