Live TV Channels
lja
 Share
Go to solution Solved by krustyreturns,
 I have Live TV setup and it seems to be working with the exception that it does not pickup some channels that are in windows media center. Is there any way to manually input? How can I get any missing channels to show in the Live TV guide and under channels? Thanks.
Link to comment
Share on other sites
  • Solution
krustyreturns
It should be importing any channels it sees as viewable in wmc, with the possible exception of drm'd channels.  Is it possible that these channel have drm?  See the channels tab in swmc to import these also.
  • Like 1
Link to comment
Thanks. That did it.
Link to comment
 Share
