Active video has small gap on side and bottom of screen
  • Please log in to reply
354 replies to this topic
#301 daedalus OFFLINE
daedalus
    Advanced Member
  • Members
  • 970 posts
  • Local time: 11:14 AM
Posted 07 March 2019 - 05:43 PM
now with gpu-api=opengl the mpv player is semi transparent :blink:
Attached File  Unbenannt-1.png   837.84KB   9 downloads
@ refresh rate switching, it works here, no gaps or other issues on a quick test
but the switching itself looks a bit strange, starting playback shows the OSD with no mpv player behind it, seeing trough to the desktop, for half a second, than switching takes place and then comes back with the mpv player
#302 Doofus OFFLINE
Doofus
    Advanced Member
  • Members
  • 11342 posts
  • Local time: 02:14 AM
Posted 07 March 2019 - 10:42 PM
Well, a quick few tests with the Emby mpv build revealed that hwdec only works on auto, and will only enable d3d11va, and nothing else. None of the copyback modes work... cuda, nvdec...nothing. So that's a long way from being able to be used.
But when playing in Theater, you can directly enable d3d11va and d3d11va-copy, but the rest don't work. So something is very screwy with that build.
Edited by Doofus, 07 March 2019 - 11:11 PM.
#303 Doofus OFFLINE
Doofus
    Advanced Member
  • Members
  • 11342 posts
Posted 07 March 2019 - 11:16 PM
As for that last Theater test build, same as before. gpu-api=opengl screws everything up. That's not usable. The one great thing is that the mpv.conf does get used first and not the UI settings. It totally overrides them :D That is fantastic! But I wonder if it's because the window is re-sizable? If you lock the window down again, when playing, it might screw it up again. I really hope not.
#304 PrincessClevage OFFLINE
PrincessClevage
    Advanced Member
  • Members
  • 965 posts
  • Local time: 07:14 PM
Posted 08 March 2019 - 03:29 AM
I finally got my UI overlay back with the build from #300 and first deleting content from system folder then extracting files to system folder. I have hwa set to auto and colours seem a bit dull using the below config file
target-prim=bt.2020
deinterlace=no
hdr-compute-peak=no
tone-mapping=reinhard
What settings might you suggest for this build?
Edit. Never mind, I was playing sdr media:-/
HDR looks ok
Edited by PrincessClevage, 08 March 2019 - 04:00 AM.
#305 calmcacil OFFLINE
calmcacil
    Member
  • Members
  • 18 posts
Posted 08 March 2019 - 11:11 AM
using the build from #300 still getting a slight bit of wallpaper bleed when maximized on the bottom of the window (using start menu on top, not seeing any real issues on that end, not bleed to secondary monitors.
#306 Luke OFFLINE
Luke
    System Architect
  • Administrators
  • 128711 posts
  • Local time: 05:14 AM
Posted 09 March 2019 - 11:36 PM
Here's an update:
https://www.dropbox....heater.zip?dl=0
It updates to the electron 5.0 beta which is based on chromium 73 and brings noticeable performance improvements.
#307 PrincessClevage OFFLINE
PrincessClevage
    Advanced Member
  • Members
  • 965 posts
Posted 10 March 2019 - 01:57 AM
Here's an update:
looks pretty good and even fixed my first two folder images not showing in horizontal view. OpenGL seems to work ok also
Edited by PrincessClevage, 10 March 2019 - 03:31 AM.
#308 denz OFFLINE
denz
    Advanced Member
  • Members
  • 2052 posts
  • Local time: 05:14 PM
  • LocationPerth, Australia
Posted 10 March 2019 - 02:41 AM
If you watch Live TV and go back you can see your desktop before it goes back to the guide. I haven't been able to reproduce it every time but had number of success with new instance of theater and click back while in live tv but wait until the osd disappears first before clicking back.
Also you can barely see the timeline most of the time unless video is with very light colour the timeline should be white colour so you can see it clearly like you can text.
Edited by denz, 10 March 2019 - 02:52 AM.
#309 daedalus OFFLINE
daedalus
    Advanced Member
  • Members
  • 970 posts
Posted 10 March 2019 - 04:33 AM
using opengl is still semi transparent here
it still uses the old self compiled mpv :(
but the switching procedure seems at least fixxed
#310 PrincessClevage OFFLINE
PrincessClevage
    Advanced Member
  • Members
  • 965 posts
Posted 10 March 2019 - 04:34 AM
Have you tried deleting the content of the system folder in ET then extracting content to system folder?
#311 daedalus OFFLINE
daedalus
    Advanced Member
  • Members
  • 970 posts
Posted 10 March 2019 - 04:50 AM
not only tried, thats what i always do
#312 calmcacil OFFLINE
calmcacil
    Member
  • Members
  • 18 posts
Posted 10 March 2019 - 07:39 AM
seems this recent build is forcing a maximum height on the window that leaves it either showing a big gap on my monitor without a taskbar, or a small gap between the taskbar % window on the one with a taskbar...
edit: restarting it again I was able to resize as I wanted, generally speaking there seem to be an issue with maximizing the window (double clicking the top of the window) where it locks the max size even when you minimize it and the maximized size is too small.
