Wrong display of some menus
android tv menus display
Best Answer ebr , 26 November 2018 - 03:30 PM
Please see how this looks in 1.6.63.  Thanks.
Go to the full post
  • Please log in to reply
10 replies to this topic
#1 Juan Simón OFFLINE
Juan Simón
    Advanced Member
  • Members
  • 34 posts
  • Local time: 12:33 AM
  • LocationDenmark
Posted 15 November 2018 - 10:31 AM
Hi,
I'm a new user of this app. I installed it a few days ago on a Arch Linux. The client is Nvidia Shield TV.
Some menus are displayed wrong, for example:
The "HECHO" (DONE) button is above the "Vista Predeterminada" (Default View) option.
My language is Spanish, perhaps the problem is the length of the literals in the Spanish translation. Can I change the language in the Android app?
I also have problems with the "Show next preview" banner shown at the end of each chapter, it's too big. It should be less intrusive. I also don't know if it's a language problem.
Can I change the font size?
Thanks.
Regards.
#2 ebr OFFLINE
ebr
    Chief Bottle Washer
  • Administrators
  • 52103 posts
  • Local time: 06:33 PM
Posted 15 November 2018 - 11:23 AM
Hi.  What version of the app are you running (shown on the app settings screen)?
Thanks.
#3 Juan Simón OFFLINE
Juan Simón
    Advanced Member
  • Members
  • 34 posts
  • LocationDenmark
Posted 15 November 2018 - 11:35 AM
Thanks.
Sorry, I forgot to put this info: 1.6.60g in client and 3.5.3.0 in server.
#4 ebr OFFLINE
ebr
    Chief Bottle Washer
  • Administrators
  • 52103 posts
Posted 15 November 2018 - 11:51 AM
And you feel the up next panel is too big...?
You are correct that your display issue on the menu is related to the translation.  I'll have to figure a way to handle that.
Thanks.
#5 Juan Simón OFFLINE
Juan Simón
    Advanced Member
  • Members
  • 34 posts
  • LocationDenmark
Posted 15 November 2018 - 12:03 PM
Yes, it isn't a problem if that panel is showed when the chapter is ended, above credits, but if the TV show doesn't have or has very few credits, the panel covers part of the screen and is uncomfortable.
I don't know what tool you used for the translation of the application but it should limit the number of characters for each literal. In this, if you need it, I can help you to translate better from English to Spanish.
Is there any way to change the language in Android?
Thanks.
#6 ebr OFFLINE
ebr
    Chief Bottle Washer
  • Administrators
  • 52103 posts
Posted 15 November 2018 - 12:12 PM
I don't see any way to make it any smaller and still useful but you can disable it showing in the app Playback settings page.  You can also dismiss it immediately when it pops up with the "back" key on your remote.
Yes, you can set your language and region in the device settings.
#7 Juan Simón OFFLINE
Juan Simón
    Advanced Member
  • Members
  • 34 posts
  • LocationDenmark
Posted 15 November 2018 - 12:21 PM
Yes, I knew, but I meant inside the application.
Thanks.
#8 Juan Simón OFFLINE
Juan Simón
    Advanced Member
  • Members
  • 34 posts
  • LocationDenmark
Posted 21 November 2018 - 10:45 AM
I am trying to help with this problem by shortening the translations so that they are the same (or almost) length as in English.
#9 Luke OFFLINE
Luke
    System Architect
  • Administrators
  • 157215 posts
Posted 21 November 2018 - 10:50 AM
We may still need to adjust the UI in some cases to make sure they can handle text that is 2x the length of English.
  • Juan Simón likes this
#10 ebr OFFLINE
ebr
    Chief Bottle Washer
  • Administrators
  • 52103 posts
Posted 26 November 2018 - 03:30 PM   Best Answer
#11 Juan Simón OFFLINE
Juan Simón
    Advanced Member
  • Members
  • 34 posts
  • LocationDenmark
Posted 27 November 2018 - 10:42 AM
Now it is better. It shows well all options and the button.
Although the buttons (in all app) seem too big to me.
Also tagged with one or more of these keywords: android tv, menus, display
0 user(s) are reading this topic
0 members, 0 guests, 0 anonymous users
