Active video has small gap on side and bottom of screen
  • Please log in to reply
354 replies to this topic
#341 AdrianW OFFLINE
AdrianW
    Advanced Member
  • Super Testers
  • 2493 posts
  • Local time: 04:02 AM
  • LocationPerth, Australia
Posted 27 April 2019 - 06:54 AM
I've now watched a couple of hours of content with exclusive audio mode set on - and there's been no dropouts so far.
So, I guess that setting somehow got cleared during the update to 3.0.8.
Anyway, audio seems fine now and more importantly the small gaps at the bottom and right no longer appear.
#342 ShoutingMan OFFLINE
ShoutingMan
    Advanced Member
  • Members
  • 679 posts
  • Local time: 03:02 PM
Posted 27 April 2019 - 11:51 AM
I'm still on 3.0.6. I've launched ET so it can get the update and I'll give it a try. Fingers crossed! :)
#343 Guest_asrequested_* OFFLINE
Guest_asrequested_*
  • Guests
Posted 27 April 2019 - 12:43 PM
In some circumstances, exclusivity is defeated. I've added the option to my mpv.conf to make sure it always gets used.
#344 calmcacil OFFLINE
calmcacil
    Member
  • Members
  • 22 posts
  • Local time: 09:02 PM
Posted 02 May 2019 - 04:52 PM
Sadly still gap when window is maximized (not fullscreen.) the bottom few pixels are still bleeding trough and is slightly frustrating, due to multimonitor setup manually resizing the window is still an option although tedious, especially if i play it on one of my other monitors that doesnt have a taskbar. This issue also occurs on monitors with no taskbar. Fullscreen Mode does not have this issue, I dont think its an unreasonable assumption that a maximized window should cover the entirety of the screen minus the taskbar.
#345 Luke OFFLINE
Luke
    System Architect
  • Administrators
  • 157137 posts
  • Local time: 04:02 PM
Posted 02 May 2019 - 05:17 PM
But if you're not going full screen, then why use refresh rate switching?
#346 calmcacil OFFLINE
calmcacil
    Member
  • Members
  • 22 posts
Posted 03 May 2019 - 07:10 AM
I'm not using refresh rate switching.
#347 AdrianW OFFLINE
AdrianW
    Advanced Member
  • Super Testers
  • 2493 posts
Posted 03 May 2019 - 09:44 AM
I managed to replicate this (I think) by doing this:
  • Unlock the taskbar
  • Run ET (defaults to full screen for me)
  • Click the maximize/restore button - which switches to almost full screen with the taskbar showing - no gaps
  • Drag the taskbar to the top - gaps appear
  • Drag the taskbar back to the bottom - gaps still there
  • Close & re-open ET, gaps still there
  • Maximize ET - gaps gone
  • Close and re-open ET, gaps still gone
Seems like a different issue but with the same symptoms.
#348 calmcacil OFFLINE
calmcacil
    Member
  • Members
  • 22 posts
Posted 03 May 2019 - 09:48 AM
^ is basically right, you can also "maximize" instead of fullscreening by doubleclicking the top bar, as expected maximizes window as per windows standards. WinKey + Up also works.
#349 Guest_asrequested_* OFFLINE
Guest_asrequested_*
  • Guests
Posted 03 May 2019 - 10:14 AM
As you're using a mouse, you can now resize the window.
#350 calmcacil OFFLINE
calmcacil
    Member
  • Members
  • 22 posts
Posted 03 May 2019 - 10:19 AM
While this is a workaround that works, albeit slightly inconvenient on multimonitor setups, as emby does not allow for snapping and other features that make life with multi monitor setups easier, it would be nice if ET behaved how you expect software to do under the operating system you are using.
Edited by calmcacil, 03 May 2019 - 10:19 AM.
#351 stettler OFFLINE
stettler
    Advanced Member
  • Members
  • 336 posts
Posted 03 May 2019 - 11:15 AM
What about using the "snap-window" parameter in the mpv.conf file?
#352 Guest_asrequested_* OFFLINE
Guest_asrequested_*
  • Guests
Posted 03 May 2019 - 12:05 PM
I'd be curious to see if that would work, now.
#353 ShoutingMan OFFLINE
ShoutingMan
    Advanced Member
  • Members
  • 679 posts
Posted 12 May 2019 - 06:38 PM
How do I get the 3.0.8 update? My 3.0.6 Emby Theater isn't updating.
#354 Guest_asrequested_* OFFLINE
Guest_asrequested_*
  • Guests
Posted 12 May 2019 - 07:01 PM
https://emby.media/emby-theater.html
#355 ShoutingMan OFFLINE
ShoutingMan
    Advanced Member
  • Members
  • 679 posts
Posted 26 May 2019 - 11:31 PM
Thanks. I was avoiding that since I thought it would lose my configuration settings. But they seemed to be preserved.
0 user(s) are reading this topic
0 members, 0 guests, 0 anonymous users
