ProphetSe7en 15 Posted March 6, 2019 Share Posted March 6, 2019 Just wondering if the built in trailer feature in kodi is not available with emby for kodi? As soon as I add emby for kodi the trailer option in movie information is missing. Link to comment Share on other sites More sharing options...
Angelblue05 4130 Posted March 6, 2019 Share Posted March 6, 2019 (edited) With native playback mode it is compatible. But Emby has it's own trailer system. Why do you need to use the Kodi one? Edited March 6, 2019 by Angelblue05 Link to comment Share on other sites More sharing options...
sualfred 677 Posted March 6, 2019 Share Posted March 6, 2019 @Angelblue05 As far as I understand him correctly no trailers are synced to him. Skins usually hide the trailer button if ListItem.Trailer is empty. 1 Link to comment Share on other sites More sharing options...
Angelblue05 4130 Posted March 6, 2019 Share Posted March 6, 2019 (edited) Do you have trailers in Emby? Open the webclient, you should see the trailer button when viewing your movie content, try it. Let me know what happens. We will go from there. Edited March 6, 2019 by Angelblue05 Link to comment Share on other sites More sharing options...
ProphetSe7en 15 Posted March 6, 2019 Author Share Posted March 6, 2019 With native playback mode it is compatible. But Emby has it's own trailer system. Why do you need to use the Kodi one? Because the Kodi one is free Do you have trailers in Emby? Open the webclient, you should see the trailer button when viewing your movie content, try it. Let me know what happens. We will go from there. No I dont have trailers in Emby. Thats why I want to use the Kodi feature to watch trailers for my movies. Trailers is avaliable in movie information page if I dont use Emby. When Emby is enabled the trailer button is gone. Link to comment Share on other sites More sharing options...
Angelblue05 4130 Posted March 6, 2019 Share Posted March 6, 2019 (edited) Emby should be loading youtube trailers for your content: Please confirm this, by going to the emby webclient, check the info for one of your movie, hit trailer. Does it work? Edited March 6, 2019 by Angelblue05 Link to comment Share on other sites More sharing options...
ProphetSe7en 15 Posted March 6, 2019 Author Share Posted March 6, 2019 Emby should be loading youtube trailers for your content: Please confirm this, by going to the emby webclient, check the info for one of your movie, hit trailer. Does it work? There is no trailer option avaliable in emby webclient. 1 Link to comment Share on other sites More sharing options...
sualfred 677 Posted March 6, 2019 Share Posted March 6, 2019 Emby uses the trailer information from themovidedb.org. If there is a trailer, you will get the trailer button on the Emby gui. If there is a button on the Emby gui, the Kodi addon will sync this trailer information. If not you won't get one in Kodi. Try to refresh the metadata from a movie in your Emby library to refresh the information. If you use local trailers you have to follow the correct file file tagging: https://github.com/MediaBrowser/Wiki/wiki/Trailers 1 Link to comment Share on other sites More sharing options...
Angelblue05 4130 Posted March 6, 2019 Share Posted March 6, 2019 There is no trailer option avaliable in emby webclient. Is the imdb, tmdb field filled?? Select the 3 dots > edit metadata. Are your titles correctly detected in Emby? That is unexpected to me. Unless it’s some obscure movie, the youtube trailer should be there. Link to comment Share on other sites More sharing options...
ProphetSe7en 15 Posted March 6, 2019 Author Share Posted March 6, 2019 Is the imdb, tmdb field filled?? Select the 3 dots > edit metadata. Are your titles correctly detected in Emby? That is unexpected to me. Unless it’s some obscure movie, the youtube trailer should be there. Movie is identified correctly, imdb and tmbb is filled. 1 Link to comment Share on other sites More sharing options...
ProphetSe7en 15 Posted March 6, 2019 Author Share Posted March 6, 2019 Emby uses the trailer information from themovidedb.org. If there is a trailer, you will get the trailer button on the Emby gui. If there is a button on the Emby gui, the Kodi addon will sync this trailer information. If not you won't get one in Kodi. Try to refresh the metadata from a movie in your Emby library to refresh the information. If you use local trailers you have to follow the correct file file tagging: https://github.com/MediaBrowser/Wiki/wiki/Trailers I have refreshed metadata, no difference. I dont want to use local trailers. 1 Link to comment Share on other sites More sharing options...
Solution sualfred 677 Posted March 6, 2019 Solution Share Posted March 6, 2019 Take a look at themovidedb page of a movie that has it missing. Emby only uses the trailer of your configured metadata language. Is one available at themoviedb.org? 2 Link to comment Share on other sites More sharing options...
ProphetSe7en 15 Posted March 6, 2019 Author Share Posted March 6, 2019 Take a look at themovidedb page of a movie that has it missing. Emby only uses the trailer of your configured metadata language. Is one available at themoviedb.org? That`s it! I had metadata language in Emby to Norwegian. Changed to English and no there is trailers available in Emby webclient. Will test in Kodi in a few Thank you so much Link to comment Share on other sites More sharing options...
Angelblue05 4130 Posted March 6, 2019 Share Posted March 6, 2019 (edited) That`s it! I had metadata language in Emby to Norwegian. Changed to English and no there is trailers available in Emby webclient. Will test in Kodi in a few Thank you so much You may need to update your libraries in Kodi so it can grab the new trailers (open Emby for kodi > open the context menu on your movie library > update the library). It's possible the server didn't trigger update events for those. Let me know. Edited March 6, 2019 by Angelblue05 1 Link to comment Share on other sites More sharing options...
ProphetSe7en 15 Posted March 6, 2019 Author Share Posted March 6, 2019 I had to update library. Now trailers are available in Kodi Thank you so much 1 Link to comment Share on other sites More sharing options...
