smitopher 19 Posted April 30, 2014 Share Posted April 30, 2014 I'm running 0.9 git download today (04/29) When selecting a video in that is marked as partially watched, I get prompted twice on whether I want to resume or restart. Is there a setting I'm missing? I'm very pleased with the performance and functionality so far and look forward to any and all new features. Link to comment Share on other sites More sharing options...
Solution xnappo 1592 Posted April 30, 2014 Solution Share Posted April 30, 2014 (edited) Set the XBMC setting 'Video'->'File Lists'->'Default Select Action' to 'Resume'. It will then work as you expect. xnappo Edited April 30, 2014 by xnappo Link to comment Share on other sites More sharing options...
smitopher 19 Posted April 30, 2014 Author Share Posted April 30, 2014 Perfect. Thank you. 1 Link to comment Share on other sites More sharing options...
Ballistic 8 Posted May 1, 2014 Share Posted May 1, 2014 To be honest.. That's a workaround. Not really a solution. Link to comment Share on other sites More sharing options...
xnappo 1592 Posted May 1, 2014 Share Posted May 1, 2014 (edited) +1. The XBMC resume information comes from the XBMC database. Feel free the remove the 'resume' code from 'def PLAY' and figure out how to get it working natively. I spend at least 5 hours trying. Maybe you will have more luck. I have no desire to look at it - the work-around is fine for me. xnappo Edited May 1, 2014 by xnappo Link to comment Share on other sites More sharing options...
xnappo 1592 Posted May 1, 2014 Share Posted May 1, 2014 One more comment on this - a large part of the reason for it is so that skin 'resume' icons will show up correctly. Now that we are heavily developing custom skins, it would be possible to use a much more direct means of displaying resume status. xnappo Link to comment Share on other sites More sharing options...
xnappo 1592 Posted May 1, 2014 Share Posted May 1, 2014 (edited) I agree - I just wanted to leave a few crumbs as to why things are the way they are for posterity's sake. xnappo Edited May 1, 2014 by xnappo Link to comment Share on other sites More sharing options...
