New Beta 4.2.0.15 Great Problems
Best Answer Chillout , 19 July 2019 - 10:15 PM
.33 fixed this issue. All is good again. Thanks!
Go to the full post
  • Please log in to reply
39 replies to this topic
#1 Home2008 OFFLINE
Home2008
    Advanced Member
  • Members
  • 76 posts
  • Local time: 05:12 AM
Posted 12 June 2019 - 10:01 AM
Leider kann ich nur sehr schlecht englisch:-( probiere es in deutsch.
Unter Windows 10 Pro große Probleme plötzlich.
1. Nachbearbeiten von Film Informationen nicht möglich
2. CPU Last geht sofort hoch auf 100%
3. Emby App am Tablet nicht mehr nutzbar
Ich sehe immer nur den Lade Kreisel, sonst nichts.
Mit der vorherigen 12 Version keinerlei Probleme!
#2 Home2008 OFFLINE
Home2008
    Advanced Member
  • Members
  • 76 posts
Posted 12 June 2019 - 10:17 AM
Unfortunately, I can only speak very poor English :-( try it in German.
Under Windows 10 Pro big problems suddenly.
1. Post-processing of movie information is not possible
2. CPU load goes up to 100% immediately
3. Emby app on tablet no longer usable
I always only see the loading gyroscope, nothing else.
No problems with the previous 12 version!
Attached is the log file.
  • Attached File  log.zip   9.4KB   4 downloads
#3 Home2008 OFFLINE
Home2008
    Advanced Member
  • Members
  • 76 posts
Posted 12 June 2019 - 11:53 AM
If the library search is 88%, the CPU load goes up to 100%. Thereafter, the search of the rest of the bib lasts forever. The CPU stays at 100%! The server is hardly usable at this time!
#4 Luke OFFLINE
Luke
    System Architect
  • Administrators
  • 138261 posts
  • Local time: 11:12 PM
Posted 12 June 2019 - 12:51 PM
Hi there, this log is only a five minute log. Are you sure this is when the problem occurred?
#5 Home2008 OFFLINE
Home2008
    Advanced Member
  • Members
  • 76 posts
Posted 12 June 2019 - 03:53 PM
Return to 4.1, and it runs again.
#6 Luke OFFLINE
Luke
    System Architect
  • Administrators
  • 138261 posts
Posted 12 June 2019 - 03:59 PM
Hi there, can you please answer my question? Thanks.
#7 Home2008 OFFLINE
Home2008
    Advanced Member
  • Members
  • 76 posts
Posted 12 June 2019 - 04:24 PM
It was after my problems. Log from Server.
#8 Luke OFFLINE
Luke
    System Architect
  • Administrators
  • 138261 posts
Posted 12 June 2019 - 04:42 PM
Can you attach the previous log then, from when the problem occurred? Thanks.
#9 Home2008 OFFLINE
Home2008
    Advanced Member
  • Members
  • 76 posts
Posted 13 June 2019 - 01:58 AM
HEre the next log
#10 Home2008 OFFLINE
Home2008
    Advanced Member
  • Members
  • 76 posts
Posted 13 June 2019 - 02:20 AM
I now have this error message when installing the 4.1.1 and when trying again with the Beta 4.2.15:
Installed is another version. See pictures. What do I do now?
#11 Luke OFFLINE
Luke
    System Architect
  • Administrators
  • 138261 posts
Posted 13 June 2019 - 11:56 AM
HEre the next log
Please try removing these plugins:
2019-06-11 19:05:23.546 Info App: Loading Emby.Kodi.SyncQueue, Version=2.1.0.0, Culture=neutral, PublicKeyToken=null from C:\Users\georg\AppData\Roaming\Emby-Server\plugins\Emby.Kodi.SyncQueue.dll
2019-06-11 19:05:23.546 Info App: Loading Emby.Plugins.TVMosaic, Version=1.8.7.0, Culture=neutral, PublicKeyToken=null from C:\Users\georg\AppData\Roaming\Emby-Server\plugins\Emby.Plugins.TVMosaic.dll
Then restart the server and see if the issue remains.
#12 Luke OFFLINE
Luke
    System Architect
  • Administrators
  • 138261 posts
@softworkz may have some insight on that. Thanks.
#13 Home2008 OFFLINE
Home2008
    Advanced Member
  • Members
  • 76 posts
Posted 13 June 2019 - 01:05 PM
TVMosaic is removed. But which Emby Kodi plugin do you mean? The Kodi Companion?
#14 Luke OFFLINE
Luke
    System Architect
  • Administrators
  • 138261 posts
Posted 14 June 2019 - 02:31 AM
Yes, thanks.
#15 Home2008 OFFLINE
Home2008
    Advanced Member
  • Members
  • 76 posts
Posted 14 June 2019 - 02:59 AM
I am now back to the normal version 4.1.1. Emby does not let the server go into standby because there is always 100% CPU load. I can not tinker forever. The server must be running properly. :)
Now I have a problem: After I have the normal, not beta, version installed. At the Kodi client the server is found, logged in. During the synchronization an error message comes. After that I can not connect Kodi nciht more with the server. Do I have to delete everything and start from scratch?
#16 Home2008 OFFLINE
Home2008
    Advanced Member
  • Members
  • 76 posts
Posted 14 June 2019 - 07:39 AM
Incredible, the 4.1.1 is now running.
I got a new Telecom today. I noticed that even the native Netflix APP stopped running on the Shield TV. After that I have all booted the pc and shield. After that, an automatic declaration was made by Emby. But beta 4.2.15 I will not use any more, the problems had nothing to do with the connection.
#17 Home2008 OFFLINE
Home2008
    Advanced Member
  • Members
  • 76 posts
Posted 14 June 2019 - 09:54 AM
So, under 4.1.1 another error on Windows 10 PC Client. Log is here.
  • Attached File  kodi.zip   24.33KB   3 downloads
#18 Luke OFFLINE
Luke
    System Architect
  • Administrators
  • 138261 posts
Posted 14 June 2019 - 03:52 PM
If you go backwards from beta to stable, then yes this is recommended.
#19 softworkz OFFLINE
softworkz
    Advanced Member
  • Developers
  • 1795 posts
Posted 14 June 2019 - 05:31 PM
For the VC redist problem, please see;
#20 Home2008 OFFLINE
Home2008
    Advanced Member
  • Members
  • 76 posts
Posted 15 June 2019 - 01:50 AM
Thanks, I could install it!
0 user(s) are reading this topic
0 members, 0 guests, 0 anonymous users
