b0mb 35 Posted January 29, 2018 Author Share Posted January 29, 2018 Is this related to this issue which is still unsolved? https://emby.media/community/index.php?/topic/45616-inconvenience-in-auto-organise/Nope... I knew about the described problem but I can live with that. My problem it's that with the latest docker container no files are moved anymore. Those will be strictly copied and then deleted. I switched to the linuxserver.io Container now where that problem doesn't appear. Gesendet von meinem Redmi Note 3 mit Tapatalk Link to comment Share on other sites More sharing options...
Solution Flux02400 4 Posted August 4, 2022 Solution Share Posted August 4, 2022 I found the solution ! The problem was in the container not in emby apps or auto-organize (v1 or v2(beta)). If your folders (default movie or shows lib and temp to organize) are pull within different docker volume then it will copy but if your folders are subfolders of the same docker volume then it move ! Sorry i'm french i hope i'm clear 1 Link to comment Share on other sites More sharing options...