Edited by calmcacil, 10 March 2019 - 07:44 AM.
#313 nicko84 OFFLINE
nicko84
    Advanced Member
  • Members
  • 230 posts
Posted 10 March 2019 - 08:46 AM
Here's an update:
Good for me with openGL and d3d copy back
Edit : nvdec and cuda don't work
Edited by nicko84, 10 March 2019 - 02:54 PM.
#314 Doofus OFFLINE
Doofus
    Advanced Member
  • Members
  • 11342 posts
Posted 10 March 2019 - 02:38 PM
No change for me. All the same problems that I last reported. And still the same issues with hwdec for that mpv build.
Here's the mpv log, for whomever is building mpv. I don't think they've added the dependency for nvdec and cuda (opengl api). I think they may still be trying to use the old broken version. But there're bigger issues with hwdec than there were. Less of the options, work.
I told it to use nvdec-copy, both in the UI and in my auto-profile, and this is what happened.
[   0.422][v][vd] Codec list:
[   0.422][v][vd]     mpeg2video - MPEG-2 video
[   0.422][v][vd]     mpegvideo (mpeg2video) - MPEG-1 video
[   0.422][v][vd] Opening decoder mpeg2video
[   0.422][v][vd] Looking at hwdec mpeg2video-d3d11va...
[   0.422][v][vo/gpu] Loading hwdec driver 'd3d11va'
[   0.422][v][vo/gpu] Loading failed.
[   0.422][v][vo/gpu] Loading hwdec driver 'dxva2-dxgi'
[   0.422][v][vo/gpu] Loading hwdec driver 'dxva2-dxinterop'
[   0.422][v][vd] Could not create device.
[   0.422][v][vd] Looking at hwdec mpeg2video-dxva2...
[   0.422][v][vd] Looking at hwdec mpeg2video-dxva2-copy...
[   0.491][v][vd] Trying hardware decoding via mpeg2video-dxva2-copy.
[   0.491][v][vd] Selected codec: mpeg2video (MPEG-2 video)
[   0.542][i][vd] Using hardware decoding (dxva2-copy).
But the stats reported no hwdec
Edited by Doofus, 10 March 2019 - 03:04 PM.
#315 Doofus OFFLINE
Doofus
    Advanced Member
  • Members
  • 11342 posts
Posted 10 March 2019 - 03:50 PM
Oh my bad. I looked a little deeper, and it is obeying the auto-profile
[   0.647][v][cplayer] first video frame after restart shown
[   0.648][v][auto_profiles] Re-evaluate auto profile Interlaced
[   0.648][i][auto_profiles] Applying profile Interlaced
[   0.648][d][cplayer] Run command: apply-profile, flags=0, args=[Interlaced]
[   0.649][d][cplayer] Setting option 'deinterlace' = 'yes' (flags = 68)
[   0.649][d][cplayer] Setting option 'hwdec' = 'nvdec-copy' (flags = 68)
So this means that the stats for nerds aren't working correctly.
#316 Luke OFFLINE
Luke
    System Architect
  • Administrators
  • 128711 posts
Posted 12 March 2019 - 02:20 AM
@Doofus, please try this version:
Thanks.
#317 Doofus OFFLINE
Doofus
    Advanced Member
  • Members
  • 11342 posts
Posted 12 March 2019 - 11:33 PM
There's some improvement. Nvdec is now usable, but using gpu-api=opengl at full screen still has no OSD and messes up my display. It's fine when windowed. I need to reboot, again.
#318 daedalus OFFLINE
daedalus
    Advanced Member
  • Members
  • 970 posts
Posted 13 March 2019 - 05:12 AM
with gpu-api=opengl it's here even more transparent with latest test build
#319 Diedrich OFFLINE
Diedrich
    Advanced Member
  • Members
  • 653 posts
Posted 19 March 2019 - 11:58 AM
In #272 I wasn't getting a delete confirmation dialogue after watching a show and clicking the trash can. I could go to the episodes list and delete from there and would get a confirmation dialogue.
I then installed #316 and now I don't get a played status indicator after letting an episode play all the way through and automatically stop, nor do I see a progress bar on the episode details screen after stopping an episode. Progress bar, however, is functioning properly on the home screen. It's not until you go back to the episode details screen that you see the progress bar and resume button.
#320 ShoutingMan OFFLINE
ShoutingMan
    Advanced Member
  • Members
  • 642 posts
Posted 07 April 2019 - 01:45 PM
Emby Theater must have updated, because it's back for me in the past month. I've stopped chasing, and just Emby Theater on the Shield. ET Windows has become too much hassle to keep working. Hopefully this gets fixed so I can have ET Windows as an option; sometimes its flexibility is preferred compared to the more constrained Shield UI and remote control.
0 user(s) are reading this topic
0 members, 0 guests, 0 anonymous users
