Emby Server Showing Movies With Additional Parts...
Emby Server Movies Additional Showing Parts Help Metadata Will Not Play Playback Error
  • Please log in to reply
41 replies to this topic
#1 Vinnie Sims OFFLINE
Vinnie Sims
    Advanced Member
  • Members
  • 130 posts
  • Local time: 04:32 PM
Posted 24 June 2019 - 05:14 PM
Hello.
So, I have my Emby Server up and running and for some reason when I add new movies or movies that have been there to my library already, I get a "Additional Parts" section for the whole movie. I have named everything correctly with what it says from Emby with the 'name of movie (year)' and still getting "Additional Parts" section. I just tried adding a Apollo 11 movie today and it's giving me the same result. I add metadata to local MKV file itself, but I tried removing it, and it still did not work.
Any help please?
Thanks!
Edited by Vinnie Sims, 24 June 2019 - 05:15 PM.
#2 ebr OFFLINE
ebr
    Chief Bottle Washer
  • Administrators
  • 49051 posts
  • Local time: 03:32 PM
Posted 24 June 2019 - 05:20 PM
Hi.  Can you please show us your file structure and how you configured the library?
Thanks.
Movie naming
#3 Vinnie Sims OFFLINE
Vinnie Sims
    Advanced Member
  • Members
  • 130 posts
Posted 24 June 2019 - 05:27 PM
My file structure goes as follows: example: /Movies/Apollo 11 (2019)/Apollo 11 (2019).mkv
‚ÄčI configured the library as such in the photos attached below...
#4 Happy2Play OFFLINE
Happy2Play
    Trial and Error
  • Moderators
  • 17143 posts
  • Local time: 12:32 PM
  • LocationWashington State
Posted 24 June 2019 - 05:32 PM
How about a screenshot of the content in the Apollo 11 folder.
#5 Vinnie Sims OFFLINE
Vinnie Sims
    Advanced Member
  • Members
  • 130 posts
Posted 24 June 2019 - 05:34 PM
Sure...
#6 Luke OFFLINE
Luke
    System Architect
  • Administrators
  • 146293 posts
Posted 24 June 2019 - 05:56 PM
How about the folder on your file system?
#7 Vinnie Sims OFFLINE
Vinnie Sims
    Advanced Member
  • Members
  • 130 posts
Posted 24 June 2019 - 06:01 PM
Sure, it is exactly the same, but here you go...
I've noticed that on Emby it shows a dot with an underline before the actual movie like this ._ for some MKV files as shown in the photo...
Edited by Vinnie Sims, 24 June 2019 - 06:08 PM.
#8 Luke OFFLINE
Luke
    System Architect
  • Administrators
  • 146293 posts
Posted 24 June 2019 - 06:09 PM
Ok it's picking up the hidden file, thanks.
#9 Vinnie Sims OFFLINE
Vinnie Sims
    Advanced Member
  • Members
  • 130 posts
Posted 24 June 2019 - 06:10 PM
What's that mean? There is only one file in for each folder that has the exact naming.
#10 Luke OFFLINE
Luke
    System Architect
  • Administrators
  • 146293 posts
Posted 24 June 2019 - 06:17 PM
There's a hidden file in the folder as well that was picked up.
#11 Vinnie Sims OFFLINE
Vinnie Sims
    Advanced Member
  • Members
  • 130 posts
Posted 24 June 2019 - 06:23 PM
Ok, so it's hidden from our eyes but the system can see it. How do we fix this? And is this what is causing the issue? I have other MKVs that are doing the same thing...
#12 Vinnie Sims OFFLINE
Vinnie Sims
    Advanced Member
  • Members
  • 130 posts
Posted 24 June 2019 - 06:25 PM
I just added another movie and it is doing the exact same thing... showing another "Additional Parts"...
#13 mickle026 OFFLINE
mickle026
    Advanced Member
  • Members
  • 192 posts
  • Local time: 08:32 PM
Posted 24 June 2019 - 06:27 PM
The hidden files probably start with a dot.  That's used on a lot of file systems.  In your case probably  " ._"
Double check your folders contents size and the contents you have.
If you are on a windows system, you can click in file explorer VIEW, the tick the hidden files box - it certainly looks like you have two copies of the movie.
When reading the file system in code (which Emby does) it can read hidden files, but playback via a player probably can't.5d114ebf25ca3_hidden.png
Edited by mickle026, 24 June 2019 - 06:30 PM.
#14 Vinnie Sims OFFLINE
Vinnie Sims
    Advanced Member
  • Members
  • 130 posts
Is this possibly a software fix or still something on my end?
#15 Vinnie Sims OFFLINE
Vinnie Sims
    Advanced Member
  • Members
  • 130 posts
Posted 24 June 2019 - 06:28 PM
If you are on a windows system, you can click in file explorer VIEW, the tick the hidden files box - it certainly looks like you have two copies of the movie.  When reading the file system in code your can read hidden files, but playback probably cant see it from the player.
I am on a Mac, how do I read this on my Mac and remove the extra hidden file?
#16 Happy2Play OFFLINE
Happy2Play
    Trial and Error
  • Moderators
  • 17143 posts
What OS is your Media on?
What ever it is it is creating the ._Apollo 11 (2019).mkv, pretty sure there are other topics on this issue also.
#17 Vinnie Sims OFFLINE
Vinnie Sims
    Advanced Member
  • Members
  • 130 posts
Posted 24 June 2019 - 06:30 PM
My Emby server is running on a Synology DS918+ which I have a external drive hooked up to it via USB which I use that as the main media source and then the actual hard drive in the Synology as for recording live tv for now.
#18 mickle026 OFFLINE
mickle026
    Advanced Member
  • Members
  • 192 posts
Posted 24 June 2019 - 06:31 PM
A guide for mac
https://ianlunn.co.u...os-x-mavericks/
Anyone know if this is a synology thing for snapshots or something like that?
Edited by mickle026, 24 June 2019 - 06:32 PM.
#19 Vinnie Sims OFFLINE
Vinnie Sims
    Advanced Member
  • Members
  • 130 posts
So, it's not just me then, eh?
#20 Happy2Play OFFLINE
Happy2Play
    Trial and Error
  • Moderators
  • 17143 posts
Posted 24 June 2019 - 06:39 PM
It is Emby reading all content in the folder whether it is hidden or not.  Since Emby has the ability to hide metadata and images.  This is a specific OS issue as only that OS creates these rogue ._name.ext files.
Also tagged with one or more of these keywords: Emby, Server, Movies, Additional, Showing, Parts, Help, Metadata, Will Not Play, Playback Error
0 user(s) are reading this topic
0 members, 0 guests, 0 anonymous users
