3.6.0.2 Series Recording Issue - AMC
series recording
Best Answer kanipek , 11 September 2018 - 05:33 PM
This issue for me was resolved by the 3.6.0.39 Beta update
Go to the full post
  • Please log in to reply
22 replies to this topic
#1 kanipek OFFLINE
kanipek
    U.S. Navy Retired
  • Members
  • 1166 posts
  • Local time: 07:21 AM
  • LocationMassillon, Ohio
Posted 24 July 2018 - 05:02 PM
The new season of Better Call Saul begins August 6th.
This series is not currently in the recording schedule.
If I choose series recording for this the series (or any on AMC) recording settings are odd -
What I would expect to see since this is a New/Premiere episode - "Record" New Episodes only and a check in "Don't record episodes already in my library"
What I am seeing is - "Record" is set to All episodes and "Don't record episodes already in my library" is unchecked
Very odd - any series I choose for series recording on AMC does this, all the other channels I checked are behaving as expected.
Seems I saw something like this on the forums previously, can't seem to find it now though.
Just reporting what I am seeing. For the moment I will leave it set to all episodes and see what happens. Also if I do change those two settings then it decides they have already been recorded - gives the greyed out series record icon in the EPG.
Edited by kanipek, 24 July 2018 - 05:04 PM.
#2 Luke OFFLINE
Luke
    System Architect
  • Administrators
  • 146061 posts
Posted 25 July 2018 - 12:31 AM
These are just default settings, they don't change from one series to the next. You have to change them if that's what you want.
Does that answer your question?
#3 kanipek OFFLINE
kanipek
    U.S. Navy Retired
  • Members
  • 1166 posts
Posted 25 July 2018 - 04:27 PM
I guess I am confused - Every other Series recording I set -- When it is a new episode the defaults are set to New Episodes Only and Do Not Record Episodes is checked.  When I Set a series Recording and it is a Repeat Episode -- I get All Episodes and Do Not Record Episodes is un-checked.
Except for AMC.
And If I change it to New Episodes Only and Don Not Record Episodes checked -- I gives me the greyed out series recording indicator so it isn't going to record anything.
This is default behavior??
Found another channel doing this WGN -- The Program Carter Premieres August 7th same issue with this one.
Seems like it is isolated to Premiere episodes - Found another TBS -- Wrecked Premieres on August 7th same issue with this one.
Is that default behavior for premeire type series/episodes??
Edited by kanipek, 25 July 2018 - 05:25 PM.
#4 Luke OFFLINE
Luke
    System Architect
  • Administrators
  • 146061 posts
Posted 25 July 2018 - 09:10 PM
Try refreshing the guide data and then creating a new series recording.
#5 kanipek OFFLINE
kanipek
    U.S. Navy Retired
  • Members
  • 1166 posts
Posted 26 July 2018 - 09:13 AM
There is no change after a guide refresh.
#6 Luke OFFLINE
Luke
    System Architect
  • Administrators
  • 146061 posts
Posted 26 July 2018 - 01:51 PM
I think it's something limited to the beta. Try removing your guide setup entirely, refreshing the guide, and then adding it back. thanks.
#7 kanipek OFFLINE
kanipek
    U.S. Navy Retired
  • Members
  • 1166 posts
Posted 26 July 2018 - 03:13 PM
I did as you suggested. I am seeing the same behavior.
This is of course using XMLTV as provider.
I guess I should also add that while it does add the series recordings, it is choosing to record a later, repeat of the episode(s). So with Better Call Saul instead of recording the first broadcast @9pm it is choosing a repeat @11:11pm. I don't know what the expected behavior of the All Episodes option is, but there is no reason tuner wise for this to be happening.
Just amplifying what I am seeing.
Edited by kanipek, 26 July 2018 - 03:28 PM.
#8 Luke OFFLINE
Luke
    System Architect
  • Administrators
  • 146061 posts
Posted 26 July 2018 - 03:47 PM
It's probably due to the way that they're tagged in the xml data. Can you locate the xml data for those entries?
#9 kanipek OFFLINE
kanipek
    U.S. Navy Retired
  • Members
  • 1166 posts
Posted 26 July 2018 - 03:58 PM
Yes:
  <programme start="20180807010000" stop="20180807020000" channel="EPG123.59337.schedulesdirect.org">
    <title>Better Call Saul</title>
    <sub-title>Smoke</sub-title>
    <desc>Jimmy struggles to cope with Chuck's tragic death; Mike ponders his role at Madrigal; Howard makes a startling confession.
