PrincessClevage 173 Posted February 18, 2019 Share Posted February 18, 2019 (edited) Since the major update for server under movies/ latest movies the first two tiles do not show images until I enter the and go back then they show the correct images, similar with tv where next up first three tiles show blank until enter one of them and then correct images are shown. Any idea what might be the cause and a fix? Thanks Edited February 18, 2019 by PrincessClevage 1 Link to comment Share on other sites More sharing options...
Luke 36878 Posted February 18, 2019 Share Posted February 18, 2019 Can you show a screenshot to demonstrate the issue? Thanks. Link to comment Share on other sites More sharing options...
PrincessClevage 173 Posted February 19, 2019 Author Share Posted February 19, 2019 Sorry ran out of time tonight, will grab tomorrow Link to comment Share on other sites More sharing options...
PrincessClevage 173 Posted February 28, 2019 Author Share Posted February 28, 2019 Sorry for the delay, below are screenshot requested, same missing tiles in movie section Link to comment Share on other sites More sharing options...
Luke 36878 Posted February 28, 2019 Share Posted February 28, 2019 If you remove the cover art plugin, does that help? Link to comment Share on other sites More sharing options...
PrincessClevage 173 Posted March 5, 2019 Author Share Posted March 5, 2019 If you remove the cover art plugin, does that help?No does not make any difference Link to comment Share on other sites More sharing options...
Luke 36878 Posted March 6, 2019 Share Posted March 6, 2019 Does this happen on the vertical home screen? Link to comment Share on other sites More sharing options...
PrincessClevage 173 Posted March 6, 2019 Author Share Posted March 6, 2019 Does this happen on the vertical home screen?no it does not occur when running in vertical mode Link to comment Share on other sites More sharing options...
daedalus 430 Posted March 7, 2019 Share Posted March 7, 2019 i also see this happening from time to time this is nothing new, i remember that this was reported some time ago Link to comment Share on other sites More sharing options...
PrincessClevage 173 Posted March 9, 2019 Author Share Posted March 9, 2019 I have only experienced this since the major emby server update and it is constantly the first two folder icons in each category in horizontal view Link to comment Share on other sites More sharing options...
Luke 36878 Posted March 9, 2019 Share Posted March 9, 2019 Can you try the test build in the other thread? Thanks. Link to comment Share on other sites More sharing options...
PrincessClevage 173 Posted March 9, 2019 Author Share Posted March 9, 2019 Server test build or ET test build? I am running ET test build from post #300 atm (from gap at bottom of screen thread) Link to comment Share on other sites More sharing options...
grandpaxxl 0 Posted April 4, 2019 Share Posted April 4, 2019 Any news on this? I've had this feature for a long time too ... Link to comment Share on other sites More sharing options...
Luke 36878 Posted April 5, 2019 Share Posted April 5, 2019 Hi there, can you please describe what you're seeing? Thanks. Link to comment Share on other sites More sharing options...
grandpaxxl 0 Posted April 8, 2019 Share Posted April 8, 2019 Sorry ... wasn't at home ... i will send screenshots tomorrow to make things clear ... even though I have to say that it will look exactly like the one from 'PrincessClevage' ... exactly the same bug ... For my installation the problem was never solved ... Link to comment Share on other sites More sharing options...
Luke 36878 Posted April 9, 2019 Share Posted April 9, 2019 Thanks ! Link to comment Share on other sites More sharing options...
grandpaxxl 0 Posted April 9, 2019 Share Posted April 9, 2019 Ok ... back in Town ... here are 3 screenshots ... the first one shows the view when you move from the start screen to the right ... the missing pictures are always the ones directly next to the right border. When moving further to the right indeed the missing part moves with the other tiles ... ... and finally when the missing pictures moved out of sight on the left border and you go back ... et voilà ... here they are ... Any ideas? Got the problem for a very long time ... and for for all versions including the current one (Emby Theater 3.0.6, Windows 10 x64) and for "Full HD" as well as UHD resolution on different systems. Link to comment Share on other sites More sharing options...
Luke 36878 Posted April 9, 2019 Share Posted April 9, 2019 Does this happen if you remove the cover art plugin from the server? Link to comment Share on other sites More sharing options...
grandpaxxl 0 Posted April 9, 2019 Share Posted April 9, 2019 Before i forget ... the problem only occurs when the upcoming tiles are completely hidden before you move to the right ... like here ... In another situation the glitch doesn't show up ... here the tiles to the right overlap the border ... this seems to trigger the update of the tiles flawlessly ... Link to comment Share on other sites More sharing options...
grandpaxxl 0 Posted April 9, 2019 Share Posted April 9, 2019 Does this happen if you remove the cover art plugin from the server? Yes ... exactly same behaviour ... sorry ... Link to comment Share on other sites More sharing options...
grandpaxxl 0 Posted April 11, 2019 Share Posted April 11, 2019 No ideas ... ?!? Link to comment Share on other sites More sharing options...
Luke 36878 Posted April 11, 2019 Share Posted April 11, 2019 It's being looked into, thanks. Link to comment Share on other sites More sharing options...
