Sostrihon 0 Posted April 20, 2019 Share Posted April 20, 2019 I can’t login? My username and password aren’t working? Link to comment Share on other sites More sharing options...
ebr 14863 Posted April 20, 2019 Share Posted April 20, 2019 Hi. What are you trying to log into? You control your own server users. Link to comment Share on other sites More sharing options...
Ostrihon64 0 Posted April 20, 2019 Share Posted April 20, 2019 i just signed up for premium and need to enter my key #, im not sure where to enter it? Link to comment Share on other sites More sharing options...
ebr 14863 Posted April 20, 2019 Share Posted April 20, 2019 i just signed up for premium and need to enter my key #, im not sure where to enter it? Hi. Please see: How do I get my key? Link to comment Share on other sites More sharing options...
frobinsoninch2015 0 Posted April 20, 2019 Share Posted April 20, 2019 i have seen so many problems the last few days with emby from tv shows not displaying properly to not being able to login or not loading it seems emby has a serious issue with there code and needs to get it sorted asap as we have all paid for the service, those having issues with folders not displaying properly just go to folder select remove folder confirm remove then restart server then add tv folder back and it will put everything back to normal, i hope they get the login issue sorted soon Link to comment Share on other sites More sharing options...
Luke 36888 Posted April 20, 2019 Share Posted April 20, 2019 i have seen so many problems the last few days with emby from tv shows not displaying properly to not being able to login or not loading it seems emby has a serious issue with there code and needs to get it sorted asap as we have all paid for the service, those having issues with folders not displaying properly just go to folder select remove folder confirm remove then restart server then add tv folder back and it will put everything back to normal, i hope they get the login issue sorted soon Hi there, can you please describe the login issue that you're having? thanks. Link to comment Share on other sites More sharing options...
frobinsoninch2015 0 Posted April 20, 2019 Share Posted April 20, 2019 (edited) each time i try to open the server it takes about 4 times before it will open i have to refresh my brouser until it will open and even then it runs very slow when i select an icon settings etc. im using opera and have been with no issues until yesterday and my lg emby app wont play also p.s im now not getting any folders on my dashboard unless i refresh , im thinking a full restart on the main emby servers just a thought as you know the old saying, have you turned it of and on LOL Edited April 20, 2019 by frobinsoninch2015 Link to comment Share on other sites More sharing options...
Luke 36888 Posted April 29, 2019 Share Posted April 29, 2019 each time i try to open the server it takes about 4 times before it will open i have to refresh my brouser until it will open and even then it runs very slow when i select an icon settings etc. im using opera and have been with no issues until yesterday and my lg emby app wont play also p.s im now not getting any folders on my dashboard unless i refresh , im thinking a full restart on the main emby servers just a thought as you know the old saying, have you turned it of and on LOL @@frobinsoninch2015, can you please attach the emby server log from when this happened? Thanks ! Link to comment Share on other sites More sharing options...
