Detail4687 3 Posted May 19, 2019 Share Posted May 19, 2019 Is it possible to filter the view (for movies, tv, etc) based upon tags? I have content tagged such as "dad shows", "mom shows" etc, but I can't figure out how to display media tagged in that way. thanks Link to comment Share on other sites More sharing options...
Luke 36879 Posted May 20, 2019 Share Posted May 20, 2019 Hi, yes the web app and many other apps have this. Have you tried clicking the filter button above the movies list? Link to comment Share on other sites More sharing options...
Detail4687 3 Posted May 20, 2019 Author Share Posted May 20, 2019 I tried the "filter" function and I don't see anything regarding tags. Below are screenshots... Link to comment Share on other sites More sharing options...
Luke 36879 Posted May 20, 2019 Share Posted May 20, 2019 Have you added any tags to your movies? Link to comment Share on other sites More sharing options...
GrimReaper 3226 Posted May 20, 2019 Share Posted May 20, 2019 While we're at it, maybe we could have a "Clear all" or "Default" button/command in the Filter browser, if we have multiple filters enabled or want to change from one filter to another - it's a bit of a hassle to clear each field manually. Cheers Link to comment Share on other sites More sharing options...
Luke 36879 Posted May 20, 2019 Share Posted May 20, 2019 While we're at it, maybe we could have a "Clear all" or "Default" button/command in the Filter browser, if we have multiple filters enabled or want to change from one filter to another - it's a bit of a hassle to clear each field manually. Cheers yes that makes sense. thanks. Link to comment Share on other sites More sharing options...
Solution Detail4687 3 Posted May 21, 2019 Author Solution Share Posted May 21, 2019 Have you added any tags to your movies? That was it! My apologies. Actually, I added tags for TV Shows, but for some reason I was trying to filter on Movies, my bad. It works not, thanks Luke 1 Link to comment Share on other sites More sharing options...
anthony_m 1 Posted May 31, 2020 Share Posted May 31, 2020 While we're at it, maybe we could have a "Clear all" or "Default" button/command in the Filter browser, if we have multiple filters enabled or want to change from one filter to another - it's a bit of a hassle to clear each field manually. Cheers Bumping this up, as I often like to use multiple filters and it is rather annoying to manually clear all of them - a "clear filter" function would be fantastic. Link to comment Share on other sites More sharing options...
Luke 36879 Posted June 1, 2020 Share Posted June 1, 2020 We plan to add multi-select filters in future updates. thanks for the feedback. Link to comment Share on other sites More sharing options...
Luke 36879 Posted January 23, 2021 Share Posted January 23, 2021 You'll be able to multi-select filter in the upcoming Emby Server 4.6 release. Thanks. Link to comment Share on other sites More sharing options...
