Richard Branches 231 Posted August 25, 2018 Author Share Posted August 25, 2018 We can do that too, just not on the device at this time. I hope you do in a near future, but don't do anything yet until I test both devices to see what's going on with "Auto" on Emby under Android Oreo, meanwhile please visit developer.dolby.com to learn how to provide support. Link to comment Share on other sites More sharing options...
ebr 14904 Posted August 25, 2018 Share Posted August 25, 2018 Plex is not converting it directly but it tells the device to do so when Dolby Audio support is present How do you know that? Link to comment Share on other sites More sharing options...
ebr 14904 Posted August 25, 2018 Share Posted August 25, 2018 That's OK but "Auto" is not working with Emby and I suspect it's broken since Oreo arrived, I was unable to test it before because I was busy at my work but now that I received this device I'm going to do more testing with both devices to see what happens. I'll let you know. Why do you think the auto setting is broken? I have no knowledge or reports of it having any problems. Link to comment Share on other sites More sharing options...
Richard Branches 231 Posted August 25, 2018 Author Share Posted August 25, 2018 Why do you think the auto setting is broken? I have no knowledge or reports of it having any problems. Because of the quick test I made but I'm still not 100% sure, that's why I need to do more testing with the old and new device and I will confirm later if I was right or wrong, it's just that I've been busy lately. Link to comment Share on other sites More sharing options...
Richard Branches 231 Posted August 25, 2018 Author Share Posted August 25, 2018 (edited) How do you know that? Before I answer your question, I'm going to use Windows 10 and the Netflix app as an example: Windows 10 has Dolby Audio built-in and the Netflix app has a kind of "auto detection" for Dolby Audio. I don't have a modern AV receiver so I need to use an HDMI extractor with my computer in order to get Dolby Digital and DTS audio from the optical audio port. The Netflix app on Windows 10 always shows the 5.1 logo on movies and tv shows that support the audio format regardless of where it is connected, meanwhile, on the Mi Box, the logo won't appear unless the device is connected to an AV receiver or TV with Dolby Digital Plus support by its HDMI inputs. The difference here is, one device has REAL Dolby Audio support while the other doesn't, that's why the 5.1 logo always appear on Windows 10 and not in the Mi Box. When I play a movie or tv show with 5.1 audio, the Netflix app in conjunction with Dolby Audio built in Windows 10 detect that my computer is connected to an "audio system" (the extractor) with only Dolby Digital support, so the computer converts automatically the Dolby Digital Plus bitstream into Dolby Digital and sends the result to the optical audio port for playback by my old home theater system. To answer your question, I believe the Plex app has the same support as the Netflix app, but it won't work if the device doesn't have a REAL Dolby Audio licence, that's why it has never worked on the Mi Box but it's working on this new Mecool device and that's why I also believe the device does the conversion (hardware decoding maybe?) but if it's not, one thing is for sure, they both need to support Dolby Audio in order to work. Edited August 25, 2018 by delacosta78 Link to comment Share on other sites More sharing options...
Richard Branches 231 Posted September 10, 2018 Author Share Posted September 10, 2018 I wasn't able to test the Mecool KM8 device with 5.1 audio until today and I found out the "Auto" audio setting in Emby in conjunction with the "Auto" audio setting on this device is passing through Dolby Digital 5.1 but it's downmixing DTS to stereo and I suspect the reason is the additional audio setting called "Digital Sounds" (I tried with HDMI RAW and SPDIF RAW). It's not even working with the "Always" audio setting, the RAW stream is sent as stereo as well. It's important to clarify this device has DTS support and it's working with Plex. In case you need the logs, they were sent on 09/10/2018 at 5:43 pm and the server log is attached here as well. embyserver.txt Link to comment Share on other sites More sharing options...
ebr 14904 Posted September 10, 2018 Share Posted September 10, 2018 There is no playback in the app log you sent. Link to comment Share on other sites More sharing options...
