Kelmino 17 Posted November 3, 2017 Share Posted November 3, 2017 (edited) When using the WebUI xxx.xxx.xxx.xxx:8096/emby/web/login.html It always requires me to sign in twice, basically it does this. Click on Login Bookmark Click on a Person 1 - Logs in fine Click on Login Bookmark Click on Person 2 - Shows persons 1 media Click on Login Bookmark Click on Person 2 - Shows Person 2 media Click on Login Bookmark Click on Person 3 - Shows Person 2 Media Click on Login Bookmark Click on Person 4 - Shows Person 3 media It seems to always show the last person who logs in, and requires us to log in twice no matter the person.Is there another way I should be going to the log-in screen via the WebUI, or is this just how it is? It's been like this for as long as I can remember, and figured I'd finally post something about it in case there was something I was doing wrong.Browser Chrome: Doesn't seem to be different on the version of Chrome, but currently using version 61.0.3163.100 on OSX, but I've seen it countless times on my main windows PC. Emby Server 3.2.36.0: But again, it's been going on ever since I can remember. Thanks in advance for anything that may help fix this slight annoyance. Edited November 3, 2017 by Kelmino Link to comment Share on other sites More sharing options...
mastrmind11 717 Posted November 3, 2017 Share Posted November 3, 2017 Probably because you're not logging out at the end of your session and it's set to remember the last user that logged in. What happens if you log out and then go to the login page and click a user? Link to comment Share on other sites More sharing options...
Kelmino 17 Posted November 3, 2017 Author Share Posted November 3, 2017 Yes, if I log out it works fine. Is there a setting that I missed to not save the last user? Link to comment Share on other sites More sharing options...
mastrmind11 717 Posted November 3, 2017 Share Posted November 3, 2017 Yes, if I log out it works fine. Is there a setting that I missed to not save the last user? There is a setting in the apps, not sure if there's one in the browser since I don't use it, but seems like there must be. Link to comment Share on other sites More sharing options...
Happy2Play 8281 Posted November 3, 2017 Share Posted November 3, 2017 (edited) When using the WebUI xxx.xxx.xxx.xxx:8096/emby/web/login.html It always requires me to sign in twice, basically it does this. Click on Login Bookmark Click on a Person 1 - Logs in fine Click on Login Bookmark Click on Person 2 - Shows persons 1 media Click on Login Bookmark Click on Person 2 - Shows Person 2 media Click on Login Bookmark Click on Person 3 - Shows Person 2 Media Click on Login Bookmark Click on Person 4 - Shows Person 3 media It seems to always show the last person who logs in, and requires us to log in twice no matter the person. Is there another way I should be going to the log-in screen via the WebUI, or is this just how it is? It's been like this for as long as I can remember, and figured I'd finally post something about it in case there was something I was doing wrong. Browser Chrome: Doesn't seem to be different on the version of Chrome, but currently using version 61.0.3163.100 on OSX, but I've seen it countless times on my main windows PC. Emby Server 3.2.36.0: But again, it's been going on ever since I can remember. Thanks in advance for anything that may help fix this slight annoyance. Why do you have /emby in your url? Have you considered your bookmarks are outdated? Edit: This has been reported before, but it is a refresh issue when logging in over another user that has not logged off. @@Luke Refreshing the page shows the proper user. Edited November 3, 2017 by Happy2Play update Link to comment Share on other sites More sharing options...
Kelmino 17 Posted November 3, 2017 Author Share Posted November 3, 2017 There is a setting in the apps, not sure if there's one in the browser since I don't use it, but seems like there must be. Yeah, I couldn't find that anywhere . :/ Why do you have /emby in your url? Have you considered your bookmarks are outdated? Edit: This has been reported before, but it is a refresh issue when logging in over another user that has not logged off. @@Luke Refreshing the page shows the proper user. That's what it redirects me to after I logged in, would having /emby cause any issues anywhere? The family has learned to live with it, it's just a little annoyance that I'd like to get rid of at some point, it's really only ever an issue when guests want to watch Emby, I just have to make sure I set it up for them instead of letting them log into guest by themselves. Thanks for the replies though. Link to comment Share on other sites More sharing options...
Luke 37058 Posted November 3, 2017 Share Posted November 3, 2017 the best bookmark is just http://localhost:8096 Link to comment Share on other sites More sharing options...
Kelmino 17 Posted November 3, 2017 Author Share Posted November 3, 2017 the best bookmark is just http://localhost:8096 When I've done that, it just logs the last user in, and we have 4 user accounts in our house that all get used frequently on the main TV. Link to comment Share on other sites More sharing options...
Luke 37058 Posted November 3, 2017 Share Posted November 3, 2017 If the users have a password, then the login screen will have a "remember me" checkbox. Link to comment Share on other sites More sharing options...
Kelmino 17 Posted November 3, 2017 Author Share Posted November 3, 2017 If the users have a password, then the login screen will have a "remember me" checkbox. None of the users have a password Link to comment Share on other sites More sharing options...
Luke 37058 Posted November 3, 2017 Share Posted November 3, 2017 Ok, well that still remains the recommended approach. Perhaps having the checkbox also in app settings would make sense. Link to comment Share on other sites More sharing options...
