loomes 40 Posted February 22, 2019 Share Posted February 22, 2019 With 4.0.7a my Kodi (actual Nightly) gets destroyed (on Nvidia Shield) when i start Playback of an exported Netflix strm file at the Moment the TV will switch the Framerate. No log outputs. When i disable framerate Switch in Kodi its works. Then i downgrade to 4.0.6a and all is working fine with framerate switch. Link to comment Share on other sites More sharing options...
Angelblue05 4127 Posted February 22, 2019 Share Posted February 22, 2019 Can you provide your Kodi log? For playback, what changed was the video emby-loading was updated to 25fps (from 10, which wasn’t functional on every platform) and a 1 sec sleep before pausing that video. Link to comment Share on other sites More sharing options...
loomes 40 Posted February 22, 2019 Author Share Posted February 22, 2019 That is it. I updated again to 4.0.7a and replaced the loading videos with the ones from 4.0.6. All is working fine again. Link to comment Share on other sites More sharing options...
Angelblue05 4127 Posted February 22, 2019 Share Posted February 22, 2019 (edited) We can't use 4.0.6e videos as they do not load on LE, CE, and a few others. Gotta figure out what is it about the current video (which works on those other platforms) doesn't work for you... Edit: Is this a Kodi bug? Edited February 22, 2019 by Angelblue05 Link to comment Share on other sites More sharing options...
Angelblue05 4127 Posted February 22, 2019 Share Posted February 22, 2019 (edited) @@loomes Can you provide your log using 4.0.7e with the video that comes with it. Thank you. Second, when you are using the 4.0.6e video, do you see the emby-loading video show up and pause before it goes on to load your content? Have you tried using native playback mode instead? Edited February 22, 2019 by Angelblue05 Link to comment Share on other sites More sharing options...
loomes 40 Posted February 22, 2019 Author Share Posted February 22, 2019 I have send you a PM with links to the log files. As i say, the Problem only occurs when i play strm files on the Emby Server (latest Beta). In my use these are strm files from the Amazon/Netlix Addons. When i play an mkv file which is localy hostet on the Emby Server all is working fine. 1 Link to comment Share on other sites More sharing options...
Solution Angelblue05 4127 Posted February 25, 2019 Solution Share Posted February 25, 2019 Solution: Use the new delay playback in the add-on settings > playback. This is happening because of auto framerate switching. It triggers for the emby-loading video, then when the add-on tries to play the main content, Kodi crashes trying to switch framerate again for the main content. A delay (1.5 second or more) before starting playback seems to resolve this. Link to comment Share on other sites More sharing options...