Season 04, Episode 01</desc>
    <credits>
      <actor role="Saul Goodman">Bob Odenkirk</actor>
      <actor role="Mike Ehrmantraut">Jonathan Banks</actor>
      <actor role="Chuck McGill">Michael McKean</actor>
      <actor role="Kim Wexler">Rhea Seehorn</actor>
      <actor role="Howard Hamlin">Patrick Fabian</actor>
      <actor role="Nacho Varga">Michael Mando</actor>
      <producer>Vince Gilligan</producer>
      <producer>Peter Gould</producer>
      <producer>Mark Johnson</producer>
      <producer>Melissa Bernstein</producer>
    </credits>
    <date>20180806</date>
    <category>Series</category>
    <category>Premieres</category>
    <category>Season Premiere</category>
    <category>Drama</category>
    <language>en</language>
    <icon src="https://s3.amazonaws.com/schedulesdirect/assets/p10492751_b_h3_ac.jpg" />
    <episode-num system="dd_progid">EP01863210.0035</episode-num>
    <episode-num system="xmltv_ns">3.0.0/1</episode-num>
    <video>
      <quality>HDTV</quality>
    </video>
    <audio>
      <stereo>stereo</stereo>
    </audio>
    <premiere>Season Premiere</premiere>
    <new />
    <subtitles type="teletext" />
    <rating system="VCHIP">
      <value>TV-14</value>
    </rating>
  </programme>
Edited by kanipek, 26 July 2018 - 04:04 PM.
#10 garyan2 OFFLINE
garyan2
    Advanced Member
  • Members
  • 113 posts
  • Local time: 05:21 AM
Posted 28 July 2018 - 11:03 AM
... curious if anything was found in the XMLTV file that is not correct ...
  • kanipek likes this
#11 Luke OFFLINE
Luke
    System Architect
  • Administrators
  • 146061 posts
Posted 28 July 2018 - 11:09 AM
Can you try setting up a new series recording for a different show and see how that compares? Thanks.
#12 kanipek OFFLINE
kanipek
    U.S. Navy Retired
  • Members
  • 1166 posts
Posted 28 July 2018 - 12:13 PM
I have done this....
If the series/episode is a new or repeat I get what I would consider "normal" behavior.
If the series/episode is a premiere then it is as I have described above - And what ever the logic is for this scenario it doesn't make sense to me, there should not be any rescheduling of a recording to a later time unless there is a reason like not enough tuners. Something is definitely wrong here.
Like I said I am just reporting what I am seeing, so you are aware.
For the moment my plan is just keep an eye on these recordings and do a cancel series and then do a series record when they are simply marked as "New".
Edited by kanipek, 28 July 2018 - 12:13 PM.
#13 Luke OFFLINE
Luke
    System Architect
  • Administrators
  • 146061 posts
Posted 28 July 2018 - 12:26 PM
Is that Premiere marked as new?
#14 garyan2 OFFLINE
garyan2
    Advanced Member
  • Members
  • 113 posts
Posted 28 July 2018 - 02:14 PM
I believe the answer to that is yes. In his example above, both the premiere and new elements are present.
    <new />
From the sound of it, and kanipek can correct me if I am wrong, is that the presence of the premiere element is preventing the New flag from being considered/recognized.
Edited by garyan2, 28 July 2018 - 02:16 PM.
#15 kanipek OFFLINE
kanipek
    U.S. Navy Retired
  • Members
  • 1166 posts
Posted 28 July 2018 - 06:45 PM
    <new />
I wish I knew what the issue was.
I have done some troubleshooting - I have rolled back to 3.6.0.1 and the problem persists. The newest version I have prior to that is 3.4.1.2 (I used to be better about keeping the older versions around) so I rolled back to 3.4.1.2 and removed then added my XMLTV source and the issue is gone.
I have used XMLTV for months to schedule many premiere type series/episodes without issue.
I have compared the current XMLTV file to one I have from March - the formatting/structure of the file is identical.
While on 3.6.0.2 I also edited the XMLTV file to remove the "Premiere" info for Better Call Saul (August 6th S04E01) - doing that resulted in it being identified as "new" and scheduling a series recording was the normal/anticipated behavior.
#16 garyan2 OFFLINE
garyan2
    Advanced Member
  • Members
  • 113 posts
Posted 28 July 2018 - 07:08 PM
I have my suspicion on what is going on, but we'll let Luke identify the issue. Premiere is trumping New but is not considered to be new as well. Your experiment of removing Premiere only reinforces that.
#17 kanipek OFFLINE
kanipek
    U.S. Navy Retired
  • Members
  • 1166 posts
Posted 28 July 2018 - 07:21 PM
They will track it down I am sure. Hopefully before the Fall TV season. Until then I will just keep an eye on these types of recordings.
#18 kanipek OFFLINE
kanipek
    U.S. Navy Retired
  • Members
  • 1166 posts
Posted 30 July 2018 - 06:27 PM
So I just had another EPG update. I had Carter on WGN scheduled the 7th of August. Update added another showing of S01E01 on August 12th and Emby has chosen this airing as the one it will record.
Series settings are: All episodes only and Don't record episodes already in my library. That is not the expected behavior.
#19 cayars OFFLINE
cayars
    Advanced Member
  • Alpha Testers
  • 3002 posts
Posted 31 July 2018 - 01:27 AM
It's doing something similar as well for show that repeat as well.  Previously you would see an entry for 9pm and 2am (whatever) and not it doesn't list the multiple shows available.
#20 Luke OFFLINE
Luke
    System Architect
  • Administrators
  • 146061 posts
Posted 02 August 2018 - 12:09 AM
Please try again with the next release, thanks.
Also tagged with one or more of these keywords: series, recording
0 user(s) are reading this topic
0 members, 0 guests, 0 anonymous users