Richard Branches 231 Posted September 10, 2018 Author Share Posted September 10, 2018 (edited) There is no playback in the app log you sent. I don't know why but I played one video file with DTS I have for a few minutes, is that the reason why? I see the file I played in the server log: 2018-09-10 17:41:27.337 Info App: Profile: Android-Exo, Path: D:\Usuarios\delacosta78\Videos\Videos Musicales\Interstella 5555 The 5tory of the 5ecret 5tar 5ystem (2003).mkv, isEligibleForDirectPlay: True, isEligibleForDirectStream: True Edited September 10, 2018 by delacosta78 Link to comment Share on other sites More sharing options...
ebr 14904 Posted September 11, 2018 Share Posted September 11, 2018 I don't know why either but there wasn't so, if you can submit another one.. Link to comment Share on other sites More sharing options...
Richard Branches 231 Posted September 11, 2018 Author Share Posted September 11, 2018 I don't know why either but there wasn't so, if you can submit another one.. App log sent again today at 11:38 am. Link to comment Share on other sites More sharing options...
ebr 14904 Posted September 11, 2018 Share Posted September 11, 2018 For some reason, the player is spitting out so many messages that it is overwhelming the log and I'm not able to see the start of playback. Can you please try playing for just a few seconds and then stopping and sending the log? Thanks. Link to comment Share on other sites More sharing options...
Richard Branches 231 Posted September 12, 2018 Author Share Posted September 12, 2018 For some reason, the player is spitting out so many messages that it is overwhelming the log and I'm not able to see the start of playback. Can you please try playing for just a few seconds and then stopping and sending the log? Thanks. I sent the log again on 09/11/18 at 11:39 pm. Link to comment Share on other sites More sharing options...
ebr 14904 Posted September 12, 2018 Share Posted September 12, 2018 For some reason, it is sending it through ffmpeg which is downmixing it. Can you please try this with the current beta? Link to comment Share on other sites More sharing options...
Richard Branches 231 Posted September 12, 2018 Author Share Posted September 12, 2018 For some reason, it is sending it through ffmpeg which is downmixing it. Can you please try this with the current beta? It's still downmixing the audio, I sent the log again at 3:35 pm. Link to comment Share on other sites More sharing options...
ebr 14904 Posted September 12, 2018 Share Posted September 12, 2018 Can you please confirm the Audio setting in the app...? Link to comment Share on other sites More sharing options...
Richard Branches 231 Posted September 12, 2018 Author Share Posted September 12, 2018 Can you please confirm the Audio setting in the app...? The app is set to "Auto", the device audio setting is set to "Auto" and the additional audio setting called "Digital Sounds" is set to HDMI RAW. Link to comment Share on other sites More sharing options...
ebr 14904 Posted September 12, 2018 Share Posted September 12, 2018 I'm guessing something with the combination of device settings is making it have to fall back to mix down. Link to comment Share on other sites More sharing options...
Luke 37024 Posted September 13, 2018 Share Posted September 13, 2018 @, have you explored your device audio settings? Link to comment Share on other sites More sharing options...
Richard Branches 231 Posted September 13, 2018 Author Share Posted September 13, 2018 @, have you explored your device audio settings? The main audio setting has "Auto", "Always" and "None" and the additional audio setting called "Digital Sounds" has PCM, SPDIF RAW and HDMI RAW. Link to comment Share on other sites More sharing options...
Richard Branches 231 Posted September 13, 2018 Author Share Posted September 13, 2018 (edited) I found the reason why it's not working: I downloaded a video with regular DTS and it works, which means, DTS-HD Master Audio streams are getting downmixed to stereo because they are not supported by the device, however, Emby app is ignoring the core DTS and that's what it should passthrough instead. I sent a log at 4:19 pm just in case you need it. Edited September 13, 2018 by delacosta78 Link to comment Share on other sites More sharing options...
Solution CBers 6766 Posted September 13, 2018 Solution Share Posted September 13, 2018 I found the reason why it's not working: I downloaded a video with regular DTS and it works, which means, DTS-HD Master Audio streams are getting downmixed to stereo because they are not supported by the device, however, Emby app is ignoring the core DTS and that's what it should passthrough instead. I sent a log at 4:19 pm just in case you need it. Do you have the DTS-HD MA option enabled in the settings in the app ?? 1 Link to comment Share on other sites More sharing options...
Richard Branches 231 Posted September 13, 2018 Author Share Posted September 13, 2018 Do you have the DTS-HD MA option enabled in the settings in the app ?? I forgot about that option!, I turned it off and it works now!, thank you for the tip, now this issue is resolved for good. 1 Link to comment Share on other sites More sharing options...
