Emp0ri0 0 Posted January 21, 2019 Share Posted January 21, 2019 (edited) That's correct. Timing is based on Samsung release of the next version so I can't confirm that. Will it also downgrade DTS-X to ac3? About release time: at least are we talking about days or weeks or even months? Edit: One more question, since we are on EMBY forum, does this feature have anything to do with emby and will it also work with mkv movies from hdd? Edited January 21, 2019 by Emp0ri0 Link to comment Share on other sites More sharing options...
SamES 880 Posted January 21, 2019 Share Posted January 21, 2019 Will it also downgrade DTS-X to ac3? About release time: at least are we talking about days or weeks or even months? Edit: One more question, since we are on EMBY forum, does this feature have anything to do with emby and will it also work with mkv movies from hdd? Unfortunately it could be days, weeks or months. We just can't say. The conversion of DTS to AC3 is an Emby feature so it won't help for direct play from hdd. 1 Link to comment Share on other sites More sharing options...
Solution Luke 36886 Posted May 28, 2019 Solution Share Posted May 28, 2019 Emby for Samsung Tizen 1.0.61 has been released for 2015-2019 models. Please try it out and stay tuned to the blog for release notes. Thanks ! 1 Link to comment Share on other sites More sharing options...
FrostByte 5024 Posted May 28, 2019 Author Share Posted May 28, 2019 This bug can be closed. The app now automatically converts DTS to AC3 for 2018 and later TVs which no longer support DTS and then Direct Streams the movie to TV. Thanks @@Luke @@SamES Link to comment Share on other sites More sharing options...
Luke 36886 Posted May 28, 2019 Share Posted May 28, 2019 Thanks for the feedback ! Link to comment Share on other sites More sharing options...
TylerV76 84 Posted June 1, 2019 Share Posted June 1, 2019 This bug can be closed. The app now automatically converts DTS to AC3 for 2018 and later TVs which no longer support DTS and then Direct Streams the movie to TV. Thanks @@Luke @@SamES Not happening on my 2018 nu8000. Is there a setting that needs to be enabled? Currently I get no sound on any DTS files. Link to comment Share on other sites More sharing options...
FrostByte 5024 Posted June 1, 2019 Author Share Posted June 1, 2019 Not happening on my 2018 nu8000. Is there a setting that needs to be enabled? Currently I get no sound on any DTS files. Yes, on the server under users profile you need both the second and the fourth boxes in the pic below checked in order for it to automatically convert DTS to AC3 1 Link to comment Share on other sites More sharing options...
Luke 36886 Posted June 1, 2019 Share Posted June 1, 2019 Not happening on my 2018 nu8000. Is there a setting that needs to be enabled? Currently I get no sound on any DTS files. Please see how to report a media playback issue. thanks. Link to comment Share on other sites More sharing options...
TylerV76 84 Posted June 2, 2019 Share Posted June 2, 2019 Yes, on the server under users profile you need both the second and the fourth boxes in the pic below checked in order for it to automatically convert DTS to AC3 Thanks! 1 Link to comment Share on other sites More sharing options...
Luke 36886 Posted June 30, 2019 Share Posted June 30, 2019 For those interested, Install from USB: https://emby.media/community/index.php?/topic/74969-samsung-tizen-install-from-usb/ Link to comment Share on other sites More sharing options...
educationtry 0 Posted November 18, 2019 Share Posted November 18, 2019 I use iDealshare VideoGo to MKV DTS to MKV AAC or MKV MP3 to fix the no sound issue. Link to comment Share on other sites More sharing options...
