SSL Error After Move
SSL SSL ERROR
Best Answer NerdGuy85 , 15 April 2019 - 08:08 PM
Nevermind, I didn't check the port. It's working. The issue was with the corrupt user profile where it was originally installed. Topic closed. Thanks for the help.
Apparently, the user account where I installed Emby the user profile crashed and when I was logging in with the admin user it was logging into a new user folder. I was able to get this issue resolved by running Emby as service using the original admin user folder. I decided to create an Emby user and copied all the programdata files, the issue has returned with the SSL. I tested this and it was working properly under the original user account but now under the emby user account, it's not.
Any suggestions?
Go to the full post
  • Please log in to reply
13 replies to this topic
#1 NerdGuy85 OFFLINE
NerdGuy85
    Member
  • Members
  • 26 posts
  • Local time: 06:51 PM
  • LocationCoral Springs, FL
Posted 15 April 2019 - 03:50 PM
Afternoon,
Over the weekend I spun up a new server and successfully moved my Emby installation over or so I thought. I've been able to connect internally without an issue, I recently attempted to connect outside my home and realized it wasn't working properly. From a web browser, I'm getting an ERR_SSL_PROTOCOL_ERROR.
I performed these steps so far:
* Removed SSL setting
* Restarted Emby Server after all setting changes
* Removed need for SSL, was able to connect on none secure port.
* Tested the SSL cert & verified the password.
Figured I'd reach out, this forum has been amazing with all my support needs.
Thanks
#2 pwhodges ONLINE
pwhodges
    Advanced Member
  • Members
  • 193 posts
  • Local time: 11:51 PM
  • LocationOxford, UK
Posted 15 April 2019 - 03:54 PM
Is the SSL port being forwarded to your new server?
#3 NerdGuy85 OFFLINE
NerdGuy85
    Member
  • Members
  • 26 posts
Posted 15 April 2019 - 04:01 PM
yup, the new server was the replacement so it has the same IP.
#4 Luke OFFLINE
Luke
    System Architect
  • Administrators
  • 128908 posts
Posted 15 April 2019 - 04:03 PM
Server log?
#5 NerdGuy85 OFFLINE
NerdGuy85
    Member
  • Members
  • 26 posts
Posted 15 April 2019 - 04:11 PM
Server log?
Sent PM
#6 Luke OFFLINE
Luke
    System Architect
  • Administrators
  • 128908 posts
Posted 15 April 2019 - 04:19 PM
	System.ComponentModel.Win32Exception: System.ComponentModel.Win32Exception (0x8009030D): The credentials supplied to the package were not recognized
	   at System.Net.SSPIWrapper.AcquireCredentialsHandle(SSPIInterface secModule, String package, CredentialUse intent, SCHANNEL_CRED scc)
The error seems to suggest that the SSL certificate password is not configured correctly.
#7 NerdGuy85 OFFLINE
NerdGuy85
    Member
  • Members
  • 26 posts
Posted 15 April 2019 - 04:40 PM
I test imported that same certificate file on another system using the same password and imported perfectly. I even attempted with a wrong password and of course, the import failed.
I re-typed the password slowly and carefully thinking maybe I fat fingered it in, I'm still getting the same error.
#8 Luke OFFLINE
Luke
    System Architect
  • Administrators
  • 128908 posts
Posted 15 April 2019 - 05:06 PM
Perhaps browser auto-complete features are interfering? try configuring with another browser.
#9 NerdGuy85 OFFLINE
NerdGuy85
    Member
  • Members
  • 26 posts
Posted 15 April 2019 - 05:12 PM
Good point. Just tried and nope that wasn't it.
Now, I just noticed internally the secured connection doesn't work either. Also getting an SSL error message.
#10 Luke OFFLINE
Luke
    System Architect
  • Administrators
  • 128908 posts
Posted 15 April 2019 - 05:13 PM
If the password is not configured correctly then this would be expected that it would not work internally.
#11 NerdGuy85 OFFLINE
NerdGuy85
    Member
  • Members
  • 26 posts
Posted 15 April 2019 - 05:22 PM
Well of course but I tested it after I re-entered the password using a different browser.
#12 NerdGuy85 OFFLINE
NerdGuy85
    Member
  • Members
  • 26 posts
Posted 15 April 2019 - 07:52 PM
Any suggestions?
#13 NerdGuy85 OFFLINE
NerdGuy85
    Member
  • Members
  • 26 posts
Posted 15 April 2019 - 08:08 PM   Best Answer
Any suggestions?
#14 Luke OFFLINE
Luke
    System Architect
  • Administrators
  • 128908 posts
Posted 15 April 2019 - 08:51 PM
Thanks for the feedback.
Also tagged with one or more of these keywords: SSL, SSL ERROR
0 user(s) are reading this topic
0 members, 0 guests, 0 anonymous users
