adelphiaUK 4 Posted November 26, 2018 Share Posted November 26, 2018 I have just changed my ports for HTTP and HTTPS access on my server to the standard 80 / 443 as I don't run anything else on my home IP. However, when looking on the server dashboard, the In-Home (LAN) access has changed but the Remote (WAN) access has remained at the default 8096 (as I haven't set up a certificate yet). This ONLY effects the dashboard link as if you enter the emby server manually with the new port numbers it connects OK. Link to comment Share on other sites More sharing options...
Luke 36999 Posted November 26, 2018 Share Posted November 26, 2018 what values did you change? Link to comment Share on other sites More sharing options...
adelphiaUK 4 Posted November 26, 2018 Author Share Posted November 26, 2018 I set mine to the standard HTTP/S ports of 80 and 443. I also have confirmed it doesn't change the WAN to the secure port I'm using (443 using SSL) and shows the default 8920 at the end of the link. If you wish me to, I can give you screenshots although I don't think they are required at this stage. Link to comment Share on other sites More sharing options...
Luke 36999 Posted November 26, 2018 Share Posted November 26, 2018 What exact settings did you change? Link to comment Share on other sites More sharing options...
Solution adelphiaUK 4 Posted November 26, 2018 Author Solution Share Posted November 26, 2018 Oh, OK. My fault I'd only changed the local ports and not the public ones (didn't realise there were two sets to change). It's OK now so you can, I guess, delete this thread or close it. Thanks for making me look closer! 1 Link to comment Share on other sites More sharing options...
Luke 36999 Posted November 26, 2018 Share Posted November 26, 2018 Thanks for the feedback. Link to comment Share on other sites More sharing options...
